Great show.  Love how you render wood.  Could you explain this technique?
Thank you.
Sincerely,
Mark
Thank you.
Sincerely,
Mark
I just use the method on the hints and tips on the WnW website
  • Spray base coat of either XF78 Deck tan, for light wood
  • or XF79 Deck brown for dark wood
  • Squeeze blob of burnt umber oils and add thinners with brush
  • with this model i brushed it on quiet thin so there is not much wood graining effect, my last model was ZM Horten where i went heavier and created wood grains with wider brush and thicker dark umber mix
  • Before the oil had fully dried i  highlighted joins and rivits with Tamiya panel line wash, then blended the wash with stiff brush, so it blends with the oils, highlighting the features
What i did do was watch every youtube i could find, and every tutorial out there. But there is not better teacher than having a go, I would do the Horten completly different now just based on experiance of the Felixstowe
To be honest I still have no idea how to simulate the mahogany wood on the Felix, but WnW gives extra side panels so i can practice practice practice
Hope this helps get you started
There are 4 rigging wires over the top of the cockpit, so i thought I'd make my own eyelets, 4 done in not bad time, but i have this felixstowe an Fe and a W12 in my stash, so i ordered 6 packs of bobs buckles and some tube, great price, thanks bob:clap2:
My attempts are a bit chunky but wont be seen anyway, I need Bobs perfect ones for the show areas
The interior was finished last night, i hevent fitted the seat belts because i want to try and find pilot figures
dEhLJqs.jpg?1
I've decided to paint the inside walls basically so i can get more practice with my new airbrush
Having spent the evening trying to fit the halves tightly together, i have decided not to paint the inside walls:frantic:
