Citadelgrad Posted April 24, 2021 Share Posted April 24, 2021 Very very nice, John. Thunnus 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted April 24, 2021 Share Posted April 24, 2021 I'm definitely lazy when it comes to washes, but I do always appreciate the look you can get with your pastel washes John. Maybe I will have to break down and try them one of these days. Great update, it's all coming together now. Matt Thunnus 1 Link to comment Share on other sites More sharing options...
aircare84 Posted April 26, 2021 Share Posted April 26, 2021 Impressive John! The finish & wash are just first class. Your attention to detail is what sets you above mere mortals such as myself. Larry Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted May 2, 2021 Author Share Posted May 2, 2021 Thanks guys! Just inching along here! The flat coat has been sprayed onto the D-13. I use Model Master Flat Clear Acryl for my flat coats. Wackyracer, Jeff T, dodgem37 and 17 others 20 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted May 2, 2021 Share Posted May 2, 2021 Thunnus 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted May 2, 2021 Share Posted May 2, 2021 Utterly incredible work John. It's all coming together now. Can't wait to see the end. Matt Thunnus 1 Link to comment Share on other sites More sharing options...
Wackyracer Posted May 2, 2021 Share Posted May 2, 2021 Another masterpiece John, the bar just gets raised again. Paintwork is exemplary. Aaron Link to comment Share on other sites More sharing options...
dodgem37 Posted May 2, 2021 Share Posted May 2, 2021 You got The Power, John. Sincerely, Mark Thunnus 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted May 2, 2021 Share Posted May 2, 2021 Thunnus 1 Link to comment Share on other sites More sharing options...
levier Posted May 2, 2021 Share Posted May 2, 2021 Excellent! Nice soft mottling. Thunnus 1 Link to comment Share on other sites More sharing options...
mywifehatesmodels Posted May 3, 2021 Share Posted May 3, 2021 I'm already smiling. Can't wait to see it finished! John Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted May 8, 2021 Author Share Posted May 8, 2021 Thanks guys! Trying to squeeze in some modeling work in between family obligations. Got my two daughters, a niece and a brother-in-law visiting so I'll probably not have a lot of time at the bench this weekend. I did manage to get a salt fade layer onto the model. Sometimes used as a chipping technique, I like to use it to impart some fade wear onto the surface of the model. It kind of resembles the water marks left by rain on things stored outside. The dried salt crystals form a random pattern mask over which a very watery light color (Tamiya Deck Tan in this case) is sprayed. Since it is hard to gauge the effect as you are spraying, I usually have to make some sort of adjustments afterwards. In this case, I'll be toning down some of the effects by gentle micromeshing. Some of the external bits are being added onto the model at this stage including the exhaust tips and tail wheel. You can also see some minor chipping that I've added using a silver pencil. I glued the landing gear legs into place using JB Kwik Weld, which gives me a bit of cure time to adjust the placement before the glue dries. The wing cannon barrels have also been glued in. I fashioned a tension spring for the aerial wire from copper wiring. It will be mounted on the tail mast when the time comes. LSP_Kevin, TAG, XOPCT and 13 others 16 Link to comment Share on other sites More sharing options...
Citadelgrad Posted May 8, 2021 Share Posted May 8, 2021 Great to see you get some bench time, John. This is sublime. So much going on, but nowhere near too much. Amazing work. Link to comment Share on other sites More sharing options...
Beaconroot Posted May 8, 2021 Share Posted May 8, 2021 Inching closer to the finish line. An incredible piece of work John. Again thanks for sharing it with us. Jim Root Link to comment Share on other sites More sharing options...
Thunnus Posted May 8, 2021 Author Share Posted May 8, 2021 Thanks guys! The wheels have been glued into place. Again using JB Kwik Weld to allow me time to set the wheels so that the flat spots are flush with the ground. I'm still playing around with the finish. The combination of the flat coat and salt fading have reduced the panel line wash effect in certain places so I am reinforcing that. Adding chipping effects here and there. chuck540z3, aircare84, Alain Gadbois and 16 others 19 Link to comment Share on other sites More sharing options...
