jean luc Posted September 6, 2015 Share Posted September 6, 2015 I show you my way of life has done to give the patina of my exhaust for that you need graphite batonnet ocher pastel battonnet also the same powder are also very well everything is in the shop of art easily must be an old paintbrush ca and a finger that easily in the hand (personally I 10 is constantly on me) and 10 minutes in front of you to start I painted the exhaust with black MATT I sand the stick to make ocher powder coats the ponpon I rest my brush I apply the powder in the corner to the manner of rubbing a juice matt paint takes on the important fact be slightly grainy what allows good grip pigments Uilleann, D.B. Andrus, CANicoll and 2 others 5 Link to comment Share on other sites More sharing options...
jean luc Posted September 6, 2015 Author Share Posted September 6, 2015 I take this a graphite stick same treatment by against this coup will not peinceau c is the doigth intervenes I rub the exhaust with the said finger I will return with the same instrument prescision to give final reflection remains only as luster quickly with a soft cloth here is b 17 on there as it gives more detail this I hope you'll help D.B. Andrus, Fooesboy, Zero77 and 8 others 11 Link to comment Share on other sites More sharing options...
Barry Posted September 6, 2015 Share Posted September 6, 2015 Thanks you for the tutorial .. absolutely am going to give it a try Peter I am with you Peter! Barry Link to comment Share on other sites More sharing options...
jean luc Posted September 6, 2015 Author Share Posted September 6, 2015 I would personally darker bring out the raw metalic another view of my B 17 Exhaust Daniel Leduc, Uilleann, Out2gtcha and 3 others 6 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 6, 2015 Share Posted September 6, 2015 Very nice tutorial Jean Luc! Thanks for posting it. Kev sandokan 1 Link to comment Share on other sites More sharing options...
Mister J Posted September 7, 2015 Share Posted September 7, 2015 Nice work, both of you :-) James Link to comment Share on other sites More sharing options...
Shadoweng Posted September 8, 2015 Share Posted September 8, 2015 What do you use to keep the graphite and rust powder from continuing to come off? Do you seal it with anything? Looks great BTW. Merci Shadow Link to comment Share on other sites More sharing options...
jean luc Posted September 9, 2015 Author Share Posted September 9, 2015 Hello I do not put anything to fix powders graphite is slightly oily it secures well if you put a liquid product the effect is lost tomv87 and Daniel Leduc 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted September 11, 2015 Share Posted September 11, 2015 Yes but if this gives a beautiful metal effect there is a major problem with lead (graphite) powder! Indeed, it is quickly loosing its bright look over time. I guess this is the result of an oxyding process. So, use it cautiously. This may be appropriate if you want to get this dull look but otherwise... Link to comment Share on other sites More sharing options...
cbk57 Posted September 11, 2015 Share Posted September 11, 2015 What about using a metalic pigment like from Mig or AK instead? I like the technique described and was thinking of using something along that line. Link to comment Share on other sites More sharing options...
CANicoll Posted January 13, 2016 Share Posted January 13, 2016 Jean Luc and all, Many thoughts for the tutorial, and for the added comments as well. Definitely will be trying this on my current P-51. Chris Link to comment Share on other sites More sharing options...
tomv87 Posted January 13, 2016 Share Posted January 13, 2016 Jean Luc- A very nice effect you have going there! Thank you for sharing your technique! Regards Tom Link to comment Share on other sites More sharing options...
Iain Posted January 13, 2016 Share Posted January 13, 2016 Missed this first time around - brilliant thread! Iain Link to comment Share on other sites More sharing options...
mozart Posted January 13, 2016 Share Posted January 13, 2016 Missed this first time around - brilliant thread! Iain Me too, it's just in time for my Spitfire exhausts which I assembled yesterday! Max Link to comment Share on other sites More sharing options...
