monthebiff Posted December 24, 2016 Share Posted December 24, 2016 Coming along real nice Mark, the colours look fantastic!! Regards. Andy dodgem37 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 24, 2016 Share Posted December 24, 2016 Brother Bear. Geez .. I'm speechless and still soaking in your weathering - what an approaching and technique. I've learned to never question the how's and why's of your work, as in the end, a true diamond appears. Keep 'emm coming peter Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 24, 2016 Share Posted December 24, 2016 Wow, neat! Love the effect. It would be a good technique for getting fading on enamel paints for me as Ive used the hairspray effect to get similar results, occasionally in concert with a finish sanding pad, but of course you have no choice to use acrylics in that case. Looking forward to more! dodgem37 1 Link to comment Share on other sites More sharing options...
Rick K Posted December 24, 2016 Share Posted December 24, 2016 Happy Holidays to you and your family Mark. Have a super 2017! dodgem37 1 Link to comment Share on other sites More sharing options...
Wolf Buddee Posted December 24, 2016 Share Posted December 24, 2016 Holy Moly m' man! That's really startin' to come together! Fantastic work Mark. Just a suggestion though, if I may? The gasket material around the gun bay cover openings might be a bit too thick! Cheers, Wolf dodgem37 and Anthony in NZ 2 Link to comment Share on other sites More sharing options...
Martinnfb Posted December 24, 2016 Share Posted December 24, 2016 Like the gasket too , If I may..LOL.... I am using sanding technique in order to brig up my riveting, however I am doing it after the insignia and basic marking is all up, that way it all looks unified. something like this Link to comment Share on other sites More sharing options...
dodgem37 Posted January 25, 2017 Author Share Posted January 25, 2017 Thank you everyone for your compliments. I really appreciate them. My apologies for not responding earlier. With the Rex build, 2 Bf109's and this in the paint booth, plus my Honey-Do List, I don't always get to my threads when I should. I apologize for my tardiness. Martin, I'm not trying to make an appearance that is unified. I'm trying to make an appearance that has variation. I'm trying to make an appearance that includes no wear, some wear; showing the 50/50 paint, more wear; showing aluminum, and a not perfect demarcation line; showing aluminum paint. The markings I'll work on later after I figure out how to solve the problems I'm facing with the mechanics to this idea. I ran into a problem executing the idea I mentioned above to Martin that I've finally solved. I has taken two strip-downs of the fuselage to figure it out, but the problem is now solved. It may not be apparent in this image, but the reason why the aluminum area is showing along the demarcation line is because of the tac I am using. I applied the tack onto a futured aluminum base before I painted the sand. But I did not future the sand before I put the tac onto the sand before I painted the blue. When I sanded the tan the tac residue that had adhered to the matte did a couple of things. One, it did not sand well, and two, it made a line as wide as the adhered tac along the demarcation line. To try to remove that line I ended up going all the way to the aluminum. I had to start over. Twice So, after futuring the aluminum, I sprayed on the tans (50/50 and 100%), distressed the tan with a sanding pad, scraped it with an implement, then sprayed a coat of future onto the distressed tan before I located tac onto the tan to make the demarcation line between tan, blue, and light grey. This worked. Hallelujah Chorus! Overall. Showing my intent. Chipped paint, peeled paint, faded paint, aluminum showing at demarcation line. Better than before. Sometimes it's all I can ask. Demarcation line, chipped paint, peeled paint. Nose didn't change. Chipped paint at fasteners, along wing leading edge, wing leading edge gun covers. From below. I'm going to remove the front panel later, at the diagonal, behind the air duct opening. This will leave the front open and show the rods that operate the breather openings. I couldn't satisfactorily render the coolant and oil piping, so the back panel will stay and cover them. Distressed cowling, chipped fasteners, panel lines, Chipped paint at wing leading edge, below cowling. Faded paint on wing, chipped paint, peeled paint. Repaired the trailing edge of the wing fillet. Chipped paint, peeled paint, distressed blue, panel lines. Chipped paint, faded paint. Faded blue toward fuselage, tan toward wing tip. Chipped and peeled paint. Faded blue toward fuselage, aluminum showing above gun bay, blue again toward wing tip. Chipped and peeled paint. Well, that's done. It only seemed like it took forever. Thank you for looking and liking. Sincerely, Mark Shaka HI, Lars Befring, Rick K and 3 others 6 Link to comment Share on other sites More sharing options...
Martinnfb Posted January 25, 2017 Share Posted January 25, 2017 I like your approach Mark, it seems to be closer to the reality then pre/post shading ritual. I am really intrigued by it and can't wait for the final result. Cheers. Martin Link to comment Share on other sites More sharing options...
Mr b Posted January 25, 2017 Share Posted January 25, 2017 lovely work.... the blue looks good rgds dodgem37 1 Link to comment Share on other sites More sharing options...
Wolf Buddee Posted January 25, 2017 Share Posted January 25, 2017 Fabulous paint work Mark! It looks perfect. The landing gear looks a little short though. Cheers, Wolf dodgem37 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted January 25, 2017 Share Posted January 25, 2017 W o W ! dodgem37 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 4, 2017 Author Share Posted February 4, 2017 (edited) Thank you, Gentlemen. Still plugging away. Added Campaign stripes and ran a needle along the panel lines. Added red. Finished up the tail wheel, almost. While I was removing the liquid mask from the door opening mechanism it came off. Something else to fix. You may note 2 colors of Blue-Grey. The deeper of the two is the original. I didn't like my earlier attempt at stripe making so I masked along the panel lines and stripped it down to plastic. All coatings and mixtures are the same but the volume (thickness) of paint and gloss coat I laid down are different. Not crazy about the paint coming off at the gun openings but I'm going to live with it. Overall. Underall. One of the Real Deals in Black & White. Courtesy SAM Camouflage & Markings No. 3 Thank you for looking and liking. Sincerely, Mark Edited February 4, 2017 by dodgem37 KiwiZac, Rainer Hoffmann, BiggTim and 4 others 7 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 4, 2017 Share Posted February 4, 2017 Brother bear Spectacular paint and weathering. What a touch and looking so good. The panel lines have taken on a whole new look after running the needle through them Keep 'em coming Peter Link to comment Share on other sites More sharing options...
ClumsyDude Posted February 4, 2017 Share Posted February 4, 2017 Wow - that needle-along-the-panel-line trick is one to remember, it looks great! Super stuff Mark. Jim dodgem37 1 Link to comment Share on other sites More sharing options...
Rick K Posted February 4, 2017 Share Posted February 4, 2017 geeze Mark. beautifully executed on all counts. the wheel well detail just pops out and pokes my eyes! dodgem37 1 Link to comment Share on other sites More sharing options...
