Wouter Posted June 21, 2016 Author Share Posted June 21, 2016 Thanks gents! Indeed a big undertaking, but it is such a cool looking ac. It must have been a bit futuristic in its time. A fellow 388'er! Wonderful work so far, Wouter- if you're like me you'll have that book memorized in due time. Cheers! chuk I hear you, that book is a little goldmine though I had hope for some more external (colour) pictures of the surviving example. Big undertaking! Good luck! (But how do you ever get anything done on such a neat, clean workbench?) Careful photography does wonders, but besides that my desk is more often littered with tools, dust, paint and what else then looking clean Zero77 1 Link to comment Share on other sites More sharing options...
Simmo.b Posted June 21, 2016 Share Posted June 21, 2016 I will be following, I have the 188 conversion to do and seeing how you tackle this bird is helpful and kndpiring Link to comment Share on other sites More sharing options...
Wouter Posted June 27, 2016 Author Share Posted June 27, 2016 Evening all. With the left wing almost finished I'm now working on the right wing. Things do go a litle faster now I know what to do. I thought I give you guys a little picture update of the enhancements I made on the power egg. So here it goes: This part needs a steeper curve So let's cut the part off Then cut off another 4.5 mm from that like this Then take a coarse file and start to file in the direction of the arrows. The center part needs to be thinned with about 1 mm. And after cleaning things up you should end up with something like this and glue the altered part back on Then the top part. Again look how thick the casting is. That's no good scale wise. here I marked which part to thin this does the trick Right, class dismissed Spads57, LSP_Paul and Greg W 3 Link to comment Share on other sites More sharing options...
amurray Posted June 28, 2016 Share Posted June 28, 2016 A man serious about proper detail! Excellent! Link to comment Share on other sites More sharing options...
LSP_Ray Posted June 29, 2016 Share Posted June 29, 2016 Nice work! Link to comment Share on other sites More sharing options...
monthebiff Posted June 29, 2016 Share Posted June 29, 2016 Coming along nicely. Regards. Andy Link to comment Share on other sites More sharing options...
Jack Posted July 3, 2016 Share Posted July 3, 2016 (edited) Wouter, very nice work, finally found your thread (with your help), not being a Luftwaffe affectionado but this is coming along very nicely, have fun! Jack. Edited July 3, 2016 by Jack Link to comment Share on other sites More sharing options...
LSP_Paul Posted July 3, 2016 Share Posted July 3, 2016 The modifications you did to the engine nacelle is a huge improvement. Keep up the great work. Paul Link to comment Share on other sites More sharing options...
Wouter Posted July 4, 2016 Author Share Posted July 4, 2016 Thanks guys! Soldering on with this beast. Got the basic work on the wings completed. and the wingtips. These went on pretty straightforward. Just a bit to thick in comparison to the Revell wings. After sanding and some putty all was well. Just need to rescribe panel lines. I then started constructing the fuselage. Just build as Revell intended and cut off at the given points. Take note that the top closing panel needs some blending in around the panel lines, more then I expected. The Ju388 tailpiece is a drop in replacement. I made a little error on the fuselage cut, so I needed to revert to using a shim and some putty. Sadly the panel lines are pretty week and feature a inconsistent depth. Besides that they didn't form a continuous line with the original Revell fuselage. Fill and rescribe. Sadly the resin is a bit brittle and this makes it very hard to get an even panel line. I tried my best but as you can see in the pictures I still have some cleaning up to do. I also tacked the 'bodenwanne' in place. Again the panel lines are not very nice/straight/even depth. Besides that you have to scribe the camera panels yourself (I marked the positions). I guess Pastor did this so you can choose to build the bomber version or the recce, but since I hate scribing.... Anyway, the bodenwanne does fit pretty good if you clean up the inside as per instructions. After glueing some blending with putty will do the job. And it gives your model a hefty weight which feels rather nice holding it in your hand. Last but not least I made an early mock up with one of the propellers. Guess that will turn out OK with some more work. Sorry for the crappy pics. I just had my phone at hand. Cheers, Wouter blackbetty, Spads57, dutik and 2 others 5 Link to comment Share on other sites More sharing options...
Iain Posted July 4, 2016 Share Posted July 4, 2016 Awesome project Wouter! Iain Link to comment Share on other sites More sharing options...
Rick K Posted July 4, 2016 Share Posted July 4, 2016 whew! looking good! Link to comment Share on other sites More sharing options...
LSP_Paul Posted July 4, 2016 Share Posted July 4, 2016 The tail and camera pod are coming along nicely. I found the same as you when I did my AIMS 88G-6 conversion. The resin was brittle yet hard as nails but seemed to shape well when a dremel tool and "much more coarse than I expected" sandpaper was required to reshape the nose wings and tail to match the Revell parts. From what you're showing us now though, nobody but you and us watching will ever know you did a thing, and this will be a spectacular kit. Keep up the great work! Paul Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 4, 2016 Share Posted July 4, 2016 You're doing great work on this one, Wouter, and it's shaping up very nicely already. Keep it up! Kev Link to comment Share on other sites More sharing options...
monthebiff Posted July 4, 2016 Share Posted July 4, 2016 fantastic progress on this one. Regards. Andy Link to comment Share on other sites More sharing options...
LSP_Ray Posted July 5, 2016 Share Posted July 5, 2016 Great progress, Wouter! I think the parts are blending in fine. Link to comment Share on other sites More sharing options...
