Dandiego Posted April 21, 2019 Author Posted April 21, 2019 The horizontal stabs have been installed. I cut a slot from one side to the other, I then inserted a thin piece of sheet metal to use as a support. The sheet metal was then pushed into each stab between the upper and lower skins. Lots o epoxy and Bondo later..... Working on the lower inboard wing panels. These have a lot going on. I will be adding wells for the wheels and flap. I will need to accomodate exhausts and intakes as well. And I found some bits that will become the exhaust. Later, Dan Starfighter, Harold, LSP_Kevin and 9 others 11 1
Starfighter Posted April 23, 2019 Posted April 23, 2019 Great progress, I am following with huge interest! Dandiego 1
R Palimaka Posted April 24, 2019 Posted April 24, 2019 (edited) Wow. This is one gutsy build! It's looking spectacular so far. I love how you work out methods to build and detail what is basically a shell. Really impressive progress...and so fast! Richard Edited April 28, 2019 by R Palimaka Dandiego 1
Dandiego Posted April 24, 2019 Author Posted April 24, 2019 1 hour ago, R Palimaka said: Wow. This is one gutsy build! It's looking spectacular so far. I love how you work out methods to build and detail what is basically a shell. Really impressive progress...and so fast! Ricahrd Richard, fast?? Yes I do make some quick progress but.... Sometimes I get ahead of myself and make mistakes. Just yesterday I realized that the 2 main gear wells were not lined up properly. Out with the dremel. Took about 10 minutes to correct. Dan Harold and MikeC 2
Dandiego Posted April 28, 2019 Author Posted April 28, 2019 (edited) Ok.... The bottom profile on the intakes needed re-shaping. So I cut the lower surface and re-attached with a little less of a curve. Next I want to have a representation of the lower portion of the engine with the inner flaps open. So I found a half round piece of something in the spares box that looked to be the right size. It was and I popped it into place. I made a list to focus my efforts. And I have installed the exhausts and am shaping the area aft. Yup thats it for today, Dan Edited April 28, 2019 by Dandiego Out2gtcha, blackbetty, johncrow and 7 others 9 1
Dandiego Posted May 5, 2019 Author Posted May 5, 2019 (edited) A little more progress. I have been working on the intake interiors. I bent some plastic over a candle to get the main shape and then added a back plate and a side plate. I cut a hole in the back plate to accept the compressor face. Lots of putty and sanding to get a smooth transition to the engine face. I covered the hole in the rear and poured in some gloss white paint to get that smooth look. I used some tape to center the compressor face and then slobbered on some CA to hold it in place. Not very pretty but it will work. And a little work to finish up the exhausts. I cut some plastic tubing in half for each side of the exhaust. Later, Dan Edited May 5, 2019 by Dandiego johncrow, Greg W, Kagemusha and 10 others 12 1
Dandiego Posted May 20, 2019 Author Posted May 20, 2019 A bit of a break, but here is a little more progress. I have cut back the fuselage behind the cockpit to accommodate an equipment shelf. I then added a piece of plastic to hold the equipment in this area. Test fit of the windscreen. Some putty work to smooth out the intakes. Thats all, Dan Starfighter, sandokan, Lothar and 9 others 11 1
Dandiego Posted May 22, 2019 Author Posted May 22, 2019 (edited) Just a little bit more. I realized that the interface between the vertical tail and rudder was not perpendicular. So I added a shim and glued it onto the trailing edge of the tail. I also built up the base of the rudder to a more substantial base. I have been working on the instrument cowl. Very hard to get a good look at what this area looks like. Here is my best guess. Unpainted and with a coat of flat black. Later, Dan Edited May 22, 2019 by Dandiego Greg W, Lee White, MikeC and 6 others 8 1
LSP_Kevin Posted May 22, 2019 Posted May 22, 2019 Excellent hardcore modelling so far, Dan! Kev Dandiego 1
Dandiego Posted June 7, 2019 Author Posted June 7, 2019 (edited) Been a while but progress continues, I have begun scribing, not my favorite thing to do. An exhaust port on the fuselage. Scribing the nose cone. Also I have glued the windscreen on and added putty. Dan Edited June 7, 2019 by Dandiego Lee White, sandokan, MikeMaben and 6 others 8 1
shark64 Posted June 8, 2019 Posted June 8, 2019 I hate rescribing too. its looking rather nice. Dandiego 1
Out2gtcha Posted June 10, 2019 Posted June 10, 2019 Cool stuff Dan, and brave too! Looking forward to more Dandiego 1
