geedubelyer Posted April 5, 2015 Share Posted April 5, 2015 Neat work Peter I might try adding foil over rivets and see what that looks like... TTFNPeter Or could you use thin strips of cigarrette paper as an alternative to foil? It is very thin. airscale 1 Link to comment Share on other sites More sharing options...
Iain Posted April 5, 2015 Share Posted April 5, 2015 That skinning is the best I've ever seen Peter - absolutely beautiful... Iain BiggTim, airscale and Uilleann 3 Link to comment Share on other sites More sharing options...
allthumbs Posted April 6, 2015 Share Posted April 6, 2015 (edited) Hi Peter, You continue to amaze us with each new update - inspirational and instructive. Regarding the rudder; are you certain it was metal skinned? My impression was that all of the piston powered Grumman 'cats had taut fabric covered control surfaces. And that close-up photo of the warbird seems to convey such a configuration, with cloth tape across stitches - but I don't assert anything positively. I bring it up more out of curiosity. Regardless of the actual materials used on the prototype, the rudder you've fabricated for the model looks very convincing indeed. Keep up the good work! Cheers, Rich Edited April 6, 2015 by allthumbs airscale 1 Link to comment Share on other sites More sharing options...
Mick Gannon Posted April 6, 2015 Share Posted April 6, 2015 Peter comparing your work on the rudder an the picture, the first attempt without rivits gives a better impression of the real thing, can't fault what you have done to date, when do I get to cast the engine? Mick airscale 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 6, 2015 Share Posted April 6, 2015 Astounding work Peter! My impression was that all of the piston powered Grumman 'cats had taut fabric covered control surfaces. Mine as well airscale 1 Link to comment Share on other sites More sharing options...
airscale Posted April 6, 2015 Author Share Posted April 6, 2015 Regarding the rudder; are you certain it was metal skinned? My impression was that all of the piston powered Grumman 'cats had taut fabric covered control surfaces. And that close-up photo of the warbird seems to convey such a configuration, with cloth tape across stitches - but I don't assert anything positively. Keep up the good work! Cheers, Rich Astounding work Peter! Mine as well do you know what chaps, I think you are right - I found these pics of a Hellcat and it certainly looks like fabric over a frame so will go with that. I have emailed an F7F owner to see if they have any diagrams / info but will work on the assumption this is the case.. thanks for saving me from an(other) epic fail Thanks Peter BiggTim, whiskytngofxtrt, sandokan and 1 other 4 Link to comment Share on other sites More sharing options...
mcbole Posted April 7, 2015 Share Posted April 7, 2015 Peter, I think it's safe to say the rudder was fabric covered. You wouldn't see tape on an all metal rudder. Just the heads of flush rivets. And the bumps are usually Philip head screws holding the fabric to the frame and then the tape applied over it. Your making a museum quality model and it never gets tiring looking for updates ! whiskytngofxtrt and airscale 2 Link to comment Share on other sites More sharing options...
LSP_Paul Posted April 7, 2015 Share Posted April 7, 2015 Peter, I don't know if you have seen this but it may provide some more details for you build. I find Avialogs very useful for scratchbuilding. Keep up the phenomenal work! Paul http://www.avialogs.com/index.php/aircraft/usa/grumman/f-7ftigercat/an-01-85fa-1-pilot-s-handbook-for-f7f-1n-f7f-2n-f7f-3-f7f-3n-f7f-4n-airplanes.html airscale 1 Link to comment Share on other sites More sharing options...
Starfighter Posted April 9, 2015 Share Posted April 9, 2015 This is just unreal! airscale 1 Link to comment Share on other sites More sharing options...
airscale Posted April 15, 2015 Author Share Posted April 15, 2015 anyone got any ideas or theories how this was done? this is the elevator from Guillermo Rojas Bazan's incredible Kingfisher in 1/16th scale ..what material might that be and how on earth was such a fine 'pinking' cut made for the zigzag edges? any ideas or comments most welcome as I am a bit stuck on this... TTFNPeter sandokan and Uilleann 2 Link to comment Share on other sites More sharing options...
geedubelyer Posted April 15, 2015 Share Posted April 15, 2015 (edited) Hi Peter, anyone got any ideas or theories how this was done? how on earth was such a fine 'pinking' cut made for the zigzag edges? any ideas or comments most welcome as I am a bit stuck on this... TTFNPeter I've not read that particular build but I have seen other Rojas Bazan builds and knowing that gentleman's work he might have made a tool specially for the job. Have you come across any sheer fabrics that might lend themselves to the task of skinning the control surfaces of your Tigercat? My cousin's partner does lady's nails and she uses an adhesive fabric with a resin to give strength (please don't ask how it works, I don't know). I wonder if it is available in the beauty section of Boots or similar? Maybe Mrs. Airscale could shed some light on the subject? I was given a small sample to try and was going to use it to replicate linen on a Sopwith Camel but lost the piece I was given. Just a thought. From the photo that you've posted the material looks as though it might even be a very thin heat shrunk/stretched plastic film... Edited April 15, 2015 by geedubelyer airscale 1 Link to comment Share on other sites More sharing options...
Victor K2 Posted April 15, 2015 Share Posted April 15, 2015 Just a guess, maybe he has used the edge of a razor saw to make an imprint on foil,(I have a Scale Aircraft Modelling rule/saw/scribing template that has a saw edge that looks compatible) ? or something along these lines. Hope you find the answer, Bob. airscale 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted April 15, 2015 Share Posted April 15, 2015 Pinking shears. Sincerely, Mark airscale and geedubelyer 2 Link to comment Share on other sites More sharing options...
BiggTim Posted April 15, 2015 Share Posted April 15, 2015 You might be able to do that with matte finish mylar, like the type we use to draft on back in the "old days". I still have a stash of it that I use for scratching stuff and making patterns. You can bend it and put patterns in it very easily, and it paints wonderfully. You might be able to find it at an art supply store, though it is not used much anymore. Otherwise, I could dig mine out and mail you some if you want to try it. The only other idea I have is shrunken silk. Tim geedubelyer and airscale 2 Link to comment Share on other sites More sharing options...
mcbole Posted April 15, 2015 Share Posted April 15, 2015 Peter, Check out www.pink-it.net. They make various size pinking tape for rc scale aircraft. They may have something close. As for what's underneath the tape, prior to using sheet metal screws, the fabric was secured to the ribs with stitching line. In a small scale maybe a piece of fine thread secured under your tape for the correct illusion. Matt geedubelyer and airscale 2 Link to comment Share on other sites More sharing options...
