LSP_Kevin Posted January 18, 2018 Share Posted January 18, 2018 Howdy folks, Our own Chris Nicoll reviews some P-39 landing gear from SAC: Scale Aircraft Conversions 32018: P-39 Airacobra Landing Gear (SH) Thanks, Chris! Kev Luca and LSP_K2 2 Link to comment Share on other sites More sharing options...
Tony T Posted January 18, 2018 Share Posted January 18, 2018 Thank you for a very brave review, and admission. Tony Harold and Jack 2 Link to comment Share on other sites More sharing options...
RLWP Posted January 18, 2018 Share Posted January 18, 2018 My impression is that SAC use the kit parts as patterns to make the white metal parts. So I'd expect them to be a bit undersize Sounds like money for old rope Richard Jack 1 Link to comment Share on other sites More sharing options...
Tony T Posted January 18, 2018 Share Posted January 18, 2018 More like money for old soldering wire. SAC really needs to change the alloy. The soldering wire metal is utterly useless for 1/32 scale. I only buy G-factor, Brassin bronze and, occasionally in the past, Aeroclub, all of which I can wholeheartedly recommend. Tony R Palimaka, Jack and Harold 3 Link to comment Share on other sites More sharing options...
R Palimaka Posted January 18, 2018 Share Posted January 18, 2018 (edited) More like dry solder wire. I bought a 1/24 Mustang landing gear, which is a replacement for the Trumpeter set. I was planning to modify it to use it on my Airfix Mustang, to add some strength. The castings are very rough, and the scissor links were solid, not see-through at all. They arrived slightly bent, and when I straightened them there was a dry squeaking sound, which made me wonder if it had cracked inside. In the end I had to replace the legs with aluminum tubing, and used the remaining SAC parts to dress it up. Not impressed. Richard Edited January 18, 2018 by R Palimaka Jack and Harold 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 18, 2018 Share Posted January 18, 2018 Chris Excellent review and points out our major concerns on SAC gear: soft white metal with questionable strength and soft details as well. Agree the kit gear seem the way to go Peter Link to comment Share on other sites More sharing options...
RLWP Posted January 18, 2018 Share Posted January 18, 2018 More like dry solder wire. I bought a 1/24 Mustang landing gear, which is a replacement for the Trumpeter set. I was planning to modify it to use it on my Airfix Mustang, to add some strength. The castings are very rough, and the scissor links were solid, not see-through at all. They arrived slightly bent, and when I straightened them there was a dry squeaking sound, which made me wonder if it had cracked inside. In the end I had to replace the legs with aluminum tubing, and used the remaining SAC parts to dress it up. Not impressed. Richard The creaking is a feature of white metal, something to do with crystal planes realigning. Very disconcerting Richard R Palimaka 1 Link to comment Share on other sites More sharing options...
Luca Posted January 18, 2018 Share Posted January 18, 2018 aaargghhhh I have a lot of SAC u/c legs in my stash...I did not know about this alloy issue Link to comment Share on other sites More sharing options...
Iain Posted January 18, 2018 Share Posted January 18, 2018 I have several sets that I've been given in recent years - agreed on the material used - plastic stronger IMHO. Iain R Palimaka and CANicoll 2 Link to comment Share on other sites More sharing options...
Jack Posted January 18, 2018 Share Posted January 18, 2018 I'll never touch them, ever........ R Palimaka 1 Link to comment Share on other sites More sharing options...
quang Posted January 19, 2018 Share Posted January 19, 2018 The most outrageous is not that they used a soft, unsuitable material. It's the fact that they obviously used the original plastic kit part as the master for their mouldings instead of creating their own. jenshb 1 Link to comment Share on other sites More sharing options...
Cees Broere Posted January 19, 2018 Share Posted January 19, 2018 (edited) Shameless copying you mean? Although some sets do have some corrections on them or integration of parts that are separate in the original kit. Cees Edited January 19, 2018 by Cees Broere Link to comment Share on other sites More sharing options...
Lancman Posted January 19, 2018 Share Posted January 19, 2018 Bought and binned their undercart for the Trumpy Hurri, to sum it up it was crap and didn't even fit. Graham Link to comment Share on other sites More sharing options...
Mark M Posted January 19, 2018 Share Posted January 19, 2018 ive today binned the 1/32 typhoon set, i opened the box, it was bent, twisted and some parts were really soft, TBH the kit parts are far better CANicoll 1 Link to comment Share on other sites More sharing options...
CANicoll Posted January 19, 2018 Share Posted January 19, 2018 Thanks for the comment gents - I think the universal issue is that the detail is missing from their parts and the metal used is suspect in the long term to actually being weaker than the kit plastic parts. So instead of a win-win, you get a lose-lose. I was very disappointed in the soft casting. It does seem like they took the kit part and re-casted it, and then added a huge mold seam. Can't say I see myself ever buying another SAC product again. Lesson learned! Chris R Palimaka 1 Link to comment Share on other sites More sharing options...
