Out2gtcha Posted November 17, 2016 Share Posted November 17, 2016 Nice! Love watching another magic session happen. Dandiego and Harold 2 Link to comment Share on other sites More sharing options...
sandokan Posted November 17, 2016 Share Posted November 17, 2016 wow! Very nice and interesting theme! Dandiego 1 Link to comment Share on other sites More sharing options...
Azgaron Posted November 17, 2016 Share Posted November 17, 2016 Very nice work so far! HÃ¥kan Dandiego 1 Link to comment Share on other sites More sharing options...
NORMCO Posted November 18, 2016 Share Posted November 18, 2016 Resin copies? I'd be "in!" paul fisher and Dandiego 2 Link to comment Share on other sites More sharing options...
Dandiego Posted November 18, 2016 Author Share Posted November 18, 2016 Normco, sounds like a great idea. But I would have no idea how to make that happen. Dan Link to comment Share on other sites More sharing options...
wunwinglow Posted November 18, 2016 Share Posted November 18, 2016 How did I miss this? Fab looking aeroplane, it will make a fab looking model! Nice one! Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted November 24, 2016 Author Share Posted November 24, 2016 (edited) Ok I'm back. I have spent the last week working on getting all of the ribs shapped correctly. My original work was quick and dirty and they needed a lot of work. I started working on the port fuselage side. Each rib was checked for shape and to make sure it "flowed" correctly into the next. Once I was happy I then transferred each ribs dimensions to the opposite side. I go rather fast when doing my rough build and that necessitates a lot of careful cleanup before proceding. Or I could stress over getiing it 100% accurate the first time. My method works well for me and, for me, I believe is faster. First up is the back end. I have cobbled together parts from the spares bin to approximate the jet exhaust. There is an exhaust tube from a Monogram F-4, a sheet plastic extension and a 1-32 tire at the end to simulate the engine exhaust. Trust me it is far enough back that no one will notice. Next will be strengthing the entire rib structure with lengthwise stringers. Next I have begun skinning the beast. I am using 60 thou sheet plastic to get a solid non-flexing skin that can endure vigorous sanding to get to the final shape. Yes some serious clamping is needed. A difficult area needs some thought and attention and that is the forward fuselage where the cockpit needs to be sorted out before I can proceed in this area. Here is a spare cockpit from an F-80 and the corresponding resin seat. Later, Dan Edited November 24, 2016 by Dandiego Harold, airscale, sandokan and 1 other 4 Link to comment Share on other sites More sharing options...
Dandiego Posted November 24, 2016 Author Share Posted November 24, 2016 Dan, in my builds I don't put much effort into internal parts of the model that will never be seen. It may look crude, but who cares? All that counts is the finished model. Anyway, it's a great project and I'm looking forward to see more progress. I wonder how you will tackle the air intakes. Have you any ideas yet? Cheers Rainer Rainer, I do have some thoughts on the intakes. As the shape is a basic rounded triangle shape I believe that I can bend some thin sheet and let it fill a precut former. I know that probably isn't very helpful but I haven't actually pulled it off yet. Stay tuned. Love your work. It is incredible. Dan Rainer Hoffmann 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted November 24, 2016 Share Posted November 24, 2016 Dan Amazing project and following with enthusiastic interest. I often wondered when doing a scratch build project, do you take into account the thickness of the 'skin' when making the ribs? I know it sounds silly but I very curious. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Dandiego Posted November 24, 2016 Author Share Posted November 24, 2016 Dan Amazing project and following with enthusiastic interest. I often wondered when doing a scratch build project, do you take into account the thickness of the 'skin' when making the ribs? I know it sounds silly but I very curious. Keep 'em coming Peter Yes Peter, all of the ribs where slightly smaller than the drawings to accommodate the skin. Dan Link to comment Share on other sites More sharing options...
airscale Posted November 24, 2016 Share Posted November 24, 2016 this is amazing to watch - I know what you mean about getting into a groove and doing it your way - the results speak for themselves and are seriously impressive Peter Harold, Dandiego and Derek B 3 Link to comment Share on other sites More sharing options...
Dandiego Posted November 26, 2016 Author Share Posted November 26, 2016 Ok I have 4 days off this weekend so I should get a fair amount of bench time. First off is to continue with the skinning of aft fuselage. I am using 6mm wide strips that I cut off of a larger sheet. I also am staggering the joints for a stronger assembly. Tube glue is being used throughout consrtuction. First picture is of the port aft area, strips have been glued on. First the rough edges are scraped level with the edge of a knife, rough sanded and then the recess between strips have CA applied to the entire length. Finally the seams are filled with Bondo. Next skinning the other side. Skinning the spine. Sheet plastic was curved to fit by bending with pliers. Any marks left over from the bending process should sand out later. Bondo time! Add laminations to thicken the tail. Cut a tube in half, this is harder than it may seem to get it just right. Apply to fuselage to form the spine. Thanks, Dan Derek B, Harold, MikeMaben and 1 other 4 Link to comment Share on other sites More sharing options...
Lee White Posted November 26, 2016 Share Posted November 26, 2016 Dan, your 'damn the torpedoes, full speed ahead!' approach to building reminds me of our late, great Larry Hawkins. I think he would have really, really enjoyed this build, it would have been right up his alley. Keep up the great work, we're all taking notes!!! Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted November 26, 2016 Author Share Posted November 26, 2016 Dan, your 'damn the torpedoes, full speed ahead!' approach to building reminds me of our late, great Larry Hawkins. I think he would have really, really enjoyed this build, it would have been right up his alley. Keep up the great work, we're all taki ng notes!!! Thanks Lee. I love this kind of modeling, really gets the juices flowing. I have quite a few 50's jets that I would like to build that will never be kitted. If I can pull this off and have a reasonable result I will move onwards and upwards. Dan Rainer Hoffmann 1 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted November 28, 2016 Share Posted November 28, 2016 Thanks Lee. I love this kind of modeling, really gets the juices flowing. I have quite a few 50's jets that I would like to build that will never be kitted. If I can pull this off and have a reasonable result I will move onwards and upwards. Dan That's the spirit, Dan. Great work so far. Scratch building is very rewarding as you create something from just some raw materials. And your speed is mind blowing... If I were only half as quick my Viggen would almost be finished by now. Cheers Rainer Link to comment Share on other sites More sharing options...
