Miloslav1956 Posted October 4, 2020 Share Posted October 4, 2020 (edited) Beautiful work, inspired me to finish 17th Tempest. Edited October 4, 2020 by Miloslav1956 nmayhew and chuck540z3 1 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted October 4, 2020 Share Posted October 4, 2020 (edited) On 10/2/2020 at 7:44 AM, scimitarf1 said: The top is definitely flat. Hurricane is the same ... 5 hours ago, chuck540z3 said: Drill a small hole into the back of the clear part, then place red or green paint inside as colored bulbs I've done it that way too but after the clear red or green, I stick some silver behind it. Gives it a reflective look. Looking great so far Edited October 4, 2020 by MikeMaben chuck540z3 and Landrotten Highlander 1 1 Link to comment Share on other sites More sharing options...
Neo Posted October 4, 2020 Share Posted October 4, 2020 (edited) Hi Chuck Love the work on the lights. I do almost the same process, just did the 1/48 hasegawa f-14 wing light. I do 1 extra step from the ones you mentionned, once ive put the clear red or green, i also paint the entire rear with chrome to simulate the reflector behind the lens. Then i CA ect like you mentioned. Let me know what you think of thid. Great work as usual Chuck! Can't wait for the next update Cheers Just notice after posting MikeMaben mentionned the same thing Edited October 4, 2020 by Neo chuck540z3 1 Link to comment Share on other sites More sharing options...
Nighthawk Calling 1 Posted October 4, 2020 Share Posted October 4, 2020 Hi Chuck Can I ask did you drill the marker and nav lights on the sprue then cut them off and what size drill did you use. Thanks chuck540z3 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted October 4, 2020 Author Share Posted October 4, 2020 (edited) Thanks for the tip on the chrome or silver background guys, which I will try next time. I had used clear red and green first, but then removed it because it didn't show up well enough, but the silver background might have helped with that. My goal was to make the color of each light obvious, like the pics below, so I used a solid red and green paint instead. Note that each light is tucked into the very corner, which I couldn't do with a tiny drill (#80 followed by #64), so I drilled them outwards a bit instead. I did this with these tiny parts cleaned up off the sprue, so it was tricky to drill them and not lose them to the carpet monster! I just noticed the additional fastener detail around each light. Consider that done as well! Cheers, Chuck Edited October 4, 2020 by chuck540z3 MikeMaben, Marcel111, Nighthawk Calling 1 and 2 others 4 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted October 4, 2020 Author Share Posted October 4, 2020 7 hours ago, Miloslav1956 said: Beautiful work, inspired me to finish 17th Tempest. Miloslav. I have admired your work on your previous models of this kit and was wondering what you did about the wing dihedral issue? Any other tips to share? Thanks, Chuck Link to comment Share on other sites More sharing options...
chuck540z3 Posted October 17, 2020 Author Share Posted October 17, 2020 (edited) October 16/20 I have found a few more edits you should do (or not do) to this build. With so many versions of Typhoons and Tempests, Special Hobby has many parts that are common to most of them, but the instructions have missed some important items as shown before. After doing the left wingtip light, I was wondering what went into the little hole in the wing next to it? It turns out, nothing!, so this hole should be filled. I’ve found a few pics of Mk II Tempests with a pitot tube here, so this is likely why the wing has it? Steps 31 and 32 are the components of the tail assembly. As with the rest of the model, I carefully sanded everything smooth and restored all of the detail to make it sharp. Installation was tricky, because the horizontal stabilizers did not fit very well, so I had to sand and fill the connecting seam and rescribe it. Meanwhile, the rudder does not fit into the core of central stabilizer, so to glue it I used extra thick CA glue to act as a gap filler and glue at the same time. I quite like the rudder detail that has realistic looking raised ribs with subtle fastener detail beneath as it should be. I spent a long time on my Kitty Hawk Harvard build correcting this feature. And to show there's no cheating on the bottom. Most of Step 33 has been done already, but the canopy rails (I38, top right) need to be installed. Followed by Step 34, where the rear canopy mechanism Part E14 is glued in