Guest Maxim Posted June 16, 2018 Share Posted June 16, 2018 Nice. The AIM-7's look spot on! Link to comment Share on other sites More sharing options...
aircommando130 Posted June 16, 2018 Share Posted June 16, 2018 Lookin good so far! I think the Sparrows would still be fairly clean. The weapons crew hangs them and then the crew comes out...does the walkaround with the crew chief and they climb aboard and go to the arm/de-arm area....get the pins pulled and light the burners and go to the tanker for fuel. I have the GT Resin burner cans as well...they are very nice! Cheers...Ron Harold and RichieB 2 Link to comment Share on other sites More sharing options...
Chek Posted June 16, 2018 Share Posted June 16, 2018 If I read you right Richie, you have both the GT Resin and Aires jetpipes? If so, you may have noticed the little square weld details on the Aires outer petals, which are absent on the GT parts. How to combine the two? Well, a task I'm just commencing is to boil up up some foil with eggshells. I'm using the thicker foil that's used as a base for cupcakes, which is submerged with the shells until they turn blackish, with all the imperfections that look like burnt titanium. I then apply a drop of Micro foil adhesive over an Aires petal, and burnish down the foil with a wooden toothpick until the detail is embossed. It can then be gently peeled off the Aires petal and gently pressed into place on the GT resin part, then trimmed to fit. I may wire wool it when the adhesive has set as hard as it's ever likely to. The hardest part so far is getting enough similarly discoloured pieces of foil to cover the 32 pieces required ( or 20 visible ones). RichieB 1 Link to comment Share on other sites More sharing options...
RichieB Posted June 16, 2018 Author Share Posted June 16, 2018 Many thanks Ron & Maxim - light weathering it is then! Chek - You are absolutely right about the missing detail but I didn't have the time or energy to try and add it. Your method sounds brilliant though I fear is a level of effort far beyond my time/patience border! Good luck and would love to see a picture when you've finished it. Link to comment Share on other sites More sharing options...
Gazzas Posted June 16, 2018 Share Posted June 16, 2018 Great cans! ummm... can I get slapped for saying that? Shawn M and RichieB 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 20, 2018 Share Posted June 20, 2018 Looks great so far! Another good option for titanium and grey colored foil is a mason jar of bleach with about an Oz of lead shot, and about 20 or 30 pennies. The chemical reaction can also generate reds greens and folds depending on the lead to copper ratio. MikeMaben 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 20, 2018 Share Posted June 20, 2018 The egg shell method works well too, but occasionally the type of eggs that can be purchased locally can sometimes nor be conducive to coloring the foil chemically. Link to comment Share on other sites More sharing options...
Bruce Posted July 20, 2018 Share Posted July 20, 2018 (edited) On 5/24/2018 at 8:37 PM, Bruce said: I could be wrong, but, I believe that the blue stripe you have on your Aim-9 missiles would indicate they are inert! I don't think you want that unless you are depicting a training mission load. On 5/24/2018 at 8:37 PM, Bruce said: Bruce It turns out that what I thought was a blue band is the optical sensor for the missile so that's not a problem, however, the mounting band that you have painted silver should be white according to my expert Jim Rotramel. Blue bands do stand for an inert missile. You mentioned you might add a little weathering...to the best of my knowledge, Missiles and ECM pods weren't left/stored outside.where they would be exposed to the elements(electronics don't do well left in the rain). Edited July 20, 2018 by Bruce RichieB 1 Link to comment Share on other sites More sharing options...
RichieB Posted July 28, 2018 Author Share Posted July 28, 2018 Many thanks Maru, starting final assembly now so hope to have this completed soon (he says!). Bruce - many thanks for the info. I will probably add a brown band to the Aim-9s as I've seen this on some photos but I'll probably leave the silver band as I quite like the add colour. Link to comment Share on other sites More sharing options...
RichieB Posted August 6, 2018 Author Share Posted August 6, 2018 and ................ she's done! and for all those wondering if the lights still worked...... Phew! I could probably keep tinkering with the weathering etc etc but in truth, after 2 and a half years its probably time to move on. Biggest wins - turning the lights on, spending time getting the weapons and drop tanks right, finally building a great big F-4. Biggest score-draws - some of the stencils silvered and I couldn't fix them (probably needed better prep), fit could be better in places. I learned a lot about decals, dry-fitting, weathering paint jobs and when to build detail into big scale (and when to not bother). Still there's always next time which in my case will probably be an early F-15B in candy stripes. Thanks for watching and all the comments, much appreciated. Have fun out there! Cheetah11, Hubert Boillot, Victor K2 and 13 others 16 Link to comment Share on other sites More sharing options...
ROM Posted August 6, 2018 Share Posted August 6, 2018 You may be proud. She looks amazing. Good job! RichieB 1 Link to comment Share on other sites More sharing options...
NavyF4s Posted August 6, 2018 Share Posted August 6, 2018 Great build R B ! She looks the part for sure, put her top shelf. RichieB 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted August 7, 2018 Share Posted August 7, 2018 Verrry nice ... but , something missing. More Pictures !! F`s are my favs and RichieB 2 Link to comment Share on other sites More sharing options...
Guest Maxim Posted August 7, 2018 Share Posted August 7, 2018 Nice work! Looks excellent. Link to comment Share on other sites More sharing options...
F`s are my favs Posted August 7, 2018 Share Posted August 7, 2018 Oh, that's an awesome weathering and colors. She's superb! RichieB 1 Link to comment Share on other sites More sharing options...
