BloorwestSiR Posted January 1, 2018 Share Posted January 1, 2018 That's some fantastic progress Jan. It looks like everything is going together really well so far. Carl Michael931080 and Jan_G 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 1, 2018 Share Posted January 1, 2018 (edited) Jan What a fantastic start - your progress is amazing Keep 'em comin Peter Edited January 1, 2018 by Peterpools Link to comment Share on other sites More sharing options...
mark31 Posted January 1, 2018 Share Posted January 1, 2018 great start on this one i have the single seater in the stash looking forward to see more Mark Jan_G 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 1, 2018 Share Posted January 1, 2018 Looks great so far! Very smooth indeed Jan_G 1 Link to comment Share on other sites More sharing options...
VintageEagle Posted January 1, 2018 Share Posted January 1, 2018 Great project and progress Jan! This kit is also on my to-do list. I did quite some research about W.Nr. 240112. The article, a previously unpublished color shot of W.Nr. 240112 and many previously unpublished b/w photos will be published in my next book. I also tried to find evidence for its correct subtype designation. You are absolutely right, it should be A-10 and not A-12. There are several indirect and one direct proof for this. Based on research I did, this aircraft was almost certainly unarmed despite the cowling with the gun troughs. I am looking forward to see more of your progress on this kit. Cheers, Roger Wackyracer, Padraic Conway, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
Daniel460 Posted January 1, 2018 Share Posted January 1, 2018 Great start and beautiful detail work! I'll follow along, very interesting plane. Dan Jan_G 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted January 1, 2018 Share Posted January 1, 2018 Lovely start so far Jan. I'm looking forward to your venture just like everyone else. Congratulations on picking up this kit. Regards, Troy Jan_G 1 Link to comment Share on other sites More sharing options...
Jan_G Posted January 1, 2018 Author Share Posted January 1, 2018 Thanks all you guys for kind words! really apreciate it jan LSP_Paul 1 Link to comment Share on other sites More sharing options...
Jan_G Posted January 1, 2018 Author Share Posted January 1, 2018 Great project and progress Jan! This kit is also on my to-do list. I did quite some research about W.Nr. 240112. The article, a previously unpublished color shot of W.Nr. 240112 and many previously unpublished b/w photos will be published in my next book. I also tried to find evidence for its correct subtype designation. You are absolutely right, it should be A-10 and not A-12. There are several indirect and one direct proof for this. Based on research I did, this aircraft was almost certainly unarmed despite the cowling with the gun troughs. Roger Thanks Roger for the tips I will cancel gun barrels. What's the name of the book you are preparing and when it will hit shelves pls? Can I ask you for the opinion regarding painting of front part of the engine cowling with flaps? ZM suggest RLM 02 and Airframe album suggest RLM 81, but based on several photos I have it definitelly looks lighter than RLM 81 seen on fuselage. So I intend to go with RLM 02 however I'm not sure if this was possible at all. Im not sure with the color of the upper part of engine cowling as well. ZM suggest to go with unpainted metal as for the side parts of the cowling. Airframe suggest RLM 81/82 for upper part and even I do not have quality photo which can prove this, it looks to me based on 1 photo that the upper part is darker then the metal sides. So I would be thankful for any recommendation Roger Thanks a lot jan LSP_Paul 1 Link to comment Share on other sites More sharing options...
VintageEagle Posted January 2, 2018 Share Posted January 2, 2018 (edited) I haven't given a name yet to the book, but it will most likely be 'Captured Eagles - Do 335' as my first book is called 'Captured Eagles Vol. I' and deals with a variety of Luftwaffe aircraft. I self publish it (like my first one) and the exact date is not yet fixed. I hope to finish it this year though. The color of the front part is a tricky question. On the color photo it looks like the flaps are RLM 82 green, then there is a center ring that looks more like RLM 02 and the front ring looks again to be RLM 81. The different shades of these 3 "rings" is also confirmed on b/w photos taken at different angles, so I doubt that the different shades are only due to sunlight at different surface angles. While evidence suggests these 3 "rings", logically I don't understand why there would have been this RLM 02 center ring as I would have rather expected either all in RLM 82 or 02, but not a mix. The upper part with the gun troughs was definitely unpainted. The different shade is possibly due to different materials. The upper part may have been steel (just guessing) while the rest was aluminum. Hope that helps. Cheers, Roger Edited January 2, 2018 by VintageEagle Jan_G, Padraic Conway and Kagemusha 3 Link to comment Share on other sites More sharing options...
Jan_G Posted January 2, 2018 Author Share Posted January 2, 2018 The color of the front part is a tricky question. On the color photo it looks like the flaps are RLM 82 green, then there is a center ring that looks more like RLM 02 and the front ring looks again to be RLM 81. The different shades of these 3 "rings" is also confirmed on b/w photos taken at different angles, so I doubt that the different shades are only due to sunlight at different surface angles. While evidence suggests these 3 "rings", logically I don't understand why there would have been this RLM 02 center ring as I would have rather expected either all in RLM 82 or 02, but not a mix. The upper part with the gun troughs was definitely unpainted. The different shade is possibly due to different materials. The upper part may have been steel (just guessing) while the rest was aluminum. Thanks a lot Roger for this valuable info! So I will try to play a little with different colors of the front engine cowling and good luck with finishing your new book, all new knowledge and findings are more than welcome regards jan Link to comment Share on other sites More sharing options...
Jan_G Posted January 6, 2018 Author Share Posted January 6, 2018 both cockpits complete, added wiring now It's time to close the whole fuselage thanks for looking jan Kagemusha, sandokan, Gazzas and 8 others 11 Link to comment Share on other sites More sharing options...
jean luc Posted January 6, 2018 Share Posted January 6, 2018 great job congratulation Jan_G 1 Link to comment Share on other sites More sharing options...
Gazzas Posted January 7, 2018 Share Posted January 7, 2018 cockpit looks sweet! The belts look ultra-cool! Gaz Jan_G 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted January 7, 2018 Share Posted January 7, 2018 (edited) Looking great!! I like the detailing!! Just one observation: the smaller rear seat has the to shoulder straps reversed, hey should be on oposite sides as the PE end parts should have the longer flat side in the middle just like the forward seat has! Other than that, oustanding work so far!! Cheers Alan Edited January 7, 2018 by alaninaustria Kagemusha and Jan_G 2 Link to comment Share on other sites More sharing options...
