109 Posted January 7, 2017 Author Share Posted January 7, 2017 (edited) Good evening good sirs! Some progress on my Dora-9: Side panels: First I make a template from .13 mm sheet styrene: I transfered the template to lithoplate and cut it to shape: I added a paper template for the rivet pattern around the jackup pipe.Also added the frames and stringers with a pencil: Edited January 7, 2017 by 109 sandokan, tucohoward, Lars Befring and 6 others 9 Link to comment Share on other sites More sharing options...
Guest Posted January 7, 2017 Share Posted January 7, 2017 Dam this is good !! Love watching you guys skin a model.....Harv Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 7, 2017 Share Posted January 7, 2017 Incredible. Kev 109 1 Link to comment Share on other sites More sharing options...
109 Posted January 14, 2017 Author Share Posted January 14, 2017 Hi, I riveted and glued the side panels in place. They still need some fine tuning: Does anyone know what this hatch (yellow circle) is? I cannot see it in photos of the real thing ...?! Any help is appreciated! :-) sandokan, Derek B, TorbenD and 7 others 10 Link to comment Share on other sites More sharing options...
109 Posted January 16, 2017 Author Share Posted January 16, 2017 Hallo I did some research on the rectangular hatch, it seems that it is limited to the D-13 variant only as I couldn't find a authentic photo of a D-9 with that hatch. HTH. sandokan and D.B. Andrus 2 Link to comment Share on other sites More sharing options...
TorbenD Posted January 16, 2017 Share Posted January 16, 2017 Simply stunning so far - I'm luvin' it Torben 109 1 Link to comment Share on other sites More sharing options...
109 Posted January 21, 2017 Author Share Posted January 21, 2017 Good evening, I started the large panel on the port side of the fuselage. I cut a template from sheet styrene for the front panelwith the prominent, large hatch. The outline of the template were transfered to lithoplate. The hatch was then cut with a saw and then file to exact dimensions using echappement file.While cutting I backed the sheet metal with a MDF plate to stabilize it while handling. fab, CODY, sandokan and 7 others 10 Link to comment Share on other sites More sharing options...
109 Posted February 11, 2017 Author Share Posted February 11, 2017 Hi, too little time for scale modeling ... :-( I tried to research some rivet patterns, they seem to differ somewhat when it comes to the details. I also settled to a method of transfering the patterns onto the lithoplate: Making a template from sheet styrene Cutting the lithoplate panel. Scanning the panel. Drawing the rivet pattern. Printing the pattern on semi transparent paper. Embossing the rivet pattern. Doctorgaz, Starfighter, Greg W and 7 others 10 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted February 11, 2017 Share Posted February 11, 2017 Fantastic! Just fantastic!!! 109 1 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted February 11, 2017 Share Posted February 11, 2017 Hi, too little time for scale modeling ... :-( I tried to research some rivet patterns, they seem to differ somewhat when it comes to the details. I also settled to a method of transfering the patterns onto the lithoplate: Making a template from sheet styrene Cutting the lithoplate panel. Scanning the panel. Drawing the rivet pattern. Printing the pattern on semi transparent paper. Embossing the rivet pattern. Copy that! Great idea to get the rivet pattern right. I'll try that myself, one day. Cheers Rainer 109 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 11, 2017 Share Posted February 11, 2017 Nice work. Natural oil canning. I like that. A nice tight line. Now I know. Sincerely, Mark BiggTim and 109 2 Link to comment Share on other sites More sharing options...
airscale Posted February 11, 2017 Share Posted February 11, 2017 absolutely brilliant! so neat and tidy that is a really clever way of getting the rivet pattern, I will have to try it superb work Peter 109 and Derek B 2 Link to comment Share on other sites More sharing options...
109 Posted February 18, 2017 Author Share Posted February 18, 2017 Some progress on my Dora ... Dry fitting of the panel after embossing the rivets. I also masked off the hatch area to prevent glue residues in this area: Panel glued in place: Mid fuselage section starting to look like an mid fuselage section :-) Doctorgaz, KiwiZac, Greg W and 3 others 6 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 18, 2017 Share Posted February 18, 2017 Nice patterning. Sincerely, Mark 109 1 Link to comment Share on other sites More sharing options...
109 Posted February 21, 2017 Author Share Posted February 21, 2017 Good evening good Sirs! I started the hatch, I cut it from lithoplate and made it to fit the panel. Next I scribend the out line of the fasteners. I also made the piano hinge from tubing (Albion alloys). Next will be the rivet pattern ... Good night :-) Doctorgaz, fab, Lars Befring and 5 others 8 Link to comment Share on other sites More sharing options...
