Neo, Shelby, thanks for leaving a note. I finished the pit (minus the bangseat), I needed to add the throttle and the rudder pedals. I am happy with the result. The Aires cockpit set is really a great addition to this kit: awesome detail, easy to assemble, almost no pour plug to remove, and a good fit, definitely one of their better offerings.
Before closing the fuselage, I wanted to ensure that I will not get a tailsitter so I poured a mix of steel grain and PVA for a bit more nose weight. i did a rough balance test she should be firmly planted on her feet.
and here is the fuselage closed. The cockpit is epoxied on the left side. I plan to glue the engine nacelles before closing the fuselage to ensure a good fit between the nacelle and the fuselage but before doing that I need to clean up the nacelle seams.
So far the fit of the fuselage is close to perfect.
Cheers,
David
Nacelles have a constant thin gap all the way around. I ended up using a shim of plastic card before I fitted the nacelles. This mean I could sand it flush to the fuselage and had a perfect joint when the pods clipped into place.
Thanks Breaker. I noticed the gap too but only after I had glued the nacelles and saw your post. I have some thin styrene I will try to use to fill the gap as it is indeed very regular. If that does work I will use putty but that would be more messy.
Cheers,
David
  • 2 weeks later...
Not a ton of progress on the Su-25 due to spending time on building my two Cobras, but I still managed to finish the first piece of ordnance: the two gun pods (from Aerobonus
More progress soon.
Cheers,
David
  • 7 months later...
I am back. I have to admit I lost much of the drive for this kit over the Summer. Nothing wrong with the kit but I could not get going. We also had new baby in February (our fourth) and as she has become more active, my time at the bench as been reduced, but no complaint as she is strong, healthy and a super happy baby most of the time. I have continued working on the Su-25 but at a snail pace. I should be able to finish it by year end but who knows. This is where I stand now, camo is free hand with MRP colors, decals are from Linden Hill (highly recommended). I used Flory wash (sand) on top and will use grime on the bottom. I was not entirely convinced with the MRP color but their grow on me. I will most likely spray highly diluted sand colored paint to tie everythin together and mute the decals a bit. Still working on the ordnance, which are a pain in the neck.
Cheers,
David
Good work. I see you have exactly the same fit of the canopy and the gun access hatch as I did, they just don't quite fit perfectly.
