ClumsyDude Posted March 16, 2017 Share Posted March 16, 2017 Holy moly Bernd ... that is just phenomenal work. Can't wait to see you come to grips with the cockpit. Jim 109 1 Link to comment Share on other sites More sharing options...
Radders Posted March 17, 2017 Share Posted March 17, 2017 That jig is better than my models and there are no words from me about the Fw-190, just amazing that's all!! 109 1 Link to comment Share on other sites More sharing options...
spacewolf Posted March 17, 2017 Share Posted March 17, 2017 Hi Bernd, nice to see you still doing your magic ! Stunning build and beautiful craftsmanship !! Just found and read through the thread... in awe of what you are doing !! Vaughn 109 1 Link to comment Share on other sites More sharing options...
Gerhard Posted March 17, 2017 Share Posted March 17, 2017 People of my skill level should be stopped from reading threads like this. Makes me want to give up altogether. This is just brilliant. Link to comment Share on other sites More sharing options...
109 Posted March 17, 2017 Author Share Posted March 17, 2017 (edited) Gerhard, no no, we all have our very own talents. So don't stop modeling! ! ☺ Edited March 17, 2017 by 109 Gerhard and KiwiZac 2 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted March 17, 2017 Share Posted March 17, 2017 Incredibly nice metal work, Bernd. That looks absolutely top notch. Cheers Rainer 109 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted March 17, 2017 Share Posted March 17, 2017 'process of shaping the dimensions of a panel change' Curve vs flat. Always a problem. Love what you're doing. 109 1 Link to comment Share on other sites More sharing options...
Gerhard Posted March 17, 2017 Share Posted March 17, 2017 Gerhard, no no, we all have our very own talents. So don't stop modeling! ! ☺ Not on my life. Was said very tongue in cheek. Link to comment Share on other sites More sharing options...
airscale Posted March 17, 2017 Share Posted March 17, 2017 Dry fitted the panel and added all the details just to find out that during the process of shaping the dimensions of a panel change so it won´t fit any more. astonishing job Bernd - really clean and surgical work & very enjoyable to watch for curved panels fitting between panels like this, I use 2 inch masking tape (for households) which can be burnished into the panel shape and the lines from the adjacent panels burnished with a cocktail stick - then go round with a pencil, peel it off and put it on your litho - cut it out and when you bend & shape it, it will be an exact fit loving what you are doing.. Peter Derek B and 109 2 Link to comment Share on other sites More sharing options...
109 Posted March 17, 2017 Author Share Posted March 17, 2017 (edited) Hi Peter, Thanks for the hint. I will give it a try! :-) Edited March 17, 2017 by 109 Link to comment Share on other sites More sharing options...
109 Posted March 18, 2017 Author Share Posted March 18, 2017 Hi, working on another panel on the fuselage bottom. This one includes a large oval hatch for fitting and removing the barrel shaped fuel tank behind the cockpit. Panel cut to shape, acutally ~ 0.2 mm larger for final fitting. Rivet lines and oval hatch marked with pencil lines. I apply a coat of flat clear lacquer to get the pencil some grip to adhere to the smooth lithoplate. That´s it for tonight! :-) Derek B, Doctorgaz, Greg W and 1 other 4 Link to comment Share on other sites More sharing options...
109 Posted March 19, 2017 Author Share Posted March 19, 2017 Hi, back to work ... I backed the panel with a 2mm MDF for cutting the hatch and the port using a jewelier´s saw and files: I changed the outline of the large hatch, so it´s lateral edges are now parallel to the edges of the panel. I found one good picture of an A-8 belly :-) Have a nice sunday! sandokan, Doctorgaz, Derek B and 3 others 6 Link to comment Share on other sites More sharing options...
ClumsyDude Posted March 19, 2017 Share Posted March 19, 2017 Wow, Bernd, that's looking most professional. Inspirational stuff. Jim 109 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 19, 2017 Share Posted March 19, 2017 Wow, Bernd, that's looking most professional. Inspirational stuff. Jim Agreed. Kev 109 1 Link to comment Share on other sites More sharing options...
109 Posted March 25, 2017 Author Share Posted March 25, 2017 (edited) Hi, some more work on the belly .... Dry fitting of the panel: I cut the hatch from litho and made a rivet template from transparent paper. Dry fitting of the hatch: Have a nice saturday! :-) Edited March 25, 2017 by 109 Greg W, MikeMaben, Anthony in NZ and 8 others 11 Link to comment Share on other sites More sharing options...
