Piprm Posted February 3, 2017 Share Posted February 3, 2017 (edited) Tricky Hah? 2D > 3D? Yes, that fine line between construction and creation... Phil Edited February 3, 2017 by Piprm Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 3, 2017 Share Posted February 3, 2017 Wow, GREAT stuff Dan! Link to comment Share on other sites More sharing options...
Dandiego Posted February 3, 2017 Author Share Posted February 3, 2017 Hubert and Phil, how right you are. I saw the shape issues as well. Basic problem is that I made the cross section of the intake throat too small. Dang it! I am already formulating a repair stategy. Stay tuned. Dan Piprm 1 Link to comment Share on other sites More sharing options...
NORMCO Posted February 3, 2017 Share Posted February 3, 2017 Have to agree with MostlyRacers. The bottom of the intakes are OK. The top is too "fat" and "hooked." Harold 1 Link to comment Share on other sites More sharing options...
Lee White Posted February 3, 2017 Share Posted February 3, 2017 I think some judicious sanding with a file will fix that, and a dowel with sandpaper around it will induce that concave profile. Chin up, Dan, 3 steps forward 1/2 step back. Link to comment Share on other sites More sharing options...
dodgem37 Posted February 3, 2017 Share Posted February 3, 2017 Fantastic work, Dan. Love what you've done. Sincerely, Mark Link to comment Share on other sites More sharing options...
Joel_W Posted February 3, 2017 Share Posted February 3, 2017 Dan, After seeing what you've been able to accomplish, I have no doubt that you'll have a proper fix for those intakes. Still, your work is just world class compared to my mostly OOB builds. Joel Hubert Boillot and Harold 2 Link to comment Share on other sites More sharing options...
Dandiego Posted February 3, 2017 Author Share Posted February 3, 2017 (edited) Well I am sure that fix will be more than just a file and some sandpaper. My plan is to remove the existing intake trunking from the bottom, and then re-install new trunking to create a larger intake mouth. That in my opinion is the root of the problem. I have all weekend so I should be able to get at least one side done. Dan Edited February 6, 2017 by Dandiego Harold, Piprm and NORMCO 3 Link to comment Share on other sites More sharing options...
Harold Posted February 5, 2017 Share Posted February 5, 2017 Well I am sure that fix will be more than just a file and some sandpaper. My plan is to remove the existing intake trunking from the bottom, and then re-install new trunking to create a larger intake mouth. Than in my opinion is the root of the problem. I have all weekend so I should be able to get at least one side done. Dan I think the "imagineering" is the fun part of doing full scratchbuilds. I have a couple I started on years ago laying around, I might dig one out someday and finish it. Unfortunately they are in the wrong scale..LOL Keep up the good work. Lee White 1 Link to comment Share on other sites More sharing options...
Dandiego Posted February 10, 2017 Author Share Posted February 10, 2017 Ok re-doing the intakes. In the first photo I have ripped out the top intake. Next enlarge the opening and add a larger back plate. Next install new intake trunking. Bondo Time... Sanding time. Also I have reinstalled the spine. In my opinion a much better result this time. Now all I have to do is do the same thing on the other side. Dan sandokan, MikeMaben, airscale and 3 others 6 Link to comment Share on other sites More sharing options...
ClumsyDude Posted February 10, 2017 Share Posted February 10, 2017 Balls of steel, that's all I can say. Jim MikeMaben, Dandiego, Piprm and 1 other 4 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted February 10, 2017 Share Posted February 10, 2017 Sensational Dan!! Love your projects..... Dandiego 1 Link to comment Share on other sites More sharing options...
Joel_W Posted February 10, 2017 Share Posted February 10, 2017 Dan, You're just plan fearless The end result looks really good. Joel Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted February 11, 2017 Author Share Posted February 11, 2017 Balls of steel, that's all I can say. Jim Jim, just checked.....nope. Dan ClumsyDude 1 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted February 11, 2017 Share Posted February 11, 2017 Good, otherwise you'd be in trouble everytime you go through airport security ... Hubert Dandiego and Lee White 2 Link to comment Share on other sites More sharing options...
