Time for an update I think!
So, after the flap fiasco it was time to get the cockpit and fuselage together.
The instructions say to keep the cockpit halves separate, glue them to the fuselage halves then glue the whole thing together. I felt that was just too much lining up of some very delicate parts that needed to be absolutely spot on so I decided to build up the cockpit in its entirety then join the fuselage halves together then merge the two together as two complete units. After all, that's how it was done on the real thing!
Before I did that though, I wanted to get the canopy on for no other reason than when you're fitting things like this together, a displaced finger when gently easing things around can mean the IP top altimeter etc can fly off in a heartbeat. At least with the canopy on old Douglas Sausage Fingers here can't knock anything off!
So first thing was to join the cockpit halves together. The fit was really very good and that then allowed me to put in the flight engineers' seat, extra instrumentation.
So. before shoots me, I know the extra altimeter above the IP is in the wrong place. It should sit on top of the right hand dial. I'll come to that in a minute.
If you look to the right you can see the engineer "dickey seat" and, if you know the kit you'll be saying "it looks nothing like it" and you'd be right.
The kit engineer's seat looks like this:
spacer.pngProblem is, that's from a late war Lancaster even maybe a MkX. The seat drops on a hinge and the backrest is a swing out lovely padded affair. The wartime LAncastgers had what was called a "dickey seat". Much less luxurious and with a simple canvas webbing strap for a backrest that clipped onto the upright of the pilot's seat. Something like this:
So, with a scalpel, thin plastic rod and tamiya masking tape for the strap, plus a buckle from the PE spares box, you can make an authentic looking one from the kit part without too much trouble...he lied.
Now to the extra instrumentation on top of the IP. I originally put the extra altimeter alongside the compass repeater because I was worried that there might not be clearance when the canopy went on. But then every reference I looked at had it above the compass repeater so I moved the whole lot forward and put it in its proper place. I'm happy now LOL!
The DF ariel in the kit was a pretty poor affair, as you can see from the left hand photo. It's just an octagon with nowhere to wind any wire around as the original had.
So the right hand photo shows that I've added some grooves with a very thin rat tail file so i cound put some winds of wire around and make it look a little more realistic.
Next to work on the canopy. Dare I say basic again? The actual Lancaster canopy was made up of a metal front part and the rear was made of spruce wood struts.
So using 1.5mm rectangular strip, I formed the spruce struts inside the canopy, gluing them on with minute amounts of CA glue. It also gives somewhere to fit the cables running the length of the canopy too which supported the sunscreen.
Why a sunscreen in a night bomber? In summer when they were sitting all day out in the open, with a canopy that that size they got very hot very quickly. The sunscreen shouldn't be confused with the blackout curtain for the Nav which ran vertically between him and the pilot. The handles for the sliding windows are 1mm diameter wire with a bit of insulation sleeve on each end and painted black. I've done one closed and the pilot's open, it was a hot May in 1943.
Last thing to be fitted to the cockpit was the bomb aimers' escape hatch and the bomb aimers' leaning pad
There's no decal for the parachute exit sighn so I fashioned my own and added the ring pull from 0.5mm red florist's wire
Looking down from where the forward gun turret will go you can see the finished effect. Yes I'm sad enough to make a scale Dann sight too
So now it was fit the fuselage halves together. Not a bad fit, the worst bit is shaping the flipping great hole for the rear spot/ventral turret which you can't really do until the halves are glued together but then the floor of the fuselage gets in the way. I'll post pics of that later but suffice to say that buch sanding, priming, sanding, priming (you all know the story), cockpit met fuselage
Looks a bit like a grumpy pug to me
Lastly, I knocked the rear turret together. Same construction as the front turret but I had some lengths of bullets left from the PE of a 1/32 B17-G so I added them feeding into the guns. Just sets it off a bit I think
spacer.pngNext up is to get the fairings on the underside and get everything in ready for Upkeep.
As ever thanks for looking. Your comments are always appreciated
  • 1 month later...
