Dave Williams Posted December 18, 2020 Posted December 18, 2020 9 minutes ago, mbrman said: Wasn't the putty, as on the wingtips on your model, meant to cover the rivets for a more streamlined finish? Your simulated putty appears to serve no purpose...just an observation... Photos of the actual V13 show that the rivet lines on the NMF wingtips were covered with putty or paint, so it’s correct.
mbrman Posted December 18, 2020 Posted December 18, 2020 (edited) Right, but i can still see every rivet through the simulated putty... it's not covering anything...a puttied rivet should be invisible. Otherwise, what's the point? Edited December 18, 2020 by mbrman
Dave Williams Posted December 18, 2020 Posted December 18, 2020 It may be for corrosion protection, to seal the hole because it’s unprimed. Otherwise, have to ask the Germans who did it back in 1945.
mbrman Posted December 18, 2020 Posted December 18, 2020 You're grasping at straws. Fact is, the putty is portrayed incorrectly. I understand that nobody wants to criticize this particular modeler, but wrong stuff is wrong. Period. Putty was applied to smooth the finish of an aircraft...not roughen it up. Even if the putty had not yet been sanded, the rivets would be covered. Just stop! Dave
Miloslav1956 Posted December 18, 2020 Author Posted December 18, 2020 I recommend looking in professional books, where there are enough photos. This is not a seal, but only a primer paint.The rivets did not always have surface protection. As an aircraft locksmith, I often used these old German rivets. There are still a lot of them left in our country, like other materials and tools. Azor 1
mbrman Posted December 18, 2020 Posted December 18, 2020 (edited) Okie Dokie! I'll take your word for it. Edited December 18, 2020 by mbrman
Dave Williams Posted December 18, 2020 Posted December 18, 2020 Feel free to ask other questions when you don’t know something.
