  • Kagemusha changed the title to 2nd Do 335B-2 Closed version
16 hours ago, LSP_Ray said:
Very nice, Miloslav! Was there much problem with closing the panels up? How was the fit?
 Thanks.
Unfortunately, all panels are larger and do not fit the holes. Everything has to be adjusted. The same is for a closed cab canopy.
10 hours ago, Miloslav1956 said:
 Thanks.
Was worried about that. I plan on having one side open, the other side closed. I guess a bit too large is better than too small.
I compared HK with a model from ZM. ZM Do 335 is far more detailed in all parts. I'll start building it at Christmas and put the building in WiP. I was a little worried about the clear parts, but ZM used an excellent material that is not as brittle as the material used for canopies.
Wasn't the putty, as on the wingtips on your model, meant to cover the rivets for a more streamlined finish?  Your simulated putty appears to serve no purpose...just an observation...
Edited by mbrman
