MrPropBlur Posted April 28, 2017 Share Posted April 28, 2017 I just joined LSP. I want to thank you for an enjoyable time following your progress. Most impressive work! Girlscanplay2 1 Link to comment Share on other sites More sharing options...
Joel_W Posted April 28, 2017 Share Posted April 28, 2017 Collin, Most impressive for sure. The wear and tear on the invasion stripes really adds that something extra. The weekend here is finally going to get into the 80s, so it's car detailing time, watching the weekend ballgames in the Florida room, finally putting the BQ outside for the season, and a lot less modeling, but I'll still get a little bench time in. Joel Link to comment Share on other sites More sharing options...
Collin Posted May 2, 2017 Author Share Posted May 2, 2017 Weathering Part 1 I suppose: Decided on a close to neutral wash, used a deep grey to add some life to the panel lines and rivets, but nothing stark like dark grey or black. I want to see it....but not see it, if that makes any sense. So this went on pretty easy over the entire model (acrylic satin coat under to protect the finish). Will let that dry for a day and then do another light coat of acrylic. Think I will then try my hand (very carefully) with some light oil weathering around the wing ammo bays and the high traffic areas (dirty brownish oil) and some fluid and darker (toward black) oils on hinge points and mechanical areas. Ultimately once that is finished and sealed...there will be a light airbrushing of exhaust and coats of weathering on high traffic areas (again)...and that should do it for weathering. ETA...well probably next week since I have to go away and play Navy this weekend. Cheers Collin And I still have that used but not seriously abused NMF that I am looking for, the look of the Alum skin of the P-38/47/51 is very elusive. TenSeven, Mark M, Shaka HI and 3 others 6 Link to comment Share on other sites More sharing options...
Mark M Posted May 2, 2017 Share Posted May 2, 2017 that wash looks perfect Link to comment Share on other sites More sharing options...
Collin Posted May 2, 2017 Author Share Posted May 2, 2017 Sat down this morning and tried my hand at some oil paint "rendering" to impart some grime and wear to some areas. Mainly in the wing root area and around the gun panel area where foot and hand traffic would be by ground crew. Only did the top of one wing and the forward port side, now taking a step back and gauging how well it looks. And of course Photobucket is screwed up this morning, so I can't upload any photos. Maybe later tonight after work. Cheers Collin Girlscanplay2 1 Link to comment Share on other sites More sharing options...
Collin Posted May 2, 2017 Author Share Posted May 2, 2017 Photobucket working again: Weathered wing: Unweathered wing: Total area I have weathered with oils so far: mark31, TenSeven, leoasman and 4 others 7 Link to comment Share on other sites More sharing options...
cib2265 Posted May 2, 2017 Share Posted May 2, 2017 Looking great Colin! Try using Tamiya's Titanium gold or silver as a dry brushing effect over the NMF alclad. It leaves lovely in scale scratches and burnishing. Joel_W 1 Link to comment Share on other sites More sharing options...
mark31 Posted May 2, 2017 Share Posted May 2, 2017 Nice work you have done here i love it Mark Link to comment Share on other sites More sharing options...
titan8251 Posted May 2, 2017 Share Posted May 2, 2017 nice Collin, looking real good Frilldo Link to comment Share on other sites More sharing options...
monthebiff Posted May 2, 2017 Share Posted May 2, 2017 Nice work indeed, liking your weathering. Regards. Andy Link to comment Share on other sites More sharing options...
Collin Posted May 3, 2017 Author Share Posted May 3, 2017 Second stage of weathering done. My first attempt at oil weathering (over an acrylic semi-matt/gloss finish). Was easier to control than expected. I used a sepia color for most of it. Wanted to show a moderate amount of weathering in the wing root and in the high traffic areas thinking of a mid-June/July aircraft being serviced multiple times a day and set back out on missions. Do I think it's a little heavy in a few places....might be, still learning the technique. Overall pretty happy. Now I will add a few streaks here and there with diluted colors for the exhaust, a small amount of gun stains and some other random areas. Might actually shoot some AK Filter colors in some of the high wear areas to impart a dusty look on top (worked well on my Typhoon build I did last year on this site). Oil weathering....give it a try, it's not as scary as I thought and if you don't like it....wipe it right off and start over!! Cheers Collin Shaka HI and TenSeven 2 Link to comment Share on other sites More sharing options...
Collin Posted May 3, 2017 Author Share Posted May 3, 2017 Still experimenting....didn't completely like the weathering, so I pulled out my steel wool/tweezer combo and a needle and etched in some scratches to show the effects of contact with the dirt over aluminum skin and what that looks like (at least to my eye). I think the weathering looks better now. It was real easy and I just lightly scrapped the areas and this is the result. I had covered the aircraft with a thin coat of acrylic semi-gloss prior to this so I could handle it. Cheers Collin Zero77 and Shawn M 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 3, 2017 Share Posted May 3, 2017 Terrific stuff, Collin! Looks great. Kev Joel_W 1 Link to comment Share on other sites More sharing options...
ClumsyDude Posted May 3, 2017 Share Posted May 3, 2017 Wow, Collin, this is really a masterclass. Well done! Jim Joel_W 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted May 4, 2017 Share Posted May 4, 2017 Looks awesome Collin. Love this bird. Troy Link to comment Share on other sites More sharing options...
