Grizly
LSP_Members
  • Posts
    371
  • Joined
  • Last visited
  • Days Won
    1
Posts posted by Grizly
  1. The subject I am modelling with my Tamiya P-51D carried underwing 5 inch rockets and there lies my problem - where to find the zero length rails. I purchased the Isradecal rails but, unfortunately, they are of a different pattern from those normally installed on the Mustang (see below for the required type). Anybody out there have a suggestion as to where I might find six sets of rails (don't need the rockets)?
  2. Anthony,
    I simply sprayed the spinner Xtracolor Sky Type S then Tamiya NATO Black and chipped some of the black off with a number 11 XActo blade.
    Bill,
    the leading edge of the prop has paint removed on the outer leading edges. It's just not evident in the pictures. I might add (some) 'chipping' on the wing leading edges. I just haven't decided yet.
  3. Richard,
    If you can, could you post pictures/drawings of the right side of late RCAF Mustangs which had the revised radio and electrical junction panel. Specifically how the radio and ARC control heads were positioned and if the oxygen regulator was updated/relocated. I still have the drawings previously provided but have since been unable to clarify the latter mentioned details.
  4. Since I used the Aires resin wheel well set in my build I was somewhat concerned that the plastic/resin gear joint might not hold the weight so, to be on the safe side I added a piano wire support between the main gear aft of the center line tank. While it can be seen with close examination of the attached, it is virtually invisible when the model is sitting on the gear on display. As an aside, should you wonder, the pylon bombs are interchangeable on my model.
  5. I'm surprised to see a sink. The post war C-47s that I flew with the RCAF had a 'honey bucket' in the tail and that was it. If there had been sinks prior to their refurbishment, I can't believe that they would have been removed. We also had a one cylinder apu back in the tail on the port side but that could well have been a post-war mod.
  6. As previously mentioned, while I used the tanks, intakes, etc from the Belcher Bits conversion, I didn't use the resin fuselage. Instead I used the fuselage master that I had made which was used to develop the resin fuselage. Why? It wasn't because I didn't like the resin copy, I simply wanted to use the part I had made and it mated nicely with the forward fuselage.
  7. My build actually used the master for the fuselage that was used to make that in the Belcher Bits conversion. Why? I made it and I just wanted to use 'my' part. The rest including the intakes, tanks, doors pylons are those provided by Belcher Bits. I do have lots of 'in progress' photos, however, there is a possibility of my build being publicized so I'm reluctant to post them at this time.
  8. After pilot training with the RCAF I cut my teeth flying the venerable C-47 and accumulated over 2000 hours on it in three years before moving on to the C-130. For those interested, here are three different variants of port side doors - the standard cargo door, the cargo door with the para door insert in the forward door modified to provide swing down passenger steps and a straight passenger entrance (no cargo door).
  9. Further to Clunkmeister's comments, the kit should have not only skinned over windows but also skinned over locations for the Frazer-Nash and Martin upper turrets and ventral turret thereby offering the modeller a broad choice of variants to model and precluding the need for HK models to make separate moulds should they wish to offer earlier and/or later marks.
  10. Looks good but I too would have preferred skinned over windows that could be punched out in order to replicate earlier Lancs. Such an initiative would have provided a broader base kit which offered the modeller a wider selection of subjects. My choice would have been a post-war Canadian Mk.10MR. I've built one in 1/48 scale and 'removing' the windows is a real pain. Hopefully HK sees fit to offer a version of the kit without windows in the (near) future.