Well, it's been a while since my last update. It's not that I haven't been working on the build, but the fact that my laptop has been at the menders for an inordinately long time, the reasons for which I won't go into. So there's lots to report that I might indeed do over two posts.
Fuselage together, I moved onto painting. I found that when I painted my Mosquito in an NFII config for a client that the @black basing@ technique championed by Matt at DoogsModels works a treat. To get tonality and shade as well as not having to 'cover up the grey', you spray a black primer coat then marble a lighter grey coat over it. Lastly you go with a blend coat of your base colour (RAF Night) and you can achieve somewhere near the tones and shades you see on the wartime photos.
So reference wise I'm looking at some of these:
First came the black primer layer of Mr Finishing Surface 1500 then the marble coat:
Then a careful blending with Mr Paint RAF Night gives something near:
Next was the Dark Green/Dark Earth uppers, again Mr Paint but this time I used my own variation on black basing and sprayed the base coat, then various shades of green or brown and even a little yellow, then the base colour again highly diluted to act as a blend coat. This gives lovely tonality to the camo. While I was on the wings, I sprayed the roundels too with the same method to obtain some fading effects. TopNotch masks as always.
The insignia came next with the iconic G George and ED932. The TopNotch masks are again superb but you need to be very careful with the ED mask. There are some very fine parts to it easily torn but they look bloody brilliant when they're on, better than any decal:
With such letters as 'A's I work back to front so to speak. I first place the negative bit on first ( the bit that will eventually be painted) as it's just like placing a decal. You then place the positive bit exactly over it before peeling the 'letter A' away to leave your perfect mask. Don't forget to put the small triangle in as well before peeling away though (like I did!)
or you don't get an A like this:
Paint is marking red. The roundels are done in the same style, again VERY carefully.
I popped the wings on at this point just to get the line up for the green and brown between the fuselage and the wings and realised just how big this thing is, as you can see by the foot rule in the picture
So bare camo done bit of shading and the rest next
As ever thanks for looking. Next installment sooner than you think
Edited by CraigH
Dirtying up wise it's a bit of a balancing act. Everyone says these were new aircraft and they were. But they arrived about two weeks before the raid and were flown hard as hell in training so definitely weren't pristine.
So all surfaces were given a double coat of Alclad Aqua Gloss. It sets hard as nails in 24 hours.
Decals next, just the tiny stencil ones. All black and red lines were painted on. Even with two coats of gloss a couple of them silvered a bit which is why I hate em. They also lift at the drop of a hat if anyhting like masking tape goes near them so they need another coat of varnish after micro sol and set have been applied. HK have made a boo boo by the way with the one with the dinghy release instructions
It's shown as going behind one of the upper escape hatches, not sure why. It goes aft of the main crew door and should be in red. There's a release cable for the dinghy there
Then upper surface panel lines were very carefully shaded with a 60:40 mix of Tamiya red/brown to flat black, diluted to about 1 drop paint to 9 drops thinner. Night surfaces shaded with pure black thinned to the same consistency.
Not never EVER pre shaded PLEASE. Pre shading should be a capital offence IMHO. The only thing that comes from under the paint is corrosion. Also you don't get the checker board effect. Every panel line isn't dirty. Subtlety is everything
After that, I pin washed all the panel lines themselves with black for the dark surfaces and dark brown for the uppers. Excess wiped off with odourless thinner. At the same time some random dirt streaking was applied using the same black/brown diluted mix. (I'm not much of a Chris Wauchop worshipper honest LOL)
Lastly on the wings, the ailerons were shaded by covering the high surfaces with thin strips of masking tale then spraying dark over them. When you remove the tape the ribs stand out in relief
So basic weathering is done (similar applied to the tail fins of course).
Next up was another of the annoying corrections you've got to make to this kit and it's the formation lights on the rear of each wingtip. On this model they appear as three separate lights protruding from the rear of the wing.