place, on top of the canopy rails. Now a complete surprise and disappointment! I spent a lot of time painting that little tank on Part J6 behind the seat, assuming you could see it from the front but not the back. As it turns out, you shouldn’t bother painting it at all! Because when you install Part E-14, it completely covers the tank and everything behind the seat! Very weird! Another part made for another aircraft, but the instructions have not been updated? Before I glued in the canopy rails, I painted them aluminum for ease of painting later. Part E-14 does not fit well at all and I had to make multiple modifications to it, including lowering the seat braces that should touch the top of the seat back and not extend over it. After at least 30 times sanding and trimming, it fits OK now. Much of this detail is partially obstructed from view by the canopy, but you can still see it. The Canopy fits very tight, so make sure you glue the rails in strongly or they will pull off the cockpit sills. The seam line at the back of Part E14 does not exist, so it should be filled and panel lines re-scribed. With the tail and canopy bits glued in, it's now time to start painting while I assemble other bits like the landing gear and the prop. At this stage of a build I feel like taking the model and running around the living room making airplane noises like I did when I was a kid! At 66 years old, my wife would not be impressed, so I’ll just pretend I did it. Thanks for looking in. I’m on the homestretch now, which is kind of exciting and sad at the same time. I’m already looking at candidates for my next project. Maybe a Wingnut Wings Biplane? Although I’m not a Biplane guy, I just bought 3 kits before they are all gone, just in case I change my mind. Cheers, Chuck Edited October 17, 2020 by chuck540z3 dodgem37, Brett M, Anthony in NZ and 20 others 22 1 Link to comment Share on other sites More sharing options...
levier Posted October 17, 2020 Share Posted October 17, 2020 Or maybe a Meng triplane... chuck540z3 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted October 17, 2020 Share Posted October 17, 2020 Chuck, that is sublime mate! I love that last photo.... I am trying to stay focused on my Phantom, but you are making this very difficult for me! chuck540z3 1 Link to comment Share on other sites More sharing options...
vvwse4 Posted October 17, 2020 Share Posted October 17, 2020 This is outstanding!!! Looking forward to the paintjob, kinda hoping you make a frontline, that is very weathered, Tempest. Enjoy your updates a lot!! Rick chuck540z3 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted October 17, 2020 Author Share Posted October 17, 2020 (edited) 18 hours ago, vvwse4 said: This is outstanding!!! Looking forward to the paintjob, kinda hoping you make a frontline, that is very weathered, Tempest. Enjoy your updates a lot!! Rick You betcha Rick! After 2 pristine models in a row (Harvard, F-5E), it's time to get down and dirty again. I will be using the well known salt weathering technique and sponged liquid mask on an aluminum background for chipping. Here is my last model of an F-4E where I used it for reference. Lots of additional and enhanced riveting here too. Cheers, Chuck Edited October 18, 2020 by chuck540z3 vvwse4, JayW, Landrotten Highlander and 8 others 10 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted October 17, 2020 Share Posted October 17, 2020 Wonderful update. Love that Phantom. Sincerely, Mark chuck540z3 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted October 17, 2020 Share Posted October 17, 2020 Always enjoy how clean and clear your work is. Makes it so easy to follow and see exactly what's going on. Matt chuck540z3 1 Link to comment Share on other sites More sharing options...
airscale Posted October 17, 2020 Share Posted October 17, 2020 i literally come over all funny when I tune in to your build threads Chuck... such precision and such a can do approach that makes any kit a canvas for a show winner wonderful to see also PM'd you a pic of something that may be of interest from my Sea fury build which shares some common bits around the canopy. I don't like to litter others threads with something that is not the OPs build lol Peter Anthony in NZ, chuck540z3 and nmayhew 2 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted October 17, 2020 Share Posted October 17, 2020 Chuck, your fine riveting work just doesn’t cease to amaze me. Excellent progress all round! Marcel chuck540z3 1 Link to comment Share on other sites More sharing options...
