198 -
Days Won
2
Posts posted by Renegade
I see Rafju beat me to posting an update...
18 minutes ago, alain11 said:well , in fact , there are not so much parts ..... promising !!!!!!!!!!!!!!!!!
The pictures shows less parts, because only one master is made for certain parts that are to be duplicated
Cheers,
John
- wunwinglow, thierry laurent and rafju
- 3
13 hours ago, topper71 said:
With à little delay, but if I can helps, here 2 interresting book on the subject regards (Marcel )topper71
Thanks Marcel
Apologies for not posting much lately, as studies and exams have once again restricted modelling time.
There was a couple of panel lines out of place that I spotted while test fitting the rudder linkage and installing antennas on the front and rear edges of the the tail fin. The lines were filled and correct ones scribed. It has just been sanded down, and will be refined once more.
Molds for the main landing gear assembly were made for mirrored parts, as well as some vents on the airframe. The wing tip launcher for the Matra 550 Magic is also work in progress.
Cheers,
John
On 9/10/2022 at 6:09 PM, alain11 said:
Hi
thank you Raphael for the photos , we can clearly see how complex are the main gear legs with "curves " and "leaves" ( ???) a very challenging job !!!!!!
moreover , these parts ask questions : due to their inclination and stance , will they be strong enough , to support the weight of the kit ??, the resin , is a brittle material ........
Alain
Hi Alain,
Not to worry about the strength. As you might recall with the Mirage IIID2Z, the gear will be cast with a metal rod inserted.
On 9/10/2022 at 11:54 AM, rafju said:Would you also be so curious? (hi, hi, hi)
Not so much hahaha
Some more work on the nose gear.
Sometimes one can lose track of a project, and just to review on where progress is at, a picture of the parts that I could manage to fit on an A3 cutting mat.
Cheers
Thanks guys
On 8/31/2022 at 4:14 PM, Cheetah11 said:Just a heads up on the Matra RLF-4 Pod. Due to the higher speed and normally 4 pods being carried open ended pods caused more drag. Therefore the pods almost always had the frangible fibre glass covers fitted. You can find the right pod or part in the Mirage 2000 kit from Kittyhawk.
Nick, you are right, that is the norm. I have tried to fill and make those darn covers and failed miserably. Don't want to buy the Kitty Hawk kit just for RLF-4 cones either. I don't think that this is a deal breaker though.
The time has come to make the parts that are probably the most challenging on an F.1, the Main landing gear! ...
The complexity of it is not too bad once broken up into individual components. The main strut of the leg is the key, and tricky to find the correct angles outward and forward. A mold will be made of it to assure the same on both sides. After that, most of the other parts can be used for either, with minor little mirrored details added.
Cheers, and thanks for looking.
- scvrobeson, johncrow, Cheetah11 and 14 others
- 17
Hi Guys,
MATRA RLF-4 rocket pod master in progress. Removed the tail cone and cut out the lower portion of a Type 155 rocket pod. A disc from plastic card attached for material lost during cutting, in which the corresponding holes were also drilled. Inner blast pipe shaped from a piece of scrap resin. The rough work looks the part, and will now be refined.
Thanks to all for popping in to see the progress
Cheers,
John
Hi Guys,
I haven't posted in a while, due to studying and writing exams.
Some work did get done in between, like successfully removing the starboard wing combat flaps, slats, flaps and aileron for their deployed positions. Also made some vents for underneath the belly. The standard ventral fins as well as the SAAF mod with CHAFF/Flare dispensers. The two underwing CLB30 and Alkan 915/916 pylons (still working on getting the rough shape right) are currently in progress.
Cheers,
John
- johncrow, Fanes, Paul in Napier and 14 others
- 17
Hi guys,
The aileron control horn and push rod (Push rod is still to long) are pretty much done.
Again, molds will be made to ensure that they will be the same shape size.
Cheers,
John
Hi Nick,
That would be awesome. However, the AZ has a couple of unique features, and would have to be considered as a completely separate product. Besides the nose, the following are also different:
Cockpit bulkhead, instrument panel, instrument cowl. Not to mention the weapons loadout
Cheers,
John
Hi guys,
Mold has set, and will cast copies today.
Also made the aileron control fairing, and will make a mold of it as well.
