etendard Posted December 18, 2016 Share Posted December 18, 2016 Dandiego 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted December 19, 2016 Share Posted December 19, 2016 Looking good Dan, keep on truckin' Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted December 19, 2016 Share Posted December 19, 2016 Good to see you back at this one, Dan. Sometimes it's best to just start allover again. I'm looking forward to the nxt update. Cheers Rainer Link to comment Share on other sites More sharing options...
Guest Uncle Fester Posted December 19, 2016 Share Posted December 19, 2016 (edited) This is an impressive undertaking and I'm envious. A 1/32 F-90 would never have been kitted, I don't believe, except maybe as a vac. But even then. The methodology is clearly sound, as you've demonstrated. From my own past experience, getting from blueprint to actual 3D tangible object isn't always that easy. Those little nooks and crannies, the wifferills, the little sumb*tches that make you want to toss it at the wall...been there. The first attempt was admirable. I was in absolute envy of the results and the impromptu "tutorials" on how to fix things when they went wrong. It's been both fascinating and educational. I think try #2 is going to go more quickly and with a result that's going to make you smile more. Thanks for sharing all your ideas and efforts. Keep plugging away and soon you'll have a "silver surfer" of a plane, I should think. UF Edited December 19, 2016 by Uncle Fester Dandiego 1 Link to comment Share on other sites More sharing options...
Lee White Posted December 19, 2016 Share Posted December 19, 2016 Great going, Dan, you won't regret it. I think the splitting of the formers and putting them on the spine is best, I did it with my now-stalled F3H Demon. When you put the outside stringers on, you'll be surprised how strong it is. http://forum.largescaleplanes.com/index.php?showtopic=49525&hl=demon Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted December 20, 2016 Author Share Posted December 20, 2016 This is an impressive undertaking and I'm envious. A 1/32 F-90 would never have been kitted, I don't believe, except maybe as a vac. But even then. The methodology is clearly sound, as you've demonstrated. From my own past experience, getting from blueprint to actual 3D tangible object isn't always that easy. Those little nooks and crannies, the wifferills, the little sumb*tches that make you want to toss it at the wall...been there. The first attempt was admirable. I was in absolute envy of the results and the impromptu "tutorials" on how to fix things when they went wrong. It's been both fascinating and educational. I think try #2 is going to go more quickly and with a result that's going to make you smile more. Thanks for sharing all your ideas and efforts. Keep plugging away and soon you'll have a "silver surfer" of a plane, I should think. UF Uncle, I agree with you on several points. Never going to be kitted. Going from drawing to model is not straightforward. Even with some good drawings there are always some things that are "lost in translation". I am unsure how everything will come together where the cockpit and intakes come together. Version 2 is already progressing better than the first. Thanks for your comments. Dan Link to comment Share on other sites More sharing options...
Dandiego Posted December 20, 2016 Author Share Posted December 20, 2016 Great going, Dan, you won't regret it. I think the splitting of the formers and putting them on the spine is best, I did it with my now-stalled F3H Demon. When you put the outside stringers on, you'll be surprised how strong it is. http://forum.largescaleplanes.com/index.php?showtopic=49525&hl=demon A Demon?! Wow. I went back a read your wip. Many correlations with my build. I read in there that you have a scratch built Vigilante in progress, one of my holy grails. What ever happened to that project? Dan Link to comment Share on other sites More sharing options...
Lee White Posted December 20, 2016 Share Posted December 20, 2016 (edited) A Demon?! Wow. I went back a read your wip. Many correlations with my build. I read in there that you have a scratch built Vigilante in progress, one of my holy grails. What ever happened to that project? Dan Hi Dan, My Vigi project is stalled at the 70% point- I started it as an experiment, to see how far I could go without using my vac rig in a scratch build. My major mistake was not planking enough, filling voids with resin... So it weighs a ton and a half. Ridiculous as it sounds, my lack of foresight in this regard pretty much turned me off to the project, so, it languishes. I have plans for it, so it might make a re-appearance here on LSP. EDIT: Here is the Vigilante thread. If you'll notice, I had to do this one twice, too, like your XF-90. Sometimes you just gotta do it. http://forum.largescaleplanes.com/index.php?showtopic=27947 Edited December 20, 2016 by Lee White Dandiego 1 Link to comment Share on other sites More sharing options...
shark64 Posted December 22, 2016 Share Posted December 22, 2016 What? you are doing two.. glad to see u back at it. phoenix ? ipms in phoenix next year? Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted December 22, 2016 Author Share Posted December 22, 2016 Just one shark. One is enough. Nats in Phoenix in 2018. Who knows might be finished by then. Link to comment Share on other sites More sharing options...
Dandiego Posted December 23, 2016 Author Share Posted December 23, 2016 Progress continues.... First I have added new exhaust tubes. They are the tubes that my airbrush needles came in. They were the exact size I needed. The tire represents the end of the engine, it actually works quite well. Next. cut the nose off of the original and graft it onto the new. Add more ribs and formers. And last for now, cut and install a backing plate that will form the inside of the intake. Thats all for now. Dan Lee White 1 Link to comment Share on other sites More sharing options...
Lee White Posted December 23, 2016 Share Posted December 23, 2016 Wow, intakes? I did that exactly once, on my F-111. My next project will have FOD covers. Too much PITA factor for me to ever do that again. Hat's off! Dandiego 1 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted December 28, 2016 Share Posted December 28, 2016 My next project will have FOD covers. Too much PITA factor for me to ever do that again. Sissy! Dan, great progress on that bird. I'm still not sure how you are going to tackle the intakes. I'll be watching this closely. Cheers Rainer Dandiego and Lee White 2 Link to comment Share on other sites More sharing options...
Dandiego Posted December 31, 2016 Author Share Posted December 31, 2016 (edited) A little more work. I have re-installed the cockpit. I had to shave down the sides of the consoles in order for the outside skin to fit. And a little work on the exhaust shroud. Going about it a little different than the last time. Thin sheet bent to shape and glued in place. Lots of clamping. Will shape it to final look when it is dry. Ok see you next year. Dan Edited December 31, 2016 by Dandiego Starfighter and Lee White 2 Link to comment Share on other sites More sharing options...
Dandiego Posted January 2, 2017 Author Share Posted January 2, 2017 A little more work. I needed to box in the main landing gear wells, so here they are. They are actually too wide here. I will narrow them in a bit. Also the speed brake wells are also in progress. Now to thicken up the tail. 2 laminations of 60 thou card, glued and clamped. Shaped and sanded. I have created a slot to hold a 60 thou stiffener to glue the stabilizors to. Next up.... finding a way to attach the wings... Dan Starfighter, Anthony in NZ, MikeMaben and 1 other 4 Link to comment Share on other sites More sharing options...
