ericg Posted July 25, 2015 Author Share Posted July 25, 2015 By the way Eric, you should think about casting the modified fuselage pylon - looking really good here! If I had some moulding silicone I probably would! Thanks for the comments guys. Will be doing lots of work to this one. Eric. Link to comment Share on other sites More sharing options...
blackbetty Posted July 27, 2015 Share Posted July 27, 2015 i modified my pylon too. what i experienced after painting upon assembly is that the pod sits very close to the main wheel, does yours? Link to comment Share on other sites More sharing options...
Starfighter Posted July 27, 2015 Share Posted July 27, 2015 If I had some moulding silicone I probably would! Thanks for the comments guys. Will be doing lots of work to this one. Eric. Eric, if you'd cast them, I'd certainly buy a set or two and I am pretty sure I'm not the only one! Link to comment Share on other sites More sharing options...
ericg Posted July 28, 2015 Author Share Posted July 28, 2015 Will see what I can do. Onto some more modifications. I honestly picked up this kit not expecting to have to do much to it, but practically every part that I pick up has to be checked against numerous photos to work out how I am going to have to modify it in order for it to look correct. Here is a really good example. The Aussie Supers are equipped with two Joint Helmet -Mounted cueing system sensors on the left hand side canopy frame, (one for each crew member.) Trumpeters designers would have the pilot having one sensor on either side as per below, which is very wrong, and the sensors look really bad anyway. Rather than do it properly, they have simply mirrored one of the sides. I took some time to scratch some new ones, mounted in the right locations this time. The kit undercarriage doors are a bit lacking in detail. In particular the nose gear door is missing the ADF sensor. Here is the new door, skinned with Eduard Photo etch plus some copper wiring. tucohoward, Uilleann, Anthony in NZ and 2 others 5 Link to comment Share on other sites More sharing options...
ClumsyDude Posted July 28, 2015 Share Posted July 28, 2015 Looking sharp Eric. Link to comment Share on other sites More sharing options...
Loic Posted July 29, 2015 Share Posted July 29, 2015 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 29, 2015 Share Posted July 29, 2015 Eric Terric work on the details - just amazing work. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Azgaron Posted July 29, 2015 Share Posted July 29, 2015 Nice work! Looks great! HÃ¥kan Link to comment Share on other sites More sharing options...
ericg Posted July 31, 2015 Author Share Posted July 31, 2015 Another aspect of the kit that has come under close scrutiny is the undercarriage. I seem to be doing lots of work correcting this part of kits lately and this one is no different. In fact, some of the stuff that Trumpeter have thrown at this one is pure fantasy. I am not sure how these things slip through the folks that sign off on these kits but if a moderatley skilled modeler from the back blocks of Brisbane can get them sorts right, you would think that the big guys would be able to, right? The main undercarriage is quite a noticeable feature of the Hornet jets and was one that I reckon needed to be done a bit better than what was out of the box. A fair bit of scratchbuilding has gone into getting the springs and various details onto the legs, and there is still lots more to come. Using an appropriately sized punch and copper wire various springs can be would to suit. Here is the part that inspired me to do the correction. The part on the right is the Trumpeter prod/spring assembly. Notice the lack of detail in the spring? More importantly, notice the bend in the part that should even be there? The entire read part of each main gear leg has required surgery to get everything to line up to allow my new straight rod/spring to fit. The J shaped rod at the front of the gear has also been modified, to look more rounded. ClumsyDude, blackbetty, tucohoward and 5 others 8 Link to comment Share on other sites More sharing options...
Azgaron Posted July 31, 2015 Share Posted July 31, 2015 Very nice work with the springs! HÃ¥kan Link to comment Share on other sites More sharing options...
ClumsyDude Posted July 31, 2015 Share Posted July 31, 2015 (edited) Eric, this is brilliant. Great work on the gear springs. I use guitar string to simulate springs, and I like them because the spring wiring is really tight, but not sure if they'd be straight enough for something like this. One day I'd like to tackle a Trumpy super hornet, so it's awesome to have this as an accuracy manual! Cheers Jim Edited July 31, 2015 by ClumsyDude Link to comment Share on other sites More sharing options...
Tanker459 Posted July 31, 2015 Share Posted July 31, 2015 Eric, Been watching now for a while and this is getting better and better with every bit of work you do on it After talking with you the other day I see what you mean about the undercarriage Keep up the excellent work Greg Link to comment Share on other sites More sharing options...
ericg Posted August 1, 2015 Author Share Posted August 1, 2015 Thanks guys. Jim, Guitar string would be good but I wanted the springs to be see through as if they were unloaded. Eric. Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2015 Share Posted August 1, 2015 Punch for springs....Briliant !.....Harv Link to comment Share on other sites More sharing options...
Youngtiger1 Posted August 1, 2015 Share Posted August 1, 2015 Just caught up with this thread and I'm glad to see you building it again. I just picked up this kit in a trade and need to see what all is in need of help. You sure are doing great work this beast. To bad, it didn't get the attention it deserved from the AM industry. Not like some other subjects. Oh well, your make up the difference with your scratch building skills Link to comment Share on other sites More sharing options...
