marauderdriver Posted March 1, 2017 Share Posted March 1, 2017 I need to find a wino to give the wine to, as I don't drink. I wonder what the charge is for peeling the foil off at the liquor store? If the pilot pull the trigger will he shoot out the front? This is definitely different! Model On Sir jack mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted March 1, 2017 Share Posted March 1, 2017 (edited) You can always buy pewter sheets in an Arts & Crafts store ...Real pewter foil have become very rare nowadays on wine bottles...France is not anymore what it used to be ( that just refers to wine bottles; don't believe a certain moron's declarations about Paris )Hubert Edited March 1, 2017 by MostlyRacers Alain Gadbois and mpk 2 Link to comment Share on other sites More sharing options...
mpk Posted March 1, 2017 Share Posted March 1, 2017 The words....they won't...come... Shaka HI, Lud13 and Alain Gadbois 3 Link to comment Share on other sites More sharing options...
Troy Molitor Posted March 5, 2017 Share Posted March 5, 2017 Lovely work going on here Alain. Love how this one is coming together for you. Well done! Troy Alain Gadbois and mpk 2 Link to comment Share on other sites More sharing options...
dodgem37 Posted March 5, 2017 Share Posted March 5, 2017 Good cockpit stuff. Sincerely, Mark mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted March 7, 2017 Author Share Posted March 7, 2017 Hi all! Thanks for the comments again, much appreciated! The left side of the cockpit has been glued in place, puttied, sanded and primed. You can note the gun access panel just in front of the wing... I started making the components that will go in the fuselage interior. Bits of wiring, electrical boxes and various items...I used fine wire from cables, thin lead solder, some sprue bits and resin bits that look the part. Similar stuff on the right side. Just test fitting, no glue. Most painting will be done before assembly. Also finally, tail parts and the scribed and riveted rudder, primed a while ago, but did not photograph until today. Bye for now! Alain MikeC, TorbenD, AndersN and 5 others 8 Link to comment Share on other sites More sharing options...
Guyman1 Posted March 7, 2017 Share Posted March 7, 2017 Hi Alain, This is such a cool piece of modelling I hate being repetitive but this is so interesting as it unfolds looking forward to the next stage. Guy mpk 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted March 7, 2017 Author Share Posted March 7, 2017 Hi Guy! Thanks! It is great fun making this project and sharing on LSP! Alain mpk, Shaka HI, Guyman1 and 1 other 4 Link to comment Share on other sites More sharing options...
alaninaustria Posted March 11, 2017 Share Posted March 11, 2017 I love coming back to this build! So unique!! Cheers Alan mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Iain Posted March 11, 2017 Share Posted March 11, 2017 Not normally into 'Luft '46' - but love this project - very different to the standard 262 (and a lot better looking IMHO). And thanks for sharing techniques - what the forums are all about - learning from each other. Iain mpk, Alain Gadbois and MikeC 3 Link to comment Share on other sites More sharing options...
wunwinglow Posted March 11, 2017 Share Posted March 11, 2017 Wow! Another one I missed!! Some great techniques on display here, definitely going to be 'learning' them! Its going to make a very impressive and interesting model when finished. Tim mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted March 13, 2017 Author Share Posted March 13, 2017 Thank you Alan, Lain and Tim! I am glad you enjoy the techniques, as I will try to show more during the build. I did more engraving work turning this time to the wings: Checking references, I found most scribed lines were accurate, so I just scribed over the raised detail, then sanded and primed both wing undersurfaces. I then drew lines where the rivets would go. Some rivet lines are double, so to help mark those I created a very simple template in thin styrene. I will keep it for the fuselage as most of those are also double. Here is the result. It is much simpler to do this before the wings are assembled! Now more on the internal details. I gave a thin coat of white Tamiya primer on the wires before painting then yellow. One tank was also painted silver (also Tamiya can, Silver leaf). Some of the bits in place with paint and weathering. I make a "dirty" mix I apply first. I scrape various colors of dry pastels then mix with water. More water will make the mix less dirty... In this case the silver finish meant I had to use more pastel pigment. To check that all the detail will fit I made new 2 fuel tanks. I used the drawing for height and length, and the volume given (some calculations done...) to deduct the width. Here is one, all sanded, in place. When the bottom section is added, even I was surprised on how little will be seen... Bye for now! Alain mpk, MikeC, AndersN and 6 others 9 Link to comment Share on other sites More sharing options...
dodgem37 Posted March 13, 2017 Share Posted March 13, 2017 Nice line work and detailing, for sure. Good photography to boot! Sincerely, Mark Alain Gadbois 1 Link to comment Share on other sites More sharing options...
Guyman1 Posted March 14, 2017 Share Posted March 14, 2017 Hi Alain, That plastic thing you have made to straighten the reverting is awesome something I might need to look into for my scratch build 1/24 Ki 61 Tony, great stuff mate this is one very unique model. Guy Alain Gadbois 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted March 14, 2017 Author Share Posted March 14, 2017 Hi all! Thanks Mark, thanks Guy, although I confess I'm not too certain about what plastic thing your talking about! Painted some other bits with the silver can: It's time to look into those Jumo engines, to move this part of the build along. I wanted to avoid the joint inside the exhaust so I cut off that section out of one half, glued together, filled in and sanded smooth. Once painted, I inserted the exhaust cone part and glued in place. The result: So far so good... Bye for now, Alain Shaka HI, MikeMaben, TorbenD and 4 others 7 Link to comment Share on other sites More sharing options...
