LSP_Kevin Posted February 26, 2017 Share Posted February 26, 2017 It's almost a shame to see all that fine work covered in primer! Still looks fantastic, though. Kev ClumsyDude, airscale and Jeff 3 Link to comment Share on other sites More sharing options...
ClumsyDude Posted February 27, 2017 Share Posted February 27, 2017 It's almost a shame to see all that fine work covered in primer! Still looks fantastic, though. Kev I'm with Kev on that ... mixed feelings about it, there's something awe inspiring about the mixed media precision. Gotta be done though, and awesome work as always. Cheers Jim airscale and Jeff 2 Link to comment Share on other sites More sharing options...
DonH Posted February 27, 2017 Share Posted February 27, 2017 Stellar werk soos gewoonlik! Take another look at the electrical gizmo cylinders. Have you missed a couple of bolt heads on the end caps? Details may have changed from the mkV to the Mk XIV, so I am not sure. airscale 1 Link to comment Share on other sites More sharing options...
Tony C Posted February 27, 2017 Share Posted February 27, 2017 You'll be telling us next, that the throttle quadrant works... Jeff and airscale 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 27, 2017 Share Posted February 27, 2017 Peter I need to come up for air. Awesome work but the word propeller engraved on the throttle .. what a touch! Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Guest Posted February 27, 2017 Share Posted February 27, 2017 "propeller" on the lever ? Really? who are you and where do you come from? Also mixed fellings about painting.....Harv Link to comment Share on other sites More sharing options...
Cees Broere Posted February 27, 2017 Share Posted February 27, 2017 I am glad you are painting all those parts Peter, the end result will look like a fully authentic Spitfire cockpit albeit in miniature rather than an unfinished one. 109 and airscale 2 Link to comment Share on other sites More sharing options...
Squizzy 78 Posted February 27, 2017 Share Posted February 27, 2017 One thing the primer does do, and that is that it confirms what we all already knew. That everything we see is a flawless finish, it's looking amazing! Jeff and airscale 2 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 27, 2017 Share Posted February 27, 2017 Alas, it's time to cover it with paint. 'I will have to seek another supplier' You may find something here: https://www.mediamixhobby.com.sg/shop/materials/bolts-and-nuts https://www.mediamixhobby.com.sg/shop/materials/rivets http://www.hiroboy.com/Rivets_Nuts_Connectors_etc_--category--149.html http://www.prime-miniatures.co.uk/ Sincerely, Mark airscale and Hubert Boillot 2 Link to comment Share on other sites More sharing options...
airscale Posted February 28, 2017 Author Share Posted February 28, 2017 good day ladies Stellar werk soos gewoonlik! Take another look at the electrical gizmo cylinders. Have you missed a couple of bolt heads on the end caps? Details may have changed from the mkV to the Mk XIV, so I am not sure. probably did yes, now I have dry fitted it you can barely see it so I am going tonleave as is - in fact I just dropped it so it is in a few bits at the moment You'll be telling us next, that the throttle quadrant works... well, the levers do move if thats any good Alas, it's time to cover it with paint. 'I will have to seek another supplier' You may find something here: https://www.mediamixhobby.com.sg/shop/materials/bolts-and-nuts https://www.mediamixhobby.com.sg/shop/materials/rivets http://www.hiroboy.com/Rivets_Nuts_Connectors_etc_--category--149.html http://www.prime-miniatures.co.uk/ Sincerely, Mark brilliant - thanks Mark, I will look to get some more, they are sooo useful.. ..not much to show apart from painting - I have done most of the bits I have made.. it all looks a bit sterile at the moment as I am trying to work out how best to approach moving forward - I could install, and weather what I have and then start trying to plumb in all the wiring (and there is a lot of it) but risk glue marks etc, or just finish assembly with all the plumbing and weather it as one.... I also need to decide which side to install the panel and seat bulkheads into as plumbing that side will be easier as I have access, once both sides are added so it becomes a pod like this things will become very tricky... the plan is once at this stage I can add one further 'wall' which will be the bottom surface and that will carry the rudder pedals and control column .. need to stop procrastinating and just get building... TTFNPeter Shaka HI, Lars Befring, KUROK and 9 others 12 Link to comment Share on other sites More sharing options...
109 Posted February 28, 2017 Share Posted February 28, 2017 Piece of art! ! Chapeau ☺ airscale 1 Link to comment Share on other sites More sharing options...
Cees Broere Posted February 28, 2017 Share Posted February 28, 2017 (edited) Peter, I would install the bits into the starboard side as that is usually in view, and any imperfections on the opposite part would be less noticable. Edited February 28, 2017 by Cees Broere airscale 1 Link to comment Share on other sites More sharing options...
SkyKing Posted February 28, 2017 Share Posted February 28, 2017 We're not worthy! (smacking forehead with piece of plywood). airscale 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted February 28, 2017 Share Posted February 28, 2017 (edited) Superlative :excellent, magnificent, wonderful, marvelous, supreme, consummate, outstanding, remarkable, fine, choice, first-rate, first-class, premier, prime, unsurpassed, unequaled, unparalleled, unrivaled, preeminent; ace, wicked, brilliant We're all running out of words Peter, so stop it! Chuck Edited March 1, 2017 by chuck540z3 airscale, 109 and Shaka HI 3 Link to comment Share on other sites More sharing options...
zaxos345 Posted February 28, 2017 Share Posted February 28, 2017 Peter.....i am totally with Chuck!!!!!!!!!!!!!!!!!!!!!!!!!!! John airscale 1 Link to comment Share on other sites More sharing options...