Cheers,
John
- blackbetty, Marcel111, alain11 and 4 others
- 7
45 minutes ago, topper71 said:
Hi John,
An another question, given the many similarities with the french F1C, will there be decals planned for a french version decoration in your kit ?
Regards Marcel
Yes, French markings will be included
Cheers,
John
- dutik, johncrow, Rockie Yarwood and 2 others
- 5
10 hours ago, Cheetah11 said:
Maybe easier to do a flaps up and another flaps down set of wings and include both in the kit?
Nick, I did not explain it clear enough. That is where the molds come in after the break up lines have been scribed for port and starboard fairings. They will indeed be supplied for the retracted position.
48 minutes ago, topper71 said:Hi John !!
Great work, have you planned armements for the F1 perhaps magic 530 missiles or more ?
Regards Marcel
Thanks Marcel,
Armament will be:
4 x LRF-4 rocket pods
2 x Matra Magic
The centerline pylon will have a drop tank.
The fairing has been shaped, and rough pencil markings to help wrap my mind around it. A mold will be made of it today.
Cheers,
John
- rafju, johncrow, blackbetty and 3 others
- 6
Thanks Nick and Raph. Your comments are greatly appreciated.
8 hours ago, Cheetah11 said:The flaps are looking great John. Well done
On a side note I measured the wing and fuselage in the week after all the internet chatter on the old Esci and KH 1/48 kits. The Esci kit was done erroneously with the launchers included in the span but the length checks out. KH kit 1/45 ????
Cheers
Nick
That is true, and why I am not using any reference to either of those for the build. Although the Kitty Hawk kit is better engineered and sadly oversized, the Italeri kit looks pretty good for it's age, besides the short wingspan and very odd/squashed cockpit layout and windshield that is too long and tapers out too much.
Back to the build, the flap mechanism underneath the F.1 wing is a mindblowing design. I'm first going to make the fairing in the retracted position and make a mold of it to ensure they are the same shape and size. Seeing that they are mirrored, then only scribe the lines on the resin copies where they split up like a Swiss Army knife...lol. Then molds of them will be made (because i'll probably screw one or two up) to cut up into the sections for deployed flaps.
Cheers,
John
Hi Guys,
The flaps and aileron cut out. The flap slots were a pain to get the curves and angles. After some primer, I can see that I sanded away a little uneven on some spots, but will get it right. A quick mock up to see what they look like, but will get a better idea later when their brackets and rails are in place.
Cheers,
John
On 8/2/2022 at 1:01 AM, daveculp said:
I do quite a bit of vac-forming and also use PETG as well. Mostly with 0.7mm thickness, and 1mm for ones that needs to accommodate for more stretching. PETG is quite tough, and you can almost push the windshield flat and still return to it's shape without cracking. You can easily flair the windshield wider without worries that it will be damaged. It might be a tad lower at the top afterwards.
Cheers,
John
3 hours ago, Cheetah11 said:
Good job John.
If you are going to deploy the flaps have a look at the trailing edge flap. They are double slotted and move a fair amount backwards to increase the area when deployed.
Cheers
Nick
Hi Nick,
It is surprising how far they travel to back. Making the slots will be a delicate task, not to mention casting them eventually.
Cheers,
John
55 minutes ago, alain11 said:
just for fun , a video dedicated to our SA friends
Great video, I've watched it many times.
44 minutes ago, rafju said:Hi John @Renegade
Very good job, outstanding skills!
can't wait for the flaps when I see at what you did on slats!
raph
Thanks Raph,
The flaps and ailerons share a complicated mechanism and housing that splits asymmetric. It's going to be a fun challenge.
Cheers,
John
Hi Nick,
Thanks for clearing that up, and it makes sense to protect the mechanisms from dust. It does look awesome when they are deployed though.
I do have the flap and slat setting from the manual. I still have to make the plate that covers the gap above the combat flap hinge when it pivots down.
Cheers,
John
Thanks Alain,
Yes, it will be a dirty wing, because it just looks so cool with the control surfaces deployed. The spoilers will not be open though, because it is not normal for the aircraft in a static display.
1/32 Mirage F.1C
in Works in Progress
Hi guys,
It's been going crazy my side, but managed to get some more molds done and successful first castings for the 1/32 Mirage F.1C/CZ.
Cheers
