Neo Posted November 30, 2018 Author Share Posted November 30, 2018 1 minute ago, R Palimaka said: This is looking great! Fine work on what I understand is not an easy kit. The P-39 looks wonderful in RAF markings, and good save on the clear coat issues. She's going to look fabulous. Richard Thank Richard the only thing i wasent sure prior to clrea coat is the topside gray that looked so dark, i feel it looks better now Link to comment Share on other sites More sharing options...
Neo Posted November 30, 2018 Author Share Posted November 30, 2018 Here is an update i have the mat coat on and i must say im now very happy with it i did run into a oups... after sanding the semi gloss i decided to install all the control surfaces so when i got to spaying the mat i could not place it on the stick like before since the rudder was there.. so in a quick move i made some foam pads that i placed inside the landing gear here you can see the foam legs More later on today R Palimaka, KUROK, MikeC and 2 others 5 Link to comment Share on other sites More sharing options...
R Palimaka Posted November 30, 2018 Share Posted November 30, 2018 Wow!! That looks so sharp! The colours turned out perfectly, I wouldn't have worried about the grey, it's spot on. Link to comment Share on other sites More sharing options...
Neo Posted December 1, 2018 Author Share Posted December 1, 2018 On 11/30/2018 at 10:32 AM, R Palimaka said: Wow!! That looks so sharp! The colours turned out perfectly, I wouldn't have worried about the grey, it's spot on. Thank you. Link to comment Share on other sites More sharing options...
Neo Posted December 1, 2018 Author Share Posted December 1, 2018 So Today i took of the canopy masks and i almost had a heart attack there was this smudge all on the inside of the canopy So using a q-tip i rubbed the interior and to my relief it simply wiped off (in the above pic all the front is wiped) now for the fun part, behind the pilot is a frame with the armoured window so really no access. so i tought about a couple solutions then i noticed that on the right side of the plane there was a tiny gap due to fitment issue. Using a leftover P.E sprue i super glued a piece of paper towel and voila So on the left side there is still some traces since i cannot go below the radio with my too and there is no ways in hell im removing the clear parts!!!! Ive also installed the exhausts and did some weathering to them (not in these pics) i can feel the end is near !! So exiting Anthony in NZ, LSP_Kevin, MikeC and 1 other 4 Link to comment Share on other sites More sharing options...
1to1scale Posted December 1, 2018 Share Posted December 1, 2018 On 9/17/2018 at 9:59 PM, Neo said: i free handed the Camo using Tamiya paints. Ive never used them before and im not convinced i like them yet! This is my second time using masks. i like the result but comparing the effort vs decals i think ill do decal in the future. Im glad i did the masks since some makings are not available otherwise. ive done some small touch ups by brush to the insignia im working on the landing gear now. Ive also going to have to respray the white on one of thee lower wing insignia. Thank you for looking Neo, it’s obviously too late now, but a tip is to use reverse masking, it gives you a much better line in some situations. I have used masks on 80% of my builds, unless there is something I can’t get in a mask. For the 2 color wing roundel, spray the red down first, the stick the center mask in place to cover your red, spray the camo pattern, then place the outer circle and the edge mask in place over everything. Next peel back the outer roundel, spray the blue, now you have a perfect roundel with no color leaking. This technique comb8nes both positive and negative I’ve masking. the four color roundel are a little more complicated, but, here is how to do it. The goal is not to have more than 2 colors meet at an edge. 1. Spray the area white. 2. Put the mask on that covers the white area, spray the yellow area, being careful not to come to the edge of the masked white area. 3. Place the masks over the rest of the roundels. Cover the inner edges of the roundels with so no tape, so no camo color leaks through. 4. Spray the camo pattern on the whole aircraft. 5. Mask the fuselage all around the roundel. 6. Peel back the red center mask and spray it, then put a pice of masking tape over the dot. 7. Peel back the blue portion and spray. you now have a perfect set of roundels that will look s much superior to decals. MikeC 1 Link to comment Share on other sites More sharing options...
Neo Posted December 1, 2018 Author Share Posted December 1, 2018 Thanks for the tip. I think i did you 4 color trick on all of them. Now that you mention it it makes sendlse for the 2 color to use the techinique you mentionned. In my case i paonted with tamiya surface primer. Then masque the entire thing. Camo. Then 1 color at a time. On the bottom wing roundel when i did touch ups i had some white leek but left it there. Ill try you trick next time. I have a 1/24 bf109 tlthat i started and have a full set of masks for. I really love your no more than 2 colors shouldeet at an edge. I will remember that. Link to comment Share on other sites More sharing options...
Neo Posted December 19, 2018 Author Share Posted December 19, 2018 Well guys im extremely exited to announce the end of this build !!!!! After a long full year this is my only finished kit for 2018 ! its been allot of fun and im really satisfied with the result. I did chicken out on the weathering !! but i didnt want to screw this one up! cockpit left left cockpit right right front top bottom display case Thank you all for following allong Trak-Tor, MikeMaben, D.B. Andrus and 7 others 10 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 19, 2018 Share Posted December 19, 2018 Wow really great effort on this one with a tremendous result! Well done Link to comment Share on other sites More sharing options...
Neo Posted December 19, 2018 Author Share Posted December 19, 2018 30 minutes ago, Out2gtcha said: Wow really great effort on this one with a tremendous result! Well done Thanks. Really means allot Link to comment Share on other sites More sharing options...
BiggTim Posted December 19, 2018 Share Posted December 19, 2018 (edited) Looks great! you don't see those a lot. Except for that puny P-38 in the wrong scale next to it. Edited December 19, 2018 by BiggTim Link to comment Share on other sites More sharing options...
Fvdm Posted December 19, 2018 Share Posted December 19, 2018 Wow, this a real beauty! Link to comment Share on other sites More sharing options...
MikeC Posted December 19, 2018 Share Posted December 19, 2018 Looks absolutely great. However, hope you won't mind a minor feedback item? The ailerons are deflected, which is a nice touch, it adds even more to the overall effect; but the stick is central. Intended as constructive feedback, not destructive criticism: it's a superb Cobra, and you certainly don't see many RAF examples in this scale. Link to comment Share on other sites More sharing options...
dodgem37 Posted December 19, 2018 Share Posted December 19, 2018 Really like what you've done. Good show! Sincerely, Mark Link to comment Share on other sites More sharing options...
TorbenD Posted December 19, 2018 Share Posted December 19, 2018 Lovely work Torben Link to comment Share on other sites More sharing options...
