sandbagger Posted July 3, 2024 Posted July 3, 2024 Hi all As the build of the Bristol Scout 1264 will be completed soon, I've started on the next build This will be the Albatros D.V, Serial No: D.2006/17 as flown by Ltn.der.Reserve Bernhard Kilian of Jasta 21b during September 1917 This is a 'Wingnut Wings' model kit Little information is recorded for Ltn.der.Reserve Bernhard Kilian, other than he was born in Neideburg in 1894 He served with Jasta 21 until his death in a flying accident at Pauvres airfield in December 1917 He was not reported to have been awarded any combat victories Mike scvrobeson, John1, TankBuster and 11 others 14
MikeMaben Posted July 4, 2024 Posted July 4, 2024 I have this kit and so will be watching Have fun Mike,
sandbagger Posted July 31, 2024 Author Posted July 31, 2024 Hi all, Now I've finished the Bristol Scout and Macchi M.5 builds for others, I can get back my modelling. So I'll now be progressing the Albatros D.V build, Mike MikeMaben and LSP_Kevin 2
europapete Posted July 31, 2024 Posted July 31, 2024 (edited) Nice topic Mike, looks like there are some extra gadgets on the outside of his cockpit. A mirror ??? or is it extra intruments with sunglare on the glass?? Quite a hefty framework though. Also a light frame with what looks like gunsights over the engine, just under the top wing Edited July 31, 2024 by europapete
sandbagger Posted July 31, 2024 Author Posted July 31, 2024 Hi all The forward sides of the fuselage halves have pre-molded circular access panels and cooling louvres The cooling louvres have no slots under them through the fuselage I've chosen to replace both with 3D printed parts from 'Proper Plane' ‘Proper Plane’ Albatros D.V/D.Va louvres (RD-011) ‘Proper Plane’ Albatros D.V/D.Va inspection hatches (RD-015) I've removed the pre-molded panels and louvres from the fuselage sides. I've also drilled cooling slots through the fuselage sides. These will have the louvres fitted over them I've also drilled slots in the lower, rear of the fuselage halves for the lower elevator control cables 'Wingnut Wings' issued correction sheets for the instruction manual These require the removal of pre-molded internal cockpit detail from the left fuselage half and removal of pre-molded straps from the lower, rear of both fuselage halves Mike Landrotten Highlander, Azgaron, Troy Molitor and 7 others 10
sandbagger Posted July 31, 2024 Author Posted July 31, 2024 (edited) 8 hours ago, europapete said: Nice topic Mike, looks like there are some extra gadgets on the outside of his cockpit. A mirror ??? or is it extra intruments with sunglare on the glass?? Quite a hefty framework though. Also a light frame with what looks like gun sights over the engine, just under the top wing Hi Pete, I think it's possibly a flare pistol, mounted on a vertical tube, such that the pilot can load a flare, lock then fire the pistol (directed away to the rear right of the aircraft). It looks like the breach is open, not closed and locked. Possibly a similar pistol to the Hebel M1894. Just forward of the pistol is a flare holder rack. As for the 'gun sight' - I found only one other photograph that seems to show this. I think you are right in that it's a centralized gun sight. My guess is that it was easier to aim (if guns ranged correctly) than leaning left or right to use the foresight of the Spandau's. Mike Edited July 31, 2024 by sandbagger TankBuster, Fanes, denders and 4 others 7
Biggles87 Posted August 1, 2024 Posted August 1, 2024 On 7/4/2024 at 10:18 AM, MikeMaben said: I have this kit and so will be watching Have fun Mike, Me too, I rarely build biplanes but the shape and minimal rigging attracted me to this one. John MikeMaben 1
sandbagger Posted August 3, 2024 Author Posted August 3, 2024 Hi all I've to paint the fuselage internal parts This includes creating wood and leather finishes The light colour wood finish is ‘Windsor & Newton’ Griffin Alkyd oil paint (Raw Sienna) applied by brush over 'Tamiya' Desert Yellow (XF59) base coat The dark colour wood finish is ‘Windsor & Newton’ Griffin Alkyd oil paint (Burnt Umber) applied by brush over 'Tamiya' Desert Yellow (XF59) base coat The leather finish on the pilots seat is ‘Ammo-Mig’ Oil brusher (Earth) and when semi-dry, stipple brushed ‘Ammo-Mig’ Oil brusher (Dark Brown) over 'Tamiya' Desert Yellow (XF59) base coat Mike LSP_Kevin, MikeMaben, themongoose and 11 others 14
sandbagger Posted August 7, 2024 Author Posted August 7, 2024 Hi all, The fuselage is now ready to be closed up. I've added the cockpit control cables for the rudder and elevator (ailerons will come later) Also pipe/tubes from the water pump greaser and the starter magneto The control rod from the engine spark advance control lever can't be added until the fuselage is closed up, as it has to route around or through a cockpit frame The engine has ignition leads to the spark plugs but not from the magnetos Wiring those is a waste as they can't really be seen on the completed model Mike Shoggz, Paulpk, Pastor John and 15 others 17 1
Dpgsbody55 Posted August 8, 2024 Posted August 8, 2024 Looks great. I've got the D.Va kit in my stash so I'll be following this. Thanks for the details on how you paint wood. Very important on this plane. Cheers, Michael
Greif8 Posted August 8, 2024 Posted August 8, 2024 Great looking work as always Mike. I like the wood tones you selected and painted. Ernest
sandbagger Posted August 10, 2024 Author Posted August 10, 2024 Hi all, The fuselage is now closed up. The kit supplied machine guns were replaced with the ‘Spandau’ 08/15 extended loading handle (14-32061) from 'Gaspatch'. These needed to be modified to allow them to locate correctly in the fuselage front/rear gun mounts, Mike Fanes, Sasha As, Landrotten Highlander and 5 others 8
