mpk Posted May 15, 2017 Share Posted May 15, 2017 (edited) Hi guys. You may have read I have begun a Tony with the express purpose of completing it. I have given myself an approximate month while working on nothing else. Just this kit, start to finish. Being that completion is the kits only purpose, I've not concerned myself with things like sink marks in the undercarriage doors. I don't think they will be noticeable anyway. I will correct this on my next Tony. I also used Tamiya Nato green in the pit. Not exact. I decided not to care if it was not the olive like green on the original. I later gave the rear bulkhead and edges of the pit a dry brush of light olive oil paint. This dry brushing of olive tricks my eye into seeing the Nato green as having an olive tinge. Interesting. I decided to dispense with AM such as individual instrument decals. This is anathema to me, but because I simply want it built, I used the kit cockpit decals. All of which worked fine. Although the IP looks a little cartoonish. I'm closing the canopy anyway. I have limited the AM to decals, Eduard harness, Mastercasters resin wheels and Quickboost cowl mounted MG's. The Mastercasters set was interesting. The wheels are okay and the set contains exhausts and linkages. The exhausts are way undersize and I am just using the kit links. The wheels are not Eduard standard but look fine. I plan to build and paint the kit wheels so as to compare them. To be honest, the only AM this kit really needs is a harness and perhaps a set of decals. This Hasegawa Tony is a wonderful kit. I'm going to build another. This should be done within a couple of weeks. (I suddenly have 2 whole free days ahead of me) Here's a few shots. The A/C I plan is at top right. The aeroplane without the red tail. The reason, it's easier. In this shot one can see the QB machine guns. One can see the cartoonish, yet workable kit IP decal. I used the 3 kit decals for the cockpit. I used Mark Softer on Gunze paints and they settled without an issue. The kit decals are all dimensionally correct with their parts. Edited May 15, 2017 by mpk mark31, MikeMaben, Joe66 and 9 others 12 Link to comment Share on other sites More sharing options...
Jim Barry Posted May 15, 2017 Share Posted May 15, 2017 Sweet! mpk and Shaka HI 2 Link to comment Share on other sites More sharing options...
dmthamade Posted May 15, 2017 Share Posted May 15, 2017 Super progress on the Tony!! Really enjoyed this kit. I really like the choice in schemes, look forward to the paint process. Don mpk and Shaka HI 2 Link to comment Share on other sites More sharing options...
Guest Posted May 15, 2017 Share Posted May 15, 2017 Go Dale !!.....Harv Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 15, 2017 Share Posted May 15, 2017 Hi guys. You may have read I have begun a Tony with the express purpose of completing it. I have given myself an approximate month while working on nothing else. Just this kit, start to finish. Being that completion is the kits only purpose, I've not concerned myself with things like sink marks in the undercarriage doors. I don't think they will be noticeable anyway. I will correct this on my next Tony. I also used Tamiya Nato green in the pit. Not exact. I decided not to care if it was not the olive like green on the original. I later gave the rear bulkhead and edges of the pit a dry brush of light olive oil paint. This dry brushing of olive tricks my eye into seeing the Nato green as having an olive tinge. Interesting. I decided to dispense with AM such as individual instrument decals. This is anathema to me, but because I simply want it built, I used the kit cockpit decals. All of which worked fine. Although the IP looks a little cartoonish. I'm closing the canopy anyway. I have limited the AM to decals, Eduard harness, Mastercasters resin wheels and Quickboost cowl mounted MG's. The Mastercasters set was interesting. The wheels are okay and the set contains exhausts and linkages. The exhausts are way undersize and I am just using the kit links. The wheels are not Eduard standard but look fine. I plan to build and paint the kit wheels so as to compare them. To be honest, the only AM this kit really needs is a harness and perhaps a set of decals. This Hasegawa Tony is a wonderful kit. I'm going to build another. This should be done within a couple of weeks. (I suddenly have 2 whole free days ahead of me) Here's a few shots. The A/C I plan is at top right. The aeroplane without the red tail. The reason, it's easier. In this shot one can see the QB machine guns. One can see the cartoonish, yet workable kit IP decal. I used the 3 kit decals for the cockpit. I used Mark Softer on Gunze paints and they settled without an issue. The kit decals are all dimensionally correct with their parts. Good luck with this, and remember to check wing/root fit, as mine gave me fits. Probably something I goofed myself, but nonetheless,... mpk 1 Link to comment Share on other sites More sharing options...
Citadelgrad Posted May 15, 2017 Share Posted May 15, 2017 Looks excellent. Im struggling with time for my own projects. Its good to see someone making progress toward a reasonable goal. I will be watching this build. mpk 1 Link to comment Share on other sites More sharing options...
mpk Posted May 15, 2017 Author Share Posted May 15, 2017 Thanks fellas. The wings are on. The canopy masked etc. Here's a couple of shots. The wings have been on for a week or so while I've been working on sub assemblies. I'm using the kit exhausts. I had to sand them down to removes ejector marks and applied Mr Surfacer 500 as weld seams. Tomorrow I'll spray an Alclad undercoat of black. Complete painting the prop and undercarriage if I can fit it in. I hope to be done soon because I am looking forward to the next project. The Tony is my dress rehearsal. Lothar, Joe66, Girlscanplay2 and 8 others 11 Link to comment Share on other sites More sharing options...
Gazzas Posted May 15, 2017 Share Posted May 15, 2017 Looking great, Mate! Cockpit painting is very nice! Gaz mpk and Shaka HI 2 Link to comment Share on other sites More sharing options...
Kendzior Posted May 15, 2017 Share Posted May 15, 2017 WOW! I see that you do not slow down the pace and at the same time the quality and fit is first class! I'm watching, as a Tony's declared fan Best regards Hubert Shaka HI and mpk 2 Link to comment Share on other sites More sharing options...
ClumsyDude Posted May 15, 2017 Share Posted May 15, 2017 Looking really good Dale. Cockpit is sweet. Jim mpk 1 Link to comment Share on other sites More sharing options...
mpk Posted May 15, 2017 Author Share Posted May 15, 2017 Thanks guys. Today was spent really preparing the airframe for some paint. Some smaller work included this lot. Tomorrow should be fun. I also bought some acrylic shelving. So I am fully prepared for completed kits. I've been told to rest for the next 12 months. So that's what I'll do. I'll rest and build models. I should be halfway decent after a year of it. Joel_W, AdamR, Daniel460 and 7 others 10 Link to comment Share on other sites More sharing options...
Shaka HI Posted May 15, 2017 Share Posted May 15, 2017 Awesome progress, Dale. Your cockpit looks fantastic -- looks like you're dry-brushing it to highlight the details and it looks very convincing! (Those pre-printed belts are meh, though....) Joel_W and mpk 2 Link to comment Share on other sites More sharing options...
alaninaustria Posted May 15, 2017 Share Posted May 15, 2017 Outstanding work Dale!! Very nice Cheers Alan mpk 1 Link to comment Share on other sites More sharing options...
Girlscanplay2 Posted May 15, 2017 Share Posted May 15, 2017 Dale Looking real nice so far!! What great progress you are having. Teresa mpk 1 Link to comment Share on other sites More sharing options...
Joel_W Posted May 15, 2017 Share Posted May 15, 2017 Dale, Looking real good my friend. Nothing wrong with OOB builds as it's all about how it looks as a display presentation piece. Joel mpk 1 Link to comment Share on other sites More sharing options...
