Martinnfb Posted July 21, 2020 Share Posted July 21, 2020 Amazing work, thank you for sharing. Lothar and Out2gtcha 2 Link to comment Share on other sites More sharing options...
shark64 Posted July 25, 2020 Share Posted July 25, 2020 next is the two seater, right? Link to comment Share on other sites More sharing options...
Etienne Posted July 25, 2020 Author Share Posted July 25, 2020 If I can do it using the work already done… Not sure about it. Kagemusha 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted July 25, 2020 Share Posted July 25, 2020 I hope you do produce a two-seat cockpit. Link to comment Share on other sites More sharing options...
crobinsonh Posted July 25, 2020 Share Posted July 25, 2020 Wow - I absolutely love what you are doing. I would sign up for the single seater as well as the twin seater Mirage 2000. Lothar 1 Link to comment Share on other sites More sharing options...
Stokey Pete Posted July 25, 2020 Share Posted July 25, 2020 Mightily impressive work there sir. Link to comment Share on other sites More sharing options...
Etienne Posted August 8, 2020 Author Share Posted August 8, 2020 Hi All, Gas throttle: I made several test prints of the whole cockpit, using different resin types, but never totally satisfied. It took 22/23h of print, so residual resin tends to harden by itself. So I decided to cut the rear part from the main one. Far better, especially for rear one, much precise in details: Landrotten Highlander, thierry laurent, LSP_Kevin and 11 others 13 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted August 8, 2020 Share Posted August 8, 2020 Looks fantastic Etienne. Link to comment Share on other sites More sharing options...
scvrobeson Posted August 8, 2020 Share Posted August 8, 2020 Excellent work, especially after the modification. I'm a neophyte to the world of 3D printing, but will those lines on the top of the electronic boxes remain visible, or will those need to be sanded out on the final product? Matt Link to comment Share on other sites More sharing options...
CZPetrP Posted August 8, 2020 Share Posted August 8, 2020 This is great Job. Nice Link to comment Share on other sites More sharing options...
Etienne Posted August 8, 2020 Author Share Posted August 8, 2020 30 minutes ago, scvrobeson said: Excellent work, especially after the modification. I'm a neophyte to the world of 3D printing, but will those lines on the top of the electronic boxes remain visible, or will those need to be sanded out on the final product? Matt I'm not sure to have enough courage to sand the lines, but keep in mind that picture is made with a 105mm macro lens. Every detail/"error" is captured scvrobeson 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted August 9, 2020 Share Posted August 9, 2020 Good to know. Figure with primer and paint on as well, you probably won't see the lines. Matt Link to comment Share on other sites More sharing options...
Etienne Posted August 16, 2020 Author Share Posted August 16, 2020 Hi All, On advice from a fair guy, I test a print at 5s exposure time. It looks better. By the way, I tried to make grills on IP cover. Hard job, hope it will make sense at printing. Lothar, spyrosjzmichos, chrish and 6 others 9 Link to comment Share on other sites More sharing options...
chrish Posted August 16, 2020 Share Posted August 16, 2020 That’s freaking amazing!! Link to comment Share on other sites More sharing options...
shark64 Posted August 16, 2020 Share Posted August 16, 2020 Are you planning to update the Instrument panel as well into digital display? Link to comment Share on other sites More sharing options...
