Wolf Buddee Posted September 13, 2012 Author Share Posted September 13, 2012 (edited) Last night and today I managed to get the air intake re-done. While drilling a small hole to accept the actuator cable for the front air intake flap, the drill bit slipped damaging the paint work. Everything I tried to repair the damage didn't quite work out as well as I wanted it to so I stripped off all the paint and started again. This time, working with all the photos I've collected I added a bunch of detail that I had neglected to add the first time, changed a few colours, and added missing rivet detail, again with Archer Fine Transfer rivet decals. I can't tell you enough how much I like these, they're well worth the money. The whole assembly was first painted with Tamiya's fine white primer and then the final colours were Alclad II Aluminum and the inner portion of the filter assembly was painted Alclad Steel for a bit of contrast. There appears to be some slight fit issues now that I've added some of the fastener details to the to the top of the filter assembly but it should be fairly easy to sort out when I install it all. Anyways, here's the pics that show the whole process from start to finish. The 1st pic shows what it looked like originally, the second, what it looks like now, and the rest show the changes made. Cheers, Wolf Edited September 13, 2012 by Wolf Buddee Tomek, Rocat, Model_Monkey and 1 other 4 Link to comment Share on other sites More sharing options...
dodgem37 Posted September 13, 2012 Share Posted September 13, 2012 Check you out!, Wolf. You BAD! Love that. Especially the black contrast. Above the baffle opening there is a rod system. Is that scratched or the kit part. Thank you. Sincerely, Mark Link to comment Share on other sites More sharing options...
Guest Ta152H1 Posted September 13, 2012 Share Posted September 13, 2012 A GREAT lesson on how to set new standards and raise the bar to unbelievably high levels! Hats off to you Wolf! Lou Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2012 Share Posted September 13, 2012 How do you manage to get these REAL spitty parts on your table ??? Really jaw droping work.This is beyond good, my friend ! Please keep us entertained for a bit longer, OK ?..........Harv :bow: Link to comment Share on other sites More sharing options...
richdlc Posted September 13, 2012 Share Posted September 13, 2012 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted September 13, 2012 Share Posted September 13, 2012 (edited) Wolf You're about the only one I know that can turn a small disaster in a positive. The re-work of the intake assembly looks terrific and the Archer rivets are a game maker. Aces Buddy on the assembly. Peter Edited September 14, 2012 by Peterpools Link to comment Share on other sites More sharing options...
Shawn M Posted September 13, 2012 Share Posted September 13, 2012 words dont do it justice.... Well done Wolf. Link to comment Share on other sites More sharing options...
Wolf Buddee Posted September 13, 2012 Author Share Posted September 13, 2012 Gentlemen, thanks all for your kind words! Much appreciated. At this rate though, if I don't start leavin' stuff alone, I'll be still on this build by Christmas. I'm hoping to have it finished by the beginning of October for a show in Vancouver. We'll see............ Cheers, Wolf Link to comment Share on other sites More sharing options...
Wolf Buddee Posted September 13, 2012 Author Share Posted September 13, 2012 Check you out!, Wolf. You BAD! Love that. Especially the black contrast. Above the baffle opening there is a rod system. Is that scratched or the kit part. Thank you. Sincerely, Mark Thanks Mark. The rod system above the front intake opening is all kit supplied detail including the photo-etch linkage rod at the side. The only thing I added was a photo-etch nut at the end of the pivot rod to secure the linkage. The black contrast is actually Alclad II Steel. It looks black in the photos because of my lighting. Here's another pic with the lighting bumped up a bit for better colour saturation. Cheers, Wolf geedubelyer and Model_Monkey 2 Link to comment Share on other sites More sharing options...
alaninaustria Posted September 13, 2012 Share Posted September 13, 2012 This is definitely the best work in a very long time.... congratulations! I suspect a slight love of labor here!! Cheers Alan Link to comment Share on other sites More sharing options...
Dambusters2012 Posted September 13, 2012 Share Posted September 13, 2012 Hey Wolf! Absolutely stunning work once again. Now having started my own 1/32 Tamiya Spit' IX (http://forum.largescaleplanes.com/index.php?showtopic=40793) it has simply served to demonstrate how exceptional the scratch building in your build really is!!! Love it! Link to comment Share on other sites More sharing options...
airscale Posted September 13, 2012 Share Posted September 13, 2012 Wolf - awe inspiring stuff as usual with you on the Archer rivets, I just got some after seeing what you have done with them (as I expect many others will..) and can't wait to try them out one question if I may - how do you create such an effective wash for the oil staining? Thanks Peter Link to comment Share on other sites More sharing options...
LSP_Ron Posted September 14, 2012 Share Posted September 14, 2012 You amaze me on how you manage to make what appears to be a detailed part look so basic once your done adding your detail. You truely have a great eye for detail and scale. You obviously see the forest through the trees and then see all the trees individually Ron Link to comment Share on other sites More sharing options...
Wolf Buddee Posted September 14, 2012 Author Share Posted September 14, 2012 This is definitely the best work in a very long time.... congratulations! I suspect a slight love of labor here!! Cheers Alan Thanks Alan, I do like the Spitfire but this particular kit is one of the nicest collection of plastic pieces I've had the pleasure of assembling. Once I started building, the research on the subject took off and the whole thing snowballed to what where it is now. Tamiya has definitely hit it out of the ballpark with this kit in so many different ways, I just had to do both the kit and the subject justice. In my opinion the Mk IX and the Mk VIII are the nicest looking of all the marks. Thanks again, Cheers, Wolf Link to comment Share on other sites More sharing options...
Wolf Buddee Posted September 14, 2012 Author Share Posted September 14, 2012 (edited) Hey Wolf! Absolutely stunning work once again. Now having started my own 1/32 Tamiya Spit' IX (http://forum.largescaleplanes.com/index.php?showtopic=40793) it has simply served to demonstrate how exceptional the scratch building in your build really is!!! Love it! Thank-you Dambusters, it all starts with an incredible kit. I've checked your build out and you're doin' a great job of it. Keep up the fantastic work! Cheers, Wolf Edited September 14, 2012 by Wolf Buddee Link to comment Share on other sites More sharing options...
