Dandiego Posted March 8, 2019 Posted March 8, 2019 (edited) I have been planning on my next project and here it is. Tigger Models Vacuform Banshee. I have built only one complete vacform model in the past and that was 20 years ago. I have already begun so lets dive in. I have already separated the parts from the backing sheet and sanded them down to their final form. My method of building will be to cut out a 40 thou spine that I will glue the fuselage halves to. In addition I have cutout and bolted on 2 thin wood stiffeners for added strength and rigidity. I have already made some cutouts for the cockpit and nose gear bay. Here are the wheels, from my spares box, and a scratchbulit nose gear bay. And a basic cockpit shell. Much work to do on this, but you have to start somewhere. Later, Dan Edited March 8, 2019 by Dandiego Lee White, Starfighter, Gazzas and 11 others 13 1
Out2gtcha Posted March 8, 2019 Posted March 8, 2019 Nice Dan! Maybe I can take a lesson or two away...............havnt attempted a vac yet.
Tomjw Posted March 8, 2019 Posted March 8, 2019 This is one I'd like to follow. I do love the lines of the Banshee. Cheers, Tom
Fvdm Posted March 9, 2019 Posted March 9, 2019 I always admire people who build a vac-form. I know I can't build one but I like to watch and follow.
Gazzas Posted March 9, 2019 Posted March 9, 2019 Man, do you pick some tasks, Dan! Looking forward to it!
Dandiego Posted March 16, 2019 Author Posted March 16, 2019 (edited) Guns. The gun troughs are quite prominent so I am improving these features. Really not a good way to reproduce these on a vac kit so some improvements. And some internal items added. Vac on! Dan Edited March 16, 2019 by Dandiego LSP_Kevin, blackbetty, Lee White and 7 others 9 1
Dandiego Posted March 23, 2019 Author Posted March 23, 2019 Just a little preliminary work on the wings.I have cut out some sheet plastic blanks that were transferred from my plans. The shape of the kit parts and the blanks based on the drawings don't match. So I will have to sort out which is closer to actual. Anyway you can also see that I have cut a slot into the side of the fuselage. This will allow for a wooden support to pass through the fuselage and into the wings. Kinda looks like a Banshee. Dan Out2gtcha, sandokan, MikeC and 6 others 9
Dandiego Posted March 23, 2019 Author Posted March 23, 2019 On 3/8/2019 at 10:22 AM, Out2gtcha said: Nice Dan! Maybe I can take a lesson or two away...............havnt attempted a vac yet. I am quite sure the lesson will be......run away fast. Vacs are a bit of work, but if you like to build something different..... Whatcha gonna do? Dan
Lee White Posted March 23, 2019 Posted March 23, 2019 Cool! Just in case you are curious as to how this kit looks when finished.......... https://www.largescaleplanes.com/articles/article.php?aid=227
Dandiego Posted March 23, 2019 Author Posted March 23, 2019 11 hours ago, Lee White said: Cool! Just in case you are curious as to how this kit looks when finished.......... https://www.largescaleplanes.com/articles/article.php?aid=227 Thanks Lee, some good stuff in there. I will be adding wingtip tanks and probably painting it in a grey and white scheme. Dan Lee White 1
Dandiego Posted March 29, 2019 Author Posted March 29, 2019 Ok progress... The upper surface of the wings have been glued to the wing blank. You can see where I changed the leading edge contour, just look for the Bondo. A few drawn in panel lines to see how the wing will look. Underside, there will be a lot going on here as I plan to have the flaps deployed. Tail planes. Wooden wing support. Lots of work to be done here. Vertical tail. Later, Dan Shawn M, ColinR, MikeC and 9 others 11 1
Dandiego Posted March 31, 2019 Author Posted March 31, 2019 (edited) Minor and major progress. Major, I glued in the wing support and also added a cross piece so it lined up level and wouldn't move. Minor, I have cut down the side consoles. They sat too high. I have added the new wider side consoles. Lots still to do here. Dan Edited March 31, 2019 by Dandiego Alain Gadbois, blackbetty, MikeC and 8 others 10 1
airscale Posted March 31, 2019 Posted March 31, 2019 brilliant I love what you are doing here Dan - it is going to be one impressive model thats for sure I can see you enjoy the freedom of just creating rather than be bound by what a kit has in it and it is that expression that makes your kind of building unique Peter Lee White and Dandiego 2