They should sit, from all the conflicting reference I've searched through, behind a blue glass cover similar to the green and red nav lights at the front of the wing. (note to self yet again, think long and hard before you hack the wingtip off of a £400 kit). As you can probably see from the photo it's a bit too late as I've started. Problem is I had no clear plastic to fit. Thankfully, the fact it's a blue glass cover meant it could be polished a bit under super clear so I let in a piece of perspex,
filed to shape, polished and sprayed Tamiya clear blue and it thankfully came out OK...on both sides!
Clear red and green sprayed nav lights and all looks well.
Next comes the little matter of the raison d'etre of the whole aircraft, the upkeep mine (not a bomb).
HK's mine still has the wooden slatting that Wallis discarded on the final trials as the mine bounced better without it.
Rather than fill and sand all that lot, I tried rolling a piece of 1/10000 plastic sheet round to smooth it out and it worked a treat. The seam will be hidden under the aircraft belly when it's installed. Spray with Mr Finishing surfacer then the debate about the finish can start.
Some say black, some olive, some red oxide primer. I like red oxide primer as it gives a bit of contrast so that's what I went with. I also think it ties in with the stories of the bombs only being filled with Torpex the morning of the raid and still being warm to the touch in the afternoon.
For a bit of contrast and effect, I sprayed with steel then chipping solution before a top coat of Tamiya hull red which is pretty close to oxide red primer. Then a bit of highlighting and some gentle brushing with a soft wet toothbrush and a nice effect of a bit of loss of primer comes through.
As for the preparing of the bomb bay to take the upkeep it's a bit of a minefield (no pun intended)
The drawings for the cradle aren't very clear the three pieces need to lean against each other.
Once you've made up the cradle the instructions give you a placement point up against two small square stops. It's wrong. The diagram below shows the correct placement at two similar stops further toward the nose.
The motor for rotating upkeep is hidden away inside the bay but I sprayed it black, drybrushed it and added hydraulic pipes for the hell of it
The belt drive assembly got a makeover as well. I originally thought it was a chain mechanism and was going to replace the chain with actual chain. Good
job I didn't as the drive was provided by a vee belt. The pulley however needed a groove in it then I can paint the belt tyre rubber and the exposed pulley in a steel colour
Perhaps the most contentious issue surrounding Upkeep is the question of fuses and fusing, Why does it matter for the model when it can't be see? Oh believe me it does!
Upkeep had two types of fuse, three hydrostatic fuses designed to cause detonation at 30 feet and, here's the elephant in the room, a self destruct fuse to stop it falling into enemy hands. The SD fuse consisted of a rip off pin that, when pulled out of the end of Upkeep, triggered a spark which lit a length of fuse which in turn, after 65 seconds would ignite the charge and explode the mine. All very Heath Robinson but effective.
So what's the problem? Well, for many years the belief was that the pin was ripped out as the caliper arm which held upkeep in place sprung open to drop the bomb. All very well and good but, if that was the case, an accidental dropping on the ground (as allegedly happened when a WAAF pulled the release handle by the pilot's seat by mistake) would give 65 seconds to clear the aircraft before ...BOOM!
A "safety catch" was needed so the rip off pin remained un-tethered while on the ground meaning an accidental dropping would not rip it out but disengaged just after the aircraft was over enemy territory arming the SD fuse.
How that was achieved? A claw fastened to the starboard caliper arm was fastened to a cable running to the cockpit ove the outside of the airframe. This claw could either be open, and not locking onto the rip off pin, or closed and grasping it,
Before take off and until over enemy territory, the claw was open. Once over enemy territory, the cable was pulled, closing the claw over the rip off pin and arming the fuse.
There;s now evidence for this in this photo of Les Monroe's craft showing the chafing of the cable over the airframe.
Also of the pulley the cable ran over before it entered the cockpit.
Put it all together and it's starting to take shape.
Last tiny iccle thing that's really bugged me since I noticed it is the crew door. I noticed it had a lip on the inside. How could it when it opened INWARDS????
