Sparzanza Posted October 13, 2016 Share Posted October 13, 2016 That looks amazing Mark! dodgem37 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 13, 2016 Share Posted October 13, 2016 Brother Bear Looking mighty good - sure brings back good memories .. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Uncarina Posted October 13, 2016 Share Posted October 13, 2016 Mark, Exquisite work. Your build is a masterful blend of the vibrant and weathered elements of this aircraft! Cheers, Tom dodgem37 and Jeff 2 Link to comment Share on other sites More sharing options...
dodgem37 Posted October 13, 2016 Author Share Posted October 13, 2016 Thank you Gentlemen. I be tryin'! Remainder of imagery: A little out of focus. My apologies. Other side. Red over painted with Future. Green dotted Oxygen Line. Scratch-built front bulkhead. With Starboard Sidewall. With Flash. Without Flash. With Port Sidewall. Another view. Starboard Sidewall against Fuselage. Port Sidewall against Fuselage. Hopefully that's not too much. I have a few more to shoot, tho. I would like to show the Fuselage, Sidewall and Cockpit base assembled in the next posting. Thank you for your wonderful comments and for looking in. Sincerely, Mark KiwiZac, Sparzanza, Jeff and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Posted October 13, 2016 Share Posted October 13, 2016 Now that looks nice !!.....Harv Link to comment Share on other sites More sharing options...
dodgem37 Posted October 13, 2016 Author Share Posted October 13, 2016 Thank you, Harv! The Last Of The Many. Apologies for the out of focus. Thank you one and all. Sincerely, Mark BiggTim, Sparzanza, Bomber_County and 10 others 13 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 13, 2016 Share Posted October 13, 2016 (edited) Brother Bear What a spectacular front office Keep 'em coming Peter Edited October 13, 2016 by Peterpools Link to comment Share on other sites More sharing options...
dodgem37 Posted October 13, 2016 Author Share Posted October 13, 2016 Thank you, Brother Bear! It has turned out much better than I had hoped. Sincerely, Mark Link to comment Share on other sites More sharing options...
Mal_Belford Posted October 13, 2016 Share Posted October 13, 2016 That is a real fine cockpit there.... Looks fantastic. Keep em coming.... dodgem37 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted October 13, 2016 Share Posted October 13, 2016 EXCELLENT work Mark! Having made this kit myself, I know where the weak points are and you have fixed or modified them all, without the benefit of using a Barracuda resin set. I really like the wiring, which is usually missed or crude. For example, the wiring harness coming out of the battery to behind the seat is usually wrong, so your use of tiny wires held together with fasteners is right on the money- along with all your other wiring. Weathering/wear is also very realistic. I think you're missing that little chain that attaches to the flare gun cap on the port side. Easy addition if you care to add it. Cheers, Chuck dodgem37 and Jeff 2 Link to comment Share on other sites More sharing options...
Ironwing Posted October 16, 2016 Share Posted October 16, 2016 Thank you, Harv! The Last Of The Many. Apologies for the out of focus. Thank you one and all. Sincerely, Mark Mark, Apologies aren't needed for focus when the body of work is as powerful as what you've accomplished thus far...Simply superb. Bravo Geoff dodgem37 and monthebiff 2 Link to comment Share on other sites More sharing options...
dodgem37 Posted October 17, 2016 Author Share Posted October 17, 2016 Thank you, Mal. Thank you, Chuck. Thank you, Geoff. There's not much to show, but it's all CHUCK's FAULT! I decided to make it open. I knew the type of chain link used, measured a link in a hardware store (1/2"/12mm), bent thin wire in half, put each end in a vice and twisted to make the chain. Then I slipped a wire thru the hole end, twisted that, punched a disc, drilled a hole in the disc, slipped the eye into the hole, glued, then trimmed. Thank you one and all. Sincerely, Mark monthebiff, MikeMaben, Sparzanza and 4 others 7 Link to comment Share on other sites More sharing options...
chuck540z3 Posted October 17, 2016 Share Posted October 17, 2016 There's not much to show, but it's all CHUCK's FAULT! Thank you one and all. Sincerely, Mark Ha! Excellent job! There's no use going nuts in the engine compartment and not doing the same thing in the cockpit. dodgem37 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted October 22, 2016 Author Share Posted October 22, 2016 Thank you, Harv. My apologies for being late. Thank you, Chuck. Just another hair-brained idea. Still plugging away, in no particular order. Tail wheel and prop/spinner. Primed, aluminum, Future, 50% Chromate Green/50% White, Chromate Green. Scraped edges with a scalpel to show aluminum and 50% coating. Futured, washed with oil paint. I forgot the color. Maybe Burnt Sienna. Flat coated. Other side. Well well. Tail wheel and strut. Other side. Prop/spinner. Playing with Black chalk pastels. Same here. Looks a little thin. Playing with Prismacolor pencils. Cool Grey at exposed aluminum. Some locations rubbed with a cotton bud, others not. Tape is prep for yellow STAY-THE-HELL-OUT-OF-THE-WAY-OF-THE-SPINNING-PROPELLER! tip. Thanks for looking in. Sincerely, Mark Jeff, Rick K, kvlazer22 and 5 others 8 Link to comment Share on other sites More sharing options...
Sparzanza Posted October 22, 2016 Share Posted October 22, 2016 Amazing painting and weathering as always, Mark! These will all make great reference pictures for my second 1/24 Mustang once the first one is completed. I've been considering to weather my Gustav's propeller blades very much like yours with a wide brush and some silver paint, but I'm terrified of messing it up! Not even sure it'd be accurate for a luftwaffle bird anyway, eh. dodgem37 1 Link to comment Share on other sites More sharing options...
