Guest Peterpools Posted February 19, 2016 Share Posted February 19, 2016 Eric Aces on the decal work .. never a doubt they would be flawless Keep 'em coming Peter Link to comment Share on other sites More sharing options...
misha71 Posted February 19, 2016 Share Posted February 19, 2016 what a beauty great paint Link to comment Share on other sites More sharing options...
Piprm Posted February 20, 2016 Share Posted February 20, 2016 (edited) Eric, ...are you sure you haven't got a small - mini factory production-line going on here, with very small slave Pixies - doing all your models, in these vast quantities (working 24 hours a day) as you have posted - here .... that we mere mortals - like us ...cannot do? Phil http://i194.photobucket.com/albums/z169/emmiedownunder/Fairies%20and%20Fantasy/Fairy-Bike.gif Edited February 20, 2016 by Piprm Link to comment Share on other sites More sharing options...
MrPRRose Posted February 20, 2016 Share Posted February 20, 2016 Eric wow you certainly do know your clear coating biz! Looks fantastic! Could I bother you for your setup if you get the chance? Ie airbrush nozzle size, X-22 thin ratio etc Link to comment Share on other sites More sharing options...
ericg Posted February 20, 2016 Author Share Posted February 20, 2016 Eric wow you certainly do know your clear coating biz! Looks fantastic! Could I bother you for your setup if you get the chance? Ie airbrush nozzle size, X-22 thin ratio etc No worries, Iwata TRN1 airbrush, X-22 in a 50:50 mix ratio with Tamiya Acrylic Thinner, sprayed at 20Psi. Eric. Link to comment Share on other sites More sharing options...
MrPRRose Posted February 20, 2016 Share Posted February 20, 2016 Thanks Eric! I'm a big fan of trigger-type airbrushes, I run a Tamiya HG trigger type 0.3mm and their 0.5mm, another rather different gun I have is the Mr Hobby Procon Boy trigger type that has a flat fan type spray pattern - great for motorcycle bodies or primer. Your Hornet is looking 'the business'..inspired! Link to comment Share on other sites More sharing options...
ericg Posted February 24, 2016 Author Share Posted February 24, 2016 (edited) Eric, ...are you sure you haven't got a small - mini factory production-line going on here, with very small slave Pixies - doing all your models, in these vast quantities (working 24 hours a day) as you have posted - here .... that we mere mortals - like us ...cannot do? Phil http://i194.photobucket.com/albums/z169/emmiedownunder/Fairies%20and%20Fantasy/Fairy-Bike.gif Arghhhh! my secret is out! Some more build. Before I painted the model, I noticed a small issue with the pylons, easy enough to fix but I wonder how this stuff gets through the people that test build these kits! See here: and here: They are the same measurement..... Now see here? The pylons come off 2 sprues that are the exactly the same, meaning that they are exactly the same when put together. This will result in an assymetric position of each of the outboard pylons. I scrubbed off one of the aligning pegs and replaced it with plastic card. Another test fit of the pylons and stuff hanging from them. I will spend some time getting this part of the build as good as I can as the loadout will really set the model off. Here is another look at the cross hatching pattern of the tanks. It is just there, just like the real deal. Also noticeable in this pic is the small data plate that I sourced from an Airscale sheet on the area next to the leading edge flap. Super observant readers will notice that I have gone back and changed a part of the markings on the model, involving ripping the original decal off the model with masking tape, filling and relocating a couple of panel lines and respraying, resealing and then splicing a couple of decals together to re-do an area that I wasn't happy with. This area may or may not have been pointed out to me by a third party via PM. I was almost about to leave it alone but when I got the PM, I made the decision to go back and re-do it. Edited February 24, 2016 by ericg Uilleann, Starfighter, Dragon and 4 others 7 Link to comment Share on other sites More sharing options...
AnthonyWan Posted February 24, 2016 Share Posted February 24, 2016 Looks awesome Eric!! I am gonna try that crosshatch on my fuel tanks too May I ask which Airscale sheet that data plate came from? -Anthony Hans 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 24, 2016 Share Posted February 24, 2016 Eric beautiful work and nice fix regarding the pylon issue. Completely agree that someone should have discovered the problem before the kit was sent out the door. It seems quite obvious that the original design was for two completely different parts to be used but someone along the way decided it was a great money saver just to include the same fret twice, even though the pylon would be wrong. If using the same fret twice, with the same pylon, then the locating strip would have been in the center or the slot in the wing moved slightly. Sure seems as if the 'Bean Counters were at work gain" Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Jeff T Posted February 25, 2016 Share Posted February 25, 2016 (edited) Good catch Eric!.... I must admit, I had to look at the pics a couple of times before I worked out what was wrong, so I dont think I would have caught it until it was too late. Cheer's, Jeff. Edited February 25, 2016 by JT68 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 25, 2016 Share Posted February 25, 2016 Excellent work, Eric! Good catch Eric!.... I must admit, I had to look at the pics a couple of times before I worked out what was wrong, so I dont think I would have caught it until it was too late. Yeah, me too. Kev Link to comment Share on other sites More sharing options...
scvrobeson Posted February 25, 2016 Share Posted February 25, 2016 Really nice Low-vis scheme on it. The weathering looks pretty accurate compared to your reference shots Matt Link to comment Share on other sites More sharing options...
ericg Posted May 20, 2016 Author Share Posted May 20, 2016 So.... After I finish a model (the latest being the Sabre), I find myself looking over the ones I have started, have a tinker with one or two and then remember the issues that I have had with them in the past causing me to put them down in the first place then start something new as a way of punishing myself for not carrying on with an old build like I damn well should. This one is no exception, although to be fair to myself, a large scale jet is alot of work and requires alot of commitment in the first place notwithstanding the fact that this is a Trumpeter large scale jet so the difficulty factor is increased significantly. I was just about to go full noise on the Revell Beaufighter but common sense prevailed. I will sometimes go back to the build that I am most guilty about casting aside, so here goes. I lost the clear landing light that Trumpeter provide and required no twisting of my arm to get behind my lathe and machine one up! Uilleann, Zero77 and Whitey 3 Link to comment Share on other sites More sharing options...
ericg Posted May 20, 2016 Author Share Posted May 20, 2016 Another area of the build that I wasn't happy with was the refuelling probe bay. The kit bay was far too shallow and required me cutting it out and making a new bay that gave it depth. I still wasn't happy with the lack of detail in it and was about to leave it until I thought I would chuck some `gizmology', just to busy it up a bit. I simply couldn't find any good pics out there, so come up with a few details. I just need to attach the final rod that connects the red arm to the probe itself and then it will be complete. Starfighter, Whitey and Zero77 3 Link to comment Share on other sites More sharing options...
F`s are my favs Posted May 20, 2016 Share Posted May 20, 2016 The overall color of the plane is awesome! I will check out the whole thread for sure... Link to comment Share on other sites More sharing options...
