Troy Molitor Posted January 31, 2020 Share Posted January 31, 2020 Looking good Brian. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 31, 2020 Author Share Posted January 31, 2020 Thanks gents! Im right in the middle of being ready to spray the rest of the internal parts for the fuselage, but between our Easter Jeep Safari trip looming this spring, and work, the model bench has taken a bit of a back seat. Ill definitely be picking the Nick back up shortly........ Uncarina 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 21, 2020 Author Share Posted June 21, 2020 Been a LOOOOOOONG time since an update! Well here we go............... Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 21, 2020 Author Share Posted June 21, 2020 First off, to get back to this project, I took apart the finished engines (generally just the front crank case) as I was not happy with the OOB prop attachment after completing them. After removing the crank cases, I inserted a cut piece of brass tubing into the props, and a corresponding smaller piece of brass tubing sticking out of the engines. MUCH more study and not so wobbly this way. Professional lego engine stands in place of the wooden ones I made from the kit that really dont fit with the engine bearers on: Next up, I used a flat razor and scrapped all the OOB detail off of the IP. I then glued on the Yahu panel, and extra levers and such. Turned out pretty decently, especially after looking the OOB IP over: Next I got the rear gunners position finished up, save for the starboard side cannon under the fuselage, but that will be added before putting the fuselage halves together: Finally, I also had to relent on the fuselage sections....................A month or two ago, I applied some perfect plastic putty to all the ejector pin marks on the interior of the two grey fuselage sections. I KNEW I should have not used that stuff, as generally I have ZERO luck with it, and in this case with the small molded in ribbing of the internal fuselage parts, it really made a mess of things, and was coming off with much less effort than I had anticipated, and getting all that extra putty out was turning the fuselage interior into a full mess. Soooooo I had to relent and broke out the clear fuselage sides, and will use what I should have used, some Mr Surfacer. I assembled the nose section for the two machine guns VS the cannon, and as you can see, the open panels applied left a couple tiny gaps to fill (which I already did) as well as my own flub up, of touching the side of the nose cone with some Tamiya extra thin on my hands, also filled with some MS 1500. Attaching things and assessing the fit of things with the clear fuselage sides seems to indicate great fit here. I also applied the gray plastic light cover on the nose, as the specific plane Im doing looks to be an earlier version of the Ki-45 that had the nose light painted over: The fit of the fuselage parts with the assembled interior is really excellent: Got the wife and my wedding anniversary coming up in 8 days, so will be taking another break from the Ki-45 next Thursday, but in the mean time, Im working on smoothing out the interior ejector marks as best I can, even though most of them probably wont be seen or noticed. All for now lads, Cheers! turbo, dodgem37, airscale and 17 others 20 Link to comment Share on other sites More sharing options...
airscale Posted June 21, 2020 Share Posted June 21, 2020 bloody hell - that all looks so right really nice job Brian - looks a cracking kit too Peter Out2gtcha, Troy Molitor and chrish 2 1 Link to comment Share on other sites More sharing options...
Uncarina Posted June 21, 2020 Share Posted June 21, 2020 Brian, nice work indeed! It’s great to see your progress with this. Cheers, Tom Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 21, 2020 Author Share Posted June 21, 2020 Thanks gents! Been a LONG time since I even sat at the bench, so its all coming back slowly. Will have another break next week soon, but hopefully can get a bit more done before we leave. Cheers! Uncarina and Kagemusha 2 Link to comment Share on other sites More sharing options...
Troy Molitor Posted June 21, 2020 Share Posted June 21, 2020 Nice update Brian. I need to pick one of these up sometime. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Thunnus Posted June 22, 2020 Share Posted June 22, 2020 Great to see this one back on the bench, Brian! I know that Z-M makes some good kits but looking at all of the interior spars for the wings triggers bad memories for me! Troy Molitor and Out2gtcha 1 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 22, 2020 Author Share Posted June 22, 2020 Thanks guys. I feel you John, there is likely a LOT of internal detail I wont put in. If I cant see it, I probably wont include it unless necessary for assembly. Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted June 22, 2020 Share Posted June 22, 2020 (edited) Stunning work Brian! Edited June 22, 2020 by spyrosjzmichos Link to comment Share on other sites More sharing options...
MikeMaben Posted June 22, 2020 Share Posted June 22, 2020 Beautiousfull !! Have fun next week Link to comment Share on other sites More sharing options...
dodgem37 Posted June 22, 2020 Share Posted June 22, 2020 Great show. Very nice. Just an observation, Brian, Mr. Greenjeans there could use some highlights and lowlights to match-up with the rest. Sincerely, Mark Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
dennismcc Posted June 22, 2020 Share Posted June 22, 2020 Looking good, overcoming these "challenges" is all part of the fun ! Cheers Dennis Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 22, 2020 Author Share Posted June 22, 2020 Thanks gents! Mark, Surprisingly, there are actually about 3 different tones of the gray green there, but I've been only using my cell phone camera, so it doesn't pick up whites or shade differences well. It also changes the hue of yellows and greens unfortunately, as I found out on my Do-335. spyrosjzmichos 1 Link to comment Share on other sites More sharing options...
