shark64 Posted October 3, 2016 Share Posted October 3, 2016 sweet. Link to comment Share on other sites More sharing options...
ericg Posted October 7, 2016 Author Share Posted October 7, 2016 The time came to install the cockpit. I have a few more details to add such as the radar controller and some minor placards. DesTROYer, mpk, Derek B and 8 others 11 Link to comment Share on other sites More sharing options...
Simmo.b Posted October 7, 2016 Share Posted October 7, 2016 Miniaturised one of your 1 to 1 stick grips I see!! Piprm, mpk and DesTROYer 3 Link to comment Share on other sites More sharing options...
LSP_Ray Posted October 7, 2016 Share Posted October 7, 2016 Nice! mpk 1 Link to comment Share on other sites More sharing options...
shark64 Posted October 9, 2016 Share Posted October 9, 2016 Look at that cockpit..real mice mpk 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted October 9, 2016 Share Posted October 9, 2016 Always fantastic to follow your builds Eric. It's always the tiny little details that set them apart. Matt mpk and Piprm 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 9, 2016 Share Posted October 9, 2016 Eric Beautiful work on the front office Keep 'coming Peter Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted October 9, 2016 Share Posted October 9, 2016 Great cockpit Eric! mpk 1 Link to comment Share on other sites More sharing options...
TTail Posted October 10, 2016 Share Posted October 10, 2016 Looking good ! mpk 1 Link to comment Share on other sites More sharing options...
X15 Posted October 10, 2016 Share Posted October 10, 2016 Fantastic as always !! X15 mpk 1 Link to comment Share on other sites More sharing options...
Brick Posted October 25, 2016 Share Posted October 25, 2016 It's like watching Michelangelo modifying the overall shape of a block of marble. That cockpit should be hung in the National Gallery, Eric. Piprm and mpk 2 Link to comment Share on other sites More sharing options...
amurray Posted October 27, 2016 Share Posted October 27, 2016 Excellent work! Link to comment Share on other sites More sharing options...
ericg Posted December 6, 2016 Author Share Posted December 6, 2016 So with The Super Hornet finally finished, it was back to work on the Mirage. The poor fit of the nose is a well known issue with the kit. It is a little too large and requires some work to fix it. First up, I glued the pitot tube onto the tip of the nose cone and then cut it off and blended the remaining part. I drew a circle onto some paper that was the approx size of the base of the nose cone and trued it up to be a proper circle. I then shimmed the mating area of the front of the fuselage and sanded it flat. After adding some nose weight I glued the parts together. As can be seen, the fuselage area where the parts meet will have to be blended. At least the nose cone is a true circle The nav lights were then glued into place using superglue And then sanded flush with the wing before being buffed. I wanted to have the two small doors under the fuselage open. These had a small handle that was pulled down for the pilot before flight, which I think were to alert the pilot as to whether the windscreen washing fluid had been topped up and the catering stores replenished. Once the panel was scribed with a pin, I then opened it up by chain drilling it and then filing it to shape. I have mocked up one of the handles with some brass tube. I will make up the small doors later on. The1971Show, Hubert Boillot, F`s are my favs and 7 others 10 Link to comment Share on other sites More sharing options...
Simmo.b Posted December 6, 2016 Share Posted December 6, 2016 Good to see this back on the bench Link to comment Share on other sites More sharing options...
Nillus Posted December 6, 2016 Share Posted December 6, 2016 Outstanding attention to detail as usual. Link to comment Share on other sites More sharing options...
