bdthoresen Posted June 26, 2015 Share Posted June 26, 2015 Mal, Mal, Mal............Just went back and reread the whole thread.....You are knocking this one out of the park........Impatiently waiting for the next update..........THOR Mal_Belford 1 Link to comment Share on other sites More sharing options...
Mal_Belford Posted June 26, 2015 Author Share Posted June 26, 2015 Thanks Thor...thanks. /Mal Link to comment Share on other sites More sharing options...
Mal_Belford Posted June 26, 2015 Author Share Posted June 26, 2015 Allright ......ive drilled holes on the cowling frame the attach holes for the cowling, masked all of, then Tamiya gloss black, after that Alclad, then used maskol to cover each hole, then YZC and Salmon Primer.....Yea it works for me...yes it will be light grey inside the cowling, nothing i wont miss later, all is just dryfitted..... Oh yes it will look cool when done, washes will be applied on the cowling flaps, and the mounting holes for them panels will get washes in them...... /Mal BiggTim, Ralph-D, Bill Cross and 2 others 5 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted June 26, 2015 Share Posted June 26, 2015 Mal Incredible work ... absolutely gorgeous. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Mal_Belford Posted June 27, 2015 Author Share Posted June 27, 2015 Thanks Maru and Peter. Allrigt Little done today...weathering proces started....im not done yet, need some rest, to easy to overdo thees things..ive used Yamiya Panel accent wash and grey/White/yellowish weathering makeup kit.... first round is done....just few touch ups, later graphite from a pen, ill run it over the springs, and some ligh light greyish dust pigment from top to down...but now let it rest and look with fresh Eyes, subtle is the key... /Mal Whitey, Bill Cross, Fenous and 2 others 5 Link to comment Share on other sites More sharing options...
S.Pelletier Posted June 27, 2015 Share Posted June 27, 2015 Hi Mal; This is my first post on LSP (been lurking for a couple months...) First; let me tell you that you're an amazing builder, painter! I have been following your build for a couple of months (FW-190, Zero and this Corsair) and i have learned much from them. I really admire your skill I have some questions about Tamiya paint : What ratio paint / thinner and what pressure do you use to achieve that perfect finish? Do you always use the same ratio / pressure and last do you use primers? I sure will continue to follow your build on LSP Stephane edit: I just re read your thread... and found that you use 1:3 ratio for paint... Link to comment Share on other sites More sharing options...
Guest Peterpools Posted June 27, 2015 Share Posted June 27, 2015 Mal Looking magnificent. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 27, 2015 Share Posted June 27, 2015 Awesome work, Mal. All those details behind the cowl flaps are amazing. Kev Link to comment Share on other sites More sharing options...
Bill Cross Posted June 27, 2015 Share Posted June 27, 2015 Superb detailing. Link to comment Share on other sites More sharing options...
LSP_Ray Posted June 28, 2015 Share Posted June 28, 2015 Beautiful work! Link to comment Share on other sites More sharing options...
Tomcat14 Posted June 28, 2015 Share Posted June 28, 2015 Mal, you are a master at what you do sir. I am enjoying your build greatly so far. Chris Causey Link to comment Share on other sites More sharing options...
Mal_Belford Posted June 28, 2015 Author Share Posted June 28, 2015 (edited) Thanks all for them kind Words, im glad you all like it. @S.Pelletier. My mix ratio with Tamiya is 30-35% paint and 70-65% isoprop alchohol, then a 3-5 big drops Tamiya retarder from a brush. coats that goes on wet without rinning or pooling up, since when it dries it is very thin, and if any fiber or particle landed on the paint, it is easily removed with a soft makeup brush Before applying next coat, note i use optivisor when im doing Airbrush work so i can spot any defects real early...alot of coats needed to cover due the ratio i use, but it got benefit as Control over the paint and less risk of "to much" paint that covers crisp Surface details. About primers..well that depends on the kit itself if needed. if a shortrun kit or others such as Hasegawes FW190/Me109 and others similar kits, where there been putty, redones, toolwork on the Surface, then i go for real primer paint, i use nowdays Tamiya Rattlecan primer...to detect Surface defects and errors. If doing a kit like this that istelf is a perfect fit, very Little with putty or surfacer then no need for real primer in my opinion, so o do a paint coat that acts like a primer instead, in this case yellow/greenish, or light grey. The Psi varys all between 10-up to 18 sometimes higher depending on the job AND Paint (it need to atomize properly, Always look on the spray pattern around), i use a HS Evolutuin plus something and a HS Infinity, they fit my needs very well. a note, i dont look at the preassure meter that much at all, i adjust the airpreassure when the "feel" is right, i test shot top side of my hand near the thumb and feel the preassure and paint flow, weird i know but it got to feel in a way that is right....lol o know but it works for me, Erik (Somnas) saw me do it, he said damn i do understand what you mean he said. I Hope this anwers your question, and feel fre to ask more and ill explain as good as i can. /Mal Edited June 28, 2015 by Mal_Belford tomv87 1 Link to comment Share on other sites More sharing options...
Mal_Belford Posted June 28, 2015 Author Share Posted June 28, 2015 Allright....Sunday morning, Went up Abou 5,30 AM...haha couldnt sleep, so on with the Coffee, take a look....and many many hours later.... Finnished, touch up with graphite from a pen, went over the springs and wire...this will do just fine for me...Mals Way.... Front Engine cowling...just dryfitting, this one were inded time consuming due the real shallow details, so work, layer by layer, yes, also make that White look alive, more adjustements, im not done yet, yes Little dirt is a must so it creates Life and depth.... /Mal geedubelyer, Sparzanza, Jamme and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 28, 2015 Share Posted June 28, 2015 That's just fantastic, Mal! Those scratch-built springs of yours just look so real. Kev Link to comment Share on other sites More sharing options...
dodgem37 Posted June 28, 2015 Share Posted June 28, 2015 One of the best builds ever. Keep up the wonderful work, Mal. Sincerely, Mark Bill Cross 1 Link to comment Share on other sites More sharing options...
