Fanes Posted March 9, 2020 Share Posted March 9, 2020 Nice progress - takning notes for my build! Link to comment Share on other sites More sharing options...
Wackyracer Posted March 9, 2020 Author Share Posted March 9, 2020 (edited) Primed and test fit Scratch built the storage rack for the extra oxygen bottles and stratched 2 more from sprue and plasticard. Beige one is from a hasegawa kit. Revell ones are only 75% round and hollow. Will add the tubes once installed and painted. Edited March 9, 2020 by Wackyracer Elger, Kagemusha, Landrotten Highlander and 7 others 10 Link to comment Share on other sites More sharing options...
Wackyracer Posted April 18, 2020 Author Share Posted April 18, 2020 Apology's for the lack of updates, as with the majority of us I've been in lockdown since 27th March. During this time been working on an "isolated GB" on another forum. Anyway, back to the PR Spit. After some time toing and froing with the pilot decided to go without and dug out a Barracuda seat for this build. The pilot was going to hide quite a bit of the extra work I'd put into the pit so in some ways defeated the object of all the work. I'm also still awaiting the PE parts from Alley Cat for marking the camera bay positions. Somewhat frustrating to say the least as I have all the resin bits just no PE, despite several emails. I will probably have to 'freestyle' the camera bays on this one, otherwise it will never be done. Added some washes to dirty it up a bit and now about to dig out some belts and install the oxygen bottles on the rear shelf. Aaron Landrotten Highlander, dodgem37, nmayhew and 6 others 9 Link to comment Share on other sites More sharing options...
Subodai Posted April 18, 2020 Share Posted April 18, 2020 Does the paint have that pattern in the surface of it? or is that some function/result of some kind of noise filter or effect added to the photo? If the former.. how did you acheive that? Link to comment Share on other sites More sharing options...
Wackyracer Posted April 18, 2020 Author Share Posted April 18, 2020 2 minutes ago, Subodai said: Does the paint have that pattern in the surface of it? or is that some function/result of some kind of noise filter or effect added to the photo? If the former.. how did you acheive that? I think its just the light source and camera when zoomed in. this is taken without zoom. The pieces are resin and the tiny surface detail gets magnified when you crop in with a phone camera. Also the resolution gets reduced (enhancing the patterns) when going from phone to server to forum etc. Derek B, Landrotten Highlander, MikeMaben and 1 other 4 Link to comment Share on other sites More sharing options...
Wackyracer Posted April 18, 2020 Author Share Posted April 18, 2020 it also needs a flat coat. Mr Paints are quite glossy so ideal for decals straight on top. i'll matt it down later and post some more pics. Link to comment Share on other sites More sharing options...
Scale32 Posted April 18, 2020 Share Posted April 18, 2020 Looking real nice Aaron. Cheers Bevan Wackyracer 1 Link to comment Share on other sites More sharing options...
Fanes Posted April 18, 2020 Share Posted April 18, 2020 Nice to see progress on your recon Spit! 8 hours ago, Wackyracer said: I'm also still awaiting the PE parts from Alley Cat for marking the camera bay positions. Somewhat frustrating to say the least as I have all the resin bits just no PE, despite several emails. I have an Alley Cat PR conversion with the PE parts in my stash - I could scan them and/or draw vector graphics for cutting templates with a Silhouette. Cheers Joachim Lothar 1 Link to comment Share on other sites More sharing options...
James Rademaker Posted April 18, 2020 Share Posted April 18, 2020 Beautiful job, Excellent detail work and painting on the cockpit. Looking forward to your finish. Jim Wackyracer 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted April 19, 2020 Share Posted April 19, 2020 Wackyracer 1 Link to comment Share on other sites More sharing options...
Wackyracer Posted April 19, 2020 Author Share Posted April 19, 2020 Starting to motor now... Belts and seat installed along with retaining wires. Just added a bit of sprue towards the rear end then wrapped the wires around. Hardly visible now buttoned up but just a little detail. Also added the 3 oxygen bottles to the scratched rack. Buttoned up the fuselage last night. Couple of mm of wire! Pit looks good to my mind Wings are a almost perfect drop fit! Soon be time for paint! Aaron Landrotten Highlander, VW Chris 1969, turbo and 7 others 10 Link to comment Share on other sites More sharing options...
MikeMaben Posted April 20, 2020 Share Posted April 20, 2020 20 hours ago, Wackyracer said: Pit looks good to my mind Definitely Link to comment Share on other sites More sharing options...
Wackyracer Posted April 21, 2020 Author Share Posted April 21, 2020 Wings attached, bottom camera bays drilled and fitted and front chin installed. williamj, Landrotten Highlander, VW Chris 1969 and 4 others 7 Link to comment Share on other sites More sharing options...
Wackyracer Posted April 23, 2020 Author Share Posted April 23, 2020 TBH I've been avoiding this part where ever possible... Vac canopy! Having never dealt with one before its been a daunting task. Plus when the canopy doesn't even fit that's added stress. Anyway, after much toing and froing I elected to go with the majority of the MK.II front frame to give the vac piece a structure and hopefully pull it into place. First stage was removing the existing glazing, which was again a scary process. Drilling around the frame... Test fit to the fuselage. I then glued the vac piece to the framework with tiny drops of CA. it was the only way I could get the vac piece to conform to the framework. I still need to find a method to fill in the missing front section of the original frame (where the bullet proof frame fitted) but looking at as many pics of these clear frames I've added a thin strip of wire around the fuselage and will attempt to plasticard/pe or filler the framework into place. You can hopefully just make out the wire and will use the vac frame for the top section. LSP_Kevin, VW Chris 1969, Landrotten Highlander and 5 others 8 Link to comment Share on other sites More sharing options...
Wackyracer Posted April 29, 2020 Author Share Posted April 29, 2020 Ready for paint, got the front canopy faired in with milliput, added the tail wheel setup and done some more sanding, filling and rescribing on troublesome spots. jgrease, LSP_Kevin, Beaconroot and 3 others 6 Link to comment Share on other sites More sharing options...
