Wackyracer Posted August 31, 2020 Posted August 31, 2020 Here's my build, ironically it was the next on my bench just because I liked the scheme so much, but with the new GB about to start worked perfectly. No doubt I'll add some extras into the mix and have to snag a Revell late canopy (my second hand kit clear parts were MIA) Aaron LSP_Kevin, MikeC, Alain Gadbois and 10 others 13
Lothar Posted August 31, 2020 Posted August 31, 2020 Great choice of markings, will be interesting to follow. Wackyracer 1
Wackyracer Posted September 1, 2020 Author Posted September 1, 2020 1 hour ago, MikeMaben said: Gotta include the cow Aaron I know, but I can only find fat ones at the mo MikeC and MikeMaben 1 1
Wackyracer Posted September 12, 2020 Author Posted September 12, 2020 So it begins. I build the pit and side walls and glued one of the tail sections to the fuselage in prep for rivets. Now the problem, the hasegawa kit has the tall tail and my bird has the earlier tail, damn. So having so many revell kits of the 109 I delved into the left over sprues and found an early version from the 109G-6 AS build I'm doing. Quick check and all looks OK so out with the razor saw... Overlay to be double sure. And 5 mins later Both sides glued and test fit. Next problem, tall tail wheel! Again hasegawa only have short one. I'd already grabbed my spare from the revell erla kit for the G-6 AS so scratching time and here's the result using the erla one as a template. And test fit. chrish, Landrotten Highlander, BradG and 8 others 11
MikeMaben Posted September 13, 2020 Posted September 13, 2020 You got it runnin' scared Aaron !! chrish and Rockie Yarwood 2
Wackyracer Posted September 13, 2020 Author Posted September 13, 2020 18 minutes ago, MikeMaben said: You got it runnin' scared Aaron !! Found some! dodgem37, Rockie Yarwood, mgbooyv8 and 3 others 5 1
Alain Gadbois Posted September 13, 2020 Posted September 13, 2020 Great cow! This will represent well The situation of the Luftwaffe at the end of the war. Alain BradG, Wackyracer, MikeMaben and 1 other 4
Wackyracer Posted September 14, 2020 Author Posted September 14, 2020 Quickboost resin MG's Rivetted the fuselage Alain Gadbois, chrish, LSP_Kevin and 5 others 8
Wackyracer Posted October 25, 2020 Author Posted October 25, 2020 (edited) Holy cow batman... Pit installed, just went with the kit parts as an 109 is very difficult to see and very claustrophobic. Getting all the sundries prepped Installed the lap belts already, but leaving the top ones till later. These are from the Aires cockpit set I used on the 109G-6AS build. Nearly ready for paint! Edited October 25, 2020 by Wackyracer scvrobeson, LSP_Kevin, MikeMaben and 10 others 13
dodgem37 Posted October 25, 2020 Posted October 25, 2020 Nice little conversion. Good show. Sincerely, Mark Wackyracer 1
mozart Posted October 25, 2020 Posted October 25, 2020 Good to see this one moving Aaron, despite the inevitable minor difficulties the build seems to be going smoothly! Wackyracer 1
Wackyracer Posted November 22, 2020 Author Posted November 22, 2020 Paint! Halfords Plastic Primer Grey, then some random lines and textures via masks and stuff. AK RLM 81 version 3 and Mr Paint RLM 84 (76 late war) Next up Gunze RLM 83 and tail RLM 76 standard shade. Filled in a few of the underside with AK RLM 76 late Added the yellow band Gunze RLM 04 And the mottles Happy enough Aaron Fanes, Out2gtcha, Phantom2 and 8 others 11
Wackyracer Posted November 28, 2020 Author Posted November 28, 2020 Masking for markings Spinner had a 3rd white and a spiral over the top, 3 stage process, made my head hurt Reveal time BradG, Fanes, alain11 and 6 others 9
Wackyracer Posted November 30, 2020 Author Posted November 30, 2020 Went over the rlm 81 with 75 just for a bit more interest Decals for the number and other bits added Exhausts painted and installed Barracuda wheels test fitted along with undercarriage Had to add the prop just to see Aaron Kais, Fanes, Landrotten Highlander and 8 others 11
