mozart Posted May 19, 2016 Share Posted May 19, 2016 Quite a masking job there Carl but I like your technique. The shot of the Arado on your jig shows off her beautiful lines a treat. Max Link to comment Share on other sites More sharing options...
Azgaron Posted May 19, 2016 Share Posted May 19, 2016 Nice masking! HÃ¥kan Link to comment Share on other sites More sharing options...
BloorwestSiR Posted May 19, 2016 Author Share Posted May 19, 2016 "Aizu" tape? Where are you hearing about/getting this stuff? Anyway, masking looks really good. Shaka, Aizu tape is a brand of masking tape from Japan. It comes in many different widths which is the big appeal. The thinnest is 0.4mm wide which i use for masking the stripes on ejection seat pull handles. They're about ¥200 for a roll from Japan So YOU bought all the Aizu from Wheels&wings!!! It'll look great after painting and removing the masking on the canopy. That's one serious clamp!! Don It wasn't me Don! The clamp is nice because I can adjust the space between the jaws and therefore the amount of pressure it's applying. Quite a masking job there Carl but I like your technique. The shot of the Arado on your jig shows off her beautiful lines a treat. Max Thanks Max! You're right that now that I've got a nacelle on, you can really see the lines of the plane coming through. Nice masking! Håkan Thanks Håkan! A bit of a pain but worth it. Carl Link to comment Share on other sites More sharing options...
The1971Show Posted May 19, 2016 Share Posted May 19, 2016 Haven't checked in on your build in a while, and boy was I in for a surprise! The pit looks superb! One question, did you get to Canadian Trash or any of the other places mentioned for the UV glue? Just wondering how that worked out (I have a CT at the end of the street and am hoping not to have to ask any of the staff what aisle I'll find it in...) Darren Link to comment Share on other sites More sharing options...
BloorwestSiR Posted May 19, 2016 Author Share Posted May 19, 2016 Thanks Darren, I haven't made it to a Crappy Tire yet to check out the Bondic pen. Maybe this weekend as I have to help a friend or up some shelves. Carl Link to comment Share on other sites More sharing options...
dmthamade Posted May 20, 2016 Share Posted May 20, 2016 I used the Bondic pen to add lenses to a instrument panel gauges and rivets on a couple of bombs, worked very well for both tasks. Don Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 20, 2016 Share Posted May 20, 2016 Nice work, Carl. Looks like it's ready for paint! Kev Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 20, 2016 Share Posted May 20, 2016 Carl Super job of masking the canopy and looking forward to the paint starting to fly after the the nacelles are on and cleaned up a bit. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
BloorwestSiR Posted May 21, 2016 Author Share Posted May 21, 2016 I used the Bondic pen to add lenses to a instrument panel gauges and rivets on a couple of bombs, worked very well for both tasks. Don I think I'll have to give one of those a try Don. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted May 21, 2016 Author Share Posted May 21, 2016 Nice work, Carl. Looks like it's ready for paint! Kev Thanks keV. It's certainly getting there. Maybe this long weekend? Link to comment Share on other sites More sharing options...
BloorwestSiR Posted May 21, 2016 Author Share Posted May 21, 2016 Carl Super job of masking the canopy and looking forward to the paint starting to fly after the the nacelles are on and cleaned up a bit. Keep 'em coming Peter Thanks Peter. I don't mind masking too much since there's usually a great reveal after. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted May 21, 2016 Author Share Posted May 21, 2016 So onto some progress on the build. Even with my efforts to improve the alignment of all the nose parts, there was still the need for a bit of filler. I used Mr Surfacer 500 for that and finally figured out what this tool I've had for a few years was for. It's to help smooth out putty both during application and after. The tip is a soft foam that you dip in Mr Color Thinner and then use to smooth out the putty. You go from this: To this: It really helps prevent the loss of surface detail due to sanding. I still had to do a bit of sanding for the final coat of Mr Surfacer but that was with 1000 grit sandpaper. BradG 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted May 21, 2016 Author Share Posted May 21, 2016 Once i had the filling done, I sprayed a coat of RLM 66 on the canopy rails. Once that was dry, I did a coat of semi gloss black. The canopy frames are black with silver rivets. Fly give you decals for these but I'm a bit wary that they might not conform well so I figured the black base will help. The end result: Somehow, I've managed to get a piece of tape on the inside of the canopy. Not much I can do about that. There's also a small but of fogging from the CA. BradG, Learstang, Shaka HI and 1 other 4 Link to comment Share on other sites More sharing options...
Guest Posted May 21, 2016 Share Posted May 21, 2016 I love it !......Harv Link to comment Share on other sites More sharing options...
Shaka HI Posted May 21, 2016 Share Posted May 21, 2016 Lovely work(despite the stray tape)! I have the same tool! Link to comment Share on other sites More sharing options...
