John1 Posted August 7, 2023 Share Posted August 7, 2023 No idea which ones are D’s and which are E models. scvrobeson 1 Link to comment Share on other sites More sharing options...
Dave Williams Posted August 7, 2023 Share Posted August 7, 2023 5 minutes ago, John1 said: No idea which ones are D’s and which are E models. You can look at the 1/48 scale sheet. https://www.caracalmodels.com/cd48170.html The US Ds and Es are the same as on that sheet. New ones, not on the 1/48 sheet, are Es. Uncarina, John1 and BloorwestSiR 2 1 Link to comment Share on other sites More sharing options...
John1 Posted August 7, 2023 Share Posted August 7, 2023 39 minutes ago, Dave Williams said: You can look at the 1/48 scale sheet. https://www.caracalmodels.com/cd48170.html The US Ds and Es are the same as on that sheet. New ones, not on the 1/48 sheet, are Es. Leaning towards one of the 101st helos. None of the subjects totally blows me away. Hopefully Werner’s Wings finally releases their sheet before I’m done with the build and need to order something. If Floyd hasn’t, I’ll grab the Caracal set. Link to comment Share on other sites More sharing options...
Uncarina Posted August 9, 2023 Share Posted August 9, 2023 Now available for preorder, shipping starts Aug 18: https://caracalmodels.com/cd32026.html Cheers, Tom Dave Williams 1 Link to comment Share on other sites More sharing options...
Dave Williams Posted August 9, 2023 Share Posted August 9, 2023 Ordered! Uncarina 1 Link to comment Share on other sites More sharing options...
John1 Posted August 9, 2023 Share Posted August 9, 2023 Regarding the Caracal decals, not the most exciting selections for post OIF/OEF E-models but in fairness, I think the Army got a bit more conservative (if that's possible) since those days. No more aircraft names for one thing. I'm going to hold off until I get closer to the end of my build and see Werner's Wings has finally got their decals released. Also sounded like from the FB page that a European outfit was supposed to be releasing decals for this kit next month. Given that WW seems to take forever to get their decals released, I have a feeling I'll be going with the Caracal 101st selection with the reaper logo on the tail. Time will tell.... On another note - while looking at some pictures, I noted that the real thing has some pretty visible anti-skid paint applied to the tops of those cheek sponsons and the wings. The Takom parts are as smooth as a baby's butt. Up to each modeler but to me, it's something that needs to be addressed. Note in this detail shot, that waterproofing material that is slopped around the pilot's side window liberally and the black color of the non-skid. Check your references for whatever you are building (assuming you can find pictures that show this area for your subject), this paint can either be black or CARC green (or one side in each color as a guy on FB posted pictures of). Bill Cross, blackbetty, Uncarina and 1 other 4 Link to comment Share on other sites More sharing options...
Dave Williams Posted August 9, 2023 Share Posted August 9, 2023 Other than sharkmouths, are there really any exciting schemes for US AH-64D/Es? Aren’t the options on the Caracal sheet pretty typical for the type? Link to comment Share on other sites More sharing options...
Uncarina Posted August 9, 2023 Share Posted August 9, 2023 That’s why I’m building Saraf and JGSDF versions. Regarding the antiskid texture, Mr Surfacer applied then stippled with a cut-off brush is a common technique. Cheers, Tom CRAZY IVAN5 and John1 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted August 9, 2023 Share Posted August 9, 2023 Hasegawa makes a self adhesive film that's textured. That should be good for recreating the antislip paint. John1 and Uncarina 1 1 Link to comment Share on other sites More sharing options...
nichenson Posted August 9, 2023 Share Posted August 9, 2023 (edited) https://www.vms-supplies.com/vms-hull-tex-air best surface texture for the scale. Edited August 9, 2023 by nichenson firefly7, John1, scvrobeson and 1 other 4 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 9, 2023 Share Posted August 9, 2023 3 hours ago, nichenson said: https://www.vms-supplies.com/vms-hull-tex-air best surface texture for the scale. Very cool............Just ordered some, thanks! Bill Cross 1 Link to comment Share on other sites More sharing options...
Uncarina Posted August 9, 2023 Share Posted August 9, 2023 (edited) ...or here's another cheaper way: 1. spray Tamiya AS-12 as a primer, something for the anti-slip adhesive to grab; 2. paint Vallejo Surface Primer as the adhesive to a section at a time; 3. sprinkle aluminum oxide over the wet primer, then blow away the excess; 4. seal with another coat of paint. Cheers, Tom Edited August 9, 2023 by Uncarina John1, Dennis7423, scvrobeson and 6 others 8 1 Link to comment Share on other sites More sharing options...
Uncarina Posted August 9, 2023 Share Posted August 9, 2023 As Postscript, if I wasn't creating anti-skid surfaces on multiple subjects I would just stick with the Mr Surfacer technique, since it has multiple uses besides this application. Cheers, Tom Link to comment Share on other sites More sharing options...
Bill Cross Posted August 11, 2023 Share Posted August 11, 2023 (edited) On 8/9/2023 at 12:55 PM, nichenson said: https://www.vms-supplies.com/vms-hull-tex-air best surface texture for the scale. VMS products are very good and their customer service is outstanding. Excellent dulling spray. Edited August 11, 2023 by Bill Cross url Link to comment Share on other sites More sharing options...
TankBuster Posted August 12, 2023 Share Posted August 12, 2023 The VMS texture looks good, BNA have it on pre order and I will pick some up to try when it comes in stock. Cheers. Link to comment Share on other sites More sharing options...
