Marcel111 2,706 Posted July 15, 2020 Share Posted July 15, 2020 My 2000C somehow got lost in the mail, very strange because the tracking shows it to have been delivered. Does anybody know what’s up with production of the kit, seems like it is hardly available right now? Cheers, Marcel Link to post Share on other sites
Finn 2,229 Posted July 23, 2020 Share Posted July 23, 2020 For your viewing pleasure: Jari Isar 30/07, jgrease, Out2gtcha and 5 others 7 1 Link to post Share on other sites
Kagemusha 9,591 Posted August 12, 2020 Share Posted August 12, 2020 [FFSMC Productions] 1/32 scale 1700 L tanks RPL 501/502 for Foreign Mirage 2000, unlike the KASL version, they are hollow. The KASL corrected nose is available here, I think I read it is a limited release... L'Arsenal have a few related items. Out2gtcha 1 Link to post Share on other sites
Out2gtcha 36,393 Posted August 13, 2020 Share Posted August 13, 2020 Nice! All we need now are some intakes....... Link to post Share on other sites
mydesign 334 Posted August 13, 2020 Share Posted August 13, 2020 (edited) that's a very expensive KASL nose correction.... with postage over USD 50,==== I will do some repairs myself.... Edited August 13, 2020 by mydesign Daniel Leduc and thierry laurent 2 Link to post Share on other sites
jenshb 868 Posted August 13, 2020 Share Posted August 13, 2020 Pardon my ignorance, but what is wrong with the fuel tanks and 2000-5 nose in the kit? Link to post Share on other sites
discus 804 Posted August 13, 2020 Share Posted August 13, 2020 16 hours ago, Out2gtcha said: Nice! All we need now are some intakes....... We also need the correct IP for the -5, the D and the N Daniel Leduc and Out2gtcha 2 Link to post Share on other sites
Dave Williams 3,842 Posted August 13, 2020 Share Posted August 13, 2020 8 hours ago, jenshb said: Pardon my ignorance, but what is wrong with the fuel tanks and 2000-5 nose in the kit? Not sure about the tanks, but there are a couple of errors in the kit nose. First, the -5 nose should be pointed as it doesn’t have the nose pitot tube like the standard C nose. Also, the radome break point isn’t correct for the single seater 2000 (any version). When the radome comes off, the section of the nose in front of the windscreen also comes off with it, so when removed you also have access to the electronics behind the radar dish. KH made the radome like most where the break is at the bulkhead the antenna is on, so when removed, you just see the antenna. Out2gtcha 1 Link to post Share on other sites
Dave Williams 3,842 Posted August 13, 2020 Share Posted August 13, 2020 37 minutes ago, discus said: We also need the correct IP for the -5, the D and the N This. I’d say we need new IPs more than new intakes. Out2gtcha 1 Link to post Share on other sites
Kagemusha 9,591 Posted August 13, 2020 Share Posted August 13, 2020 10 hours ago, jenshb said: Pardon my ignorance, but what is wrong with the fuel tanks and 2000-5 nose in the kit? The 1700 L tanks aren't included with either kits, thought it's not used on the D/N, but if you wanted to do any other two-seater so equipped. Link to post Share on other sites
Out2gtcha 36,393 Posted August 14, 2020 Share Posted August 14, 2020 7 hours ago, discus said: We also need the correct IP for the -5, the D and the N 6 hours ago, Dave Williams said: This. I’d say we need new IPs more than new intakes. I guess it all comes down to what is important to the individual modeler. Since there really aren't any intakes at all, it makes it my top priority. I've got the two very nice D/N pilots and plan on having the canopies likely closed. For me personally, being no SME on the2K, I wouldn't know the difference in IPs to save my soul. Likely I'll be entering it at some point in an IPMS event, and usually the judges dont know the difference either. However having judged IPMS aircraft catagories prior, we almost always took the torches down the intakes when it came time to split between two equally nice models. Lothar, LSP_K2, Kagemusha and 1 other 4 Link to post Share on other sites
jenshb 868 Posted August 14, 2020 Share Posted August 14, 2020 Thank you for the replies gents. No 1700l tanks in the kit - aftermarket to the rescue. The missing 2000-5 IP - isn't Renessaince working on a complete cockpit that will include the -5 IP, so that should be a matter of time. Missing intake trunks - agree, that would be nice. It appears from other builders that the shock cones are helping to make that omission less visible than anticipated. Now the nose cone. Yes, the -5 has a very pointy nose cone, so a piece of brass rod superglued and filed to a sharp tip should fix that. Are there any other shape issues with the nose cone? From what has been said above, it seems that the wring breakpoint for the nose cone will only matter if you plan to display the radar or leafe it removeable. Gluing it in place should make the problem a non-issue? Link to post Share on other sites
blackbetty 5,174 Posted August 14, 2020 Share Posted August 14, 2020 would the 1700l tanks of the revell/italeri mirage fit? Link to post Share on other sites
Etienne 225 Posted August 15, 2020 Share Posted August 15, 2020 Hi All, RPL 522 tank is not a good sizes. A relative of mine designed a new tank, that Renaissance/Rflight will produce. I'm now completing IP for a -5, and if enough courage, will do for a C and D/N. ROM, Kagemusha, Isar 30/07 and 1 other 4 Link to post Share on other sites
Vulcan 29 Posted August 15, 2020 Share Posted August 15, 2020 Hi all, Is the KASL nose needed to build a correct D version or is it unique to the 5Ei/Di? Thanks Link to post Share on other sites