That's gone
As ever, thanks for looking. Please feel free to challenge my musings, it's how we all learn after all.
Just Exhaust staining and oil and grease and I think I'm almost there. Phew
Last leg now. I added the trailing aerial weighted end made of biro ball bearings dipped one at a time into CA and formed into a string. The static between them is a nightmare though.
Exhaust staining next. There are many and varied patterns but some things seem constant across most aircraft.
  • The outer engines only get white lead deposits on one side
  • Undersides are quite white
  • The exhaust shrouds have some consistent patterns and, frequently, a white cone of lead
I didn't want too heavy weathering so worked from images such as these:
So. for better or worse, here's what I came up with. This is a bit of a montage with the wings partly on. I took these now as I won't fix the wings on properly until it's ready to be collected, simply as I'd be too scared to take them off again now and I've nowhere tp store it with the wings on it's too flippin' big.
Aerials wise, as you'll see in the pics, I've added both fin to cockpit ones although I think the port side one was only used if an extra R1155 receiver was positioned at the navigator's station.
The long Gee MkI whip aerial protrudes from the canopy near the DF loop and I've added the VHF aerial shown on Gibson's Lanc front starboard in the nose.
The other two are Standard Beam Approach (forward top of fuselage ) and the rear whip aerial is the TR1196 designed for air to air and air to ground communication. Trouble was, it wasn't much cop for air to air which is why the dams planes had the VHF systems fitted.
So just a bit of oil and grease to add and a diorama base to build and she's done.
Attempted reproduction of the iconic shot of Gibson's Lanc although in that one the wooden slatting around the mine is still present which points at the photo being taken while training.
1 hour ago, brahman104 said:
Incredible job Craig!
I never knew the cable ran on the outside to the cockpit for the mine. Learn something new every day!
Well done :)
Craig
Many thanks
  • 7 months later...
Well, it's been a while! The gentleman who commissioned this beast has had his extension built and his model room is ready to be furnished so I can take the Lancaster out from its wings off storage in my cupboard and finally get to making the diorama it's going to sit on.
First up, accuracy. Open the can of worms and shoot me down in flames but I've done a bit of digging and as I'm sure many of you know, Scampton was a grass airfield until Autumn 1943. The question is were there any frying pan type hard standings around before then?
I've found a couple of diagrams from local authority documents which show the airfield in 1939 with a grass runway and all the buildings down the bottom corner.
The only hardstanding appears to be around the C hangers and offices with no hard perimeter track either so I've decided to do a concrete/ grass split diorama for a bit of variety
Using a black 20mm thick foam insulation board with a perfect texture for concrete, the first stage was to split what will be grass form the concrete. It didn't need to be circular as there's no frying pan hard standing. The concrete blocks were, apparently 10' x 20' which equates to 190 x 95 mm so this was marked out using a rounded end pencil to give the expansion gaps in the concrete.
Also at this point, I marked in some random cracks.
Next It was spray a lighter shade of grey than the base polystyrene in a swirly pattern to begin to get some variance. The same again with a lighter shade of grey and less swirliness and finally a blend coat of white with a drop of black in there to bring it all together.
After that, the expansion gaps were carefully filled in along with the cracks. Any over paint can be blended into the exterior to create a stained look which often happens with concrete wherever water collects.
I need to add a few flecks of black and white paint by flicking and then some oil stains and it'll be on with the grass.
The spitfire is totally out of scale, I just wanted to see how it looked. It's going on an all grass base.
As ever thanks for looking and see you for the grass shortly
4 hours ago, Finn said:
Craig here is a video of a Lancaster squadron at RAF Scampton in 1942 which might be of help:
https://www.iwm.org.uk/collections/item/object/1060021063
Jari
Jari thank you so much! this is brilliant. I reckon I can see a couple of instances of differing surfaces there :D. Might just be hard dirt to grass but I reckon this looks convincing
