fozzy Posted February 8, 2017 Author Share Posted February 8, 2017 ...and finally!......a shot of the in complete top half just placed on top!......... Well done for keeping up chaps! I have to now play around with the top half the same as I did with the bottom half!.......tops and bottoms!...I don't know! until the next post................. Cheers Fozzy Shaka HI, sax003, Lars Befring and 3 others 6 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 8, 2017 Share Posted February 8, 2017 '.....and there's more!!!!!' A lot more. Love everything about what you're doing here Fozzy. Great stuff. Great show. Sincerely, Mark fozzy and Shaka HI 2 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted February 8, 2017 Share Posted February 8, 2017 Great show, Martin. Your attention to detail is terrific! Cheers Rainer Shaka HI and fozzy 2 Link to comment Share on other sites More sharing options...
ClumsyDude Posted February 8, 2017 Share Posted February 8, 2017 Huh. Shaking my head in disbelief, Martin ... so lifelike! I also have a stash of wires but it's not as impressive as yours. Cheers Jim fozzy 1 Link to comment Share on other sites More sharing options...
TorbenD Posted February 8, 2017 Share Posted February 8, 2017 Goodness me! Impressively organised chaos... loving it! Torben fozzy 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted February 9, 2017 Share Posted February 9, 2017 Awesome, Fozzy! Your'e such a resourceful (and "unlazy") "miniaturization engineer"! fozzy 1 Link to comment Share on other sites More sharing options...
brahman104 Posted February 9, 2017 Share Posted February 9, 2017 You Sir, are totally nailing this bomb bay. All your details look spot on, believe me, I've been studying this area for quite a while now I really like your bomb door retract gearboxes. I've got to get onto them at some point soon. Also, very clever use on splitting the bomb bay into upper and lower halves instead of the much more traditional left and right sides. I think this area calls for such creative thinking. Loving this build Martin! Craig fozzy 1 Link to comment Share on other sites More sharing options...
Gerhard Posted February 9, 2017 Share Posted February 9, 2017 Dont know why you call yourself fozzy, there is nothing fuzzy about your work. Outstanding!!! fozzy 1 Link to comment Share on other sites More sharing options...
fozzy Posted February 9, 2017 Author Share Posted February 9, 2017 Cheers guys for all your comments! You Sir, are totally nailing this bomb bay. All your details look spot on, believe me, I've been studying this area for quite a while now I really like your bomb door retract gearboxes. I've got to get onto them at some point soon. Also, very clever use on splitting the bomb bay into upper and lower halves instead of the much more traditional left and right sides. I think this area calls for such creative thinking. Loving this build Martin! Craig Hi Craig....in reference to the upper and lower design of this build......I thought long and hard on how I was to achieve scratching all the detail...I knew I had to construct the whole thing in two halves..and the clincher was that it was going to be easier to marry the detail together doing an upper and lower design!...I think if I had done the left and right halves I would have been in a whole world of trouble ! I talk from experience as I tried doing a B17F many many moons ago ....probably late 80s!!....using the traditional method of the two fuselage halves on re vamping an old Revel kit in 1:48 scale....it was a night mare.....old photos...but here it is....... So much easier top and bottom method! CODY and Guyman1 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 9, 2017 Share Posted February 9, 2017 This is just unbelievably realistic work, Martin! Kev fozzy 1 Link to comment Share on other sites More sharing options...
fozzy Posted February 9, 2017 Author Share Posted February 9, 2017 This is just unbelievably realistic work, Martin! Kev Cheers Kev! Link to comment Share on other sites More sharing options...
fozzy Posted February 16, 2017 Author Share Posted February 16, 2017 Hello again everyone Since I last posted I had some concern as to how I was going to display the detail of this section of the build. After a lot of thought I realized that because this is a continuation of the front end ....and if I am to continue down the fuselage then I have to keep the display the same as how I started this project....ie some of the top sections removed so one could look down into the model...as I did with the front end of this B17G.......... All I have to do now is cut away some of the top panels...which I have now done........ Looks like a very strange photo but when I place the upper section which houses the life raft then it will all make sense...I hope!!...well I am confident it will look ok! I made some little bomb bay lights out of scraps...the lamps were made from cutting off the ends of an old 1:72 scale bomb.....and the lenses were made from vac formed clear plastic....... They were then painted and glued into position...... all wired up and painted and job done! Okay then......it was time to at long last bring the two halves together permanently....with the aid of super glue and white glue. ...but before that I had to make a little door which connects the cockpit with the bomb bay and add a few more wires and cables. I had to do this before putting the halves together else I would never be able to get my fingers in the bomb bay to attach them!........ Photos coming up....next post................. sax003 1 Link to comment Share on other sites More sharing options...
fozzy Posted February 16, 2017 Author Share Posted February 16, 2017 So here we have the bomb bay as it is at the moment........... So I think so far so good! So now I have to scratch build the bomb racks....make a frame work for the rear bulk head and then fix the life raft assembly on the top!......and that's just half of the work to finish this section! On wards and upwards! Cheers Fozzy 109, TaffyMan, Lars Befring and 3 others 6 Link to comment Share on other sites More sharing options...
Shawn M Posted February 16, 2017 Share Posted February 16, 2017 if i didnt know better, I'd claim full scale fozzy 1 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted February 16, 2017 Share Posted February 16, 2017 if i didnt know better, I'd claim full scale 2nd! Hard to believe it's a model. Absolutely stunning work, Martin! Cheers Rainer Shawn M and fozzy 2 Link to comment Share on other sites More sharing options...
