Uncarina Posted April 13, 2020 Share Posted April 13, 2020 Great work on the cockpit Nick! Cheers, Tom Link to comment Share on other sites More sharing options...
mozart Posted April 13, 2020 Share Posted April 13, 2020 (edited) Good progress Nick, hope the oleo leg turns up whilst you’re autumn cleaning! Edited April 13, 2020 by mozart Link to comment Share on other sites More sharing options...
Cheetah11 Posted April 13, 2020 Author Share Posted April 13, 2020 Hi Max 4 hours ago, mozart said: Good progress Nick, hope the oleo leg turns up whilst you’re autumn cleaning! I have turned my modeling room upside down with no luck. The problem is the oleo legs are not even listed in the plans as spare parts.Then the legs still need a few plastic parts. I will have to get another kit and ask someone to copy the part in metal or see if someone in the modeling community has build one in the flying pose. This is going to be a long term fix. In the mean time not to stall this build I have made a contingency plan. BTW I love your vacu-form Lightning. I did a Falcon 1/48 Canberra in 1992 but in those days I could not find suitable wheels, so it was sold on. I am watching your build with great interest. I finished the belly tank last night and it turned out better than expected. Happy modeling Nick BradG, johncrow, Madmax and 4 others 6 1 Link to comment Share on other sites More sharing options...
Padubon Posted April 13, 2020 Share Posted April 13, 2020 I am very impressed with your work. I started to build the same kit about 15 years ago but I lost that battle. Outstanding job! Cheetah11 1 Link to comment Share on other sites More sharing options...
jenshb Posted April 13, 2020 Share Posted April 13, 2020 Could you not order a spare part from Tamiya. I know the post is a bit messed up at the moment, but hopefully things will get more normal before the groupbuild ends. Link to comment Share on other sites More sharing options...
Madmax Posted April 13, 2020 Share Posted April 13, 2020 It's in the cat Nick... Cheetah11 1 Link to comment Share on other sites More sharing options...
Cheetah11 Posted April 14, 2020 Author Share Posted April 14, 2020 Hi Jens 16 hours ago, jenshb said: Could you not order a spare part from Tamiya. I know the post is a bit messed up at the moment, but hopefully things will get more normal before the groupbuild ends. I will try and contact Tamiya. We unfortunately have to work through our local hobby shop ( yes, we still have one) and the cost escalates. The local importer only gets a Tamiya shipment every six months or so, so depending on the timing it could be a long time. The joys and challenges of modeling in a quasi third world country. Cheers Nick Link to comment Share on other sites More sharing options...
jenshb Posted April 14, 2020 Share Posted April 14, 2020 I have had excellent service from TIme Tunnel Models here in the UK to order sprues from Tamiya kits. As long as the kit is current, they will get it - normally in a couple of weeks or less. Don't know if they will ship to South Africa though... Might be worth contacting them? Cheetah11 1 Link to comment Share on other sites More sharing options...
Cheetah11 Posted April 17, 2020 Author Share Posted April 17, 2020 A small update. I added a piece of spruce to the tail plane attachment point and drilled a hole into the spruce for a better fit. Upon test fitting the kit parts there was a small amount of play, so this sorted the problem. I added the top deck to the front fuselage. The kit designer would most likely not approve but this sequence works better for me. An uncommon step was present after glueing the parts but at this stage easy to eliminate. Top and bottom fuselage joined and gap filled with superglue. In retrospect it would have been easier to fill the gap with plastic card. Happy Modeling Nick LSP_Kevin, BradG, Dragon and 6 others 9 Link to comment Share on other sites More sharing options...
Cheetah11 Posted April 18, 2020 Author Share Posted April 18, 2020 The top and bottom halves joined so painting can begin. I was fortunate enough to see a real F-15 close up at the Dutch Military Museum in 2017 and tried to replicate the bare metal parts on the fuselage with Alclad ,weathered with thin Tamiya Lacquer. In a one and a million chance I found the missing gear leg. Actually my wife found it outside. The torque links had been nibbled away and there were teeth marks on the primer coat. I scratched the new torque links and it is now good to go. Next to the Tamiya part is the superfluous scratch build part. A day of modeling wasted, but a lot learned on designing in TinkerCad. I have a prime suspect in mind for this near disaster but he is not confessing and keeping a poker face. Happy modeling Nick Lee White, alain11, Derek B and 11 others 7 7 Link to comment Share on other sites More sharing options...
jenshb Posted April 18, 2020 Share Posted April 18, 2020 Glad you found it. Cheetah11 1 Link to comment Share on other sites More sharing options...
mozart Posted April 18, 2020 Share Posted April 18, 2020 Yeah!! The dog dunnit!!! Glad it turned up. Cheetah11 1 Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted April 18, 2020 Share Posted April 18, 2020 Sure you don't have a cat? They are Masters in blaming the dog. Lothar, Cheetah11, mozart and 1 other 4 Link to comment Share on other sites More sharing options...
alain11 Posted April 18, 2020 Share Posted April 18, 2020 pets are forbidden in my room , mine is 75kg and 90cm high , I let you imagine the disaster it can cause with its looong tail Alain Uncarina, Daniel Leduc, Cheetah11 and 1 other 4 Link to comment Share on other sites More sharing options...
mozart Posted April 18, 2020 Share Posted April 18, 2020 44 minutes ago, alain11 said: pets are forbidden in my room , mine is 75kg and 90cm high , I let you imagine the disaster it can cause with its looong tail Alain My wife and I share our craft room. Our cat often sits right in the middle of her sewing, she (the cat) never ever comes near my work bench.......wonder why?! Link to comment Share on other sites More sharing options...
