Uilleann Posted May 27, 2017 Share Posted May 27, 2017 I....... I....... I....... HOLY SCHNIKES!!!!!! Jeff, zaxos345 and airscale 3 Link to comment Share on other sites More sharing options...
GrumblyCarrion Posted May 27, 2017 Share Posted May 27, 2017 (edited) Peter, Always amazing, interesting, inspirational and generally fun to read and ogle at, thank you for sharing. Best Alex Edited May 27, 2017 by GrumblyCarrion Jeff and airscale 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 27, 2017 Share Posted May 27, 2017 Peter Only the keenest of eyes would ever have a clue. Beautiful work as always my griend Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Gazzas Posted May 27, 2017 Share Posted May 27, 2017 Man, o Man! airscale 1 Link to comment Share on other sites More sharing options...
brahman104 Posted May 27, 2017 Share Posted May 27, 2017 (edited) That is beautiful work Peter. I wouldn't be too fussed about the split of the parts, once you cleaned them up the join is hardly recognisable! Was that Pewter that you were using there? Did you apply the rivets once the panel was in place on the model to support it? In any case, it does have a characteristic look and you nailed it! Craig EDIT: I see you said the piece was ali.... I take it that you annealed it, but how is it so clean at the start? Mine ends up going brown with the heat process. Also, how do you support something that complex yet fragile when you cut it out from the waste area? Edited May 27, 2017 by brahman104 airscale 1 Link to comment Share on other sites More sharing options...
jenshb Posted May 28, 2017 Share Posted May 28, 2017 I knew that would be a challenge, but you've beat it into submission. Terriffic job. Jens airscale 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted May 28, 2017 Share Posted May 28, 2017 Really nice to see such craftsmanship! Amazing!! Cheers Alan airscale and Jeff 2 Link to comment Share on other sites More sharing options...
Jeff Posted May 28, 2017 Share Posted May 28, 2017 This is Magic, in it's purest form......... there are really no words, and I even dug out my old school Thesaurus ........................ nothing.....in this language anyway.... it is a wonderful feast for the eyes... just bloody fabulous....just gets better and better.... thanks for this Peter.... you have NO idea how much I am enjoying this adventure... airscale 1 Link to comment Share on other sites More sharing options...
TonyT Posted May 29, 2017 Share Posted May 29, 2017 (edited) ok they are highback dimensions, but screen too both armoured and X1X curved, so do not know if they help, 9 drawings uploaded https://flic.kr/s/aHskXGLjeG Edited May 29, 2017 by TonyT airscale 1 Link to comment Share on other sites More sharing options...
airscale Posted May 30, 2017 Author Share Posted May 30, 2017 Hi folks That is beautiful work Peter. I wouldn't be too fussed about the split of the parts, once you cleaned them up the join is hardly recognisable! Was that Pewter that you were using there? Did you apply the rivets once the panel was in place on the model to support it? In any case, it does have a characteristic look and you nailed it! Craig EDIT: I see you said the piece was ali.... I take it that you annealed it, but how is it so clean at the start? Mine ends up going brown with the heat process. Also, how do you support something that complex yet fragile when you cut it out from the waste area? Hi Craig - thanks for stopping by so the ali is not annealed, it is just soft already, almost like thick tinfoil, I am not sure what it is, or what it is used for, or indeed where to get it as I was sent some from the US by someone on HS who worked in a lab... as for supporting it, it is fairly thick so is not going to deform like foil, but a careful touch is needed thats for sure, sometimes I rivet beforehand, but mainly I do it afterwards as seams you think are right end up moving as the part is applied so the rivets are in the wrong place - this is done slowly and carefully as otherwise you can deform the edges and get big depressions & wrinkled edges instead of a nice neat rivet imprint.. I can show a little more as I just used some for the wingtips.. first a tape template, here the tape kinks a bit on the bottom side as it doesn't like compound curves either.. ..the tape is then transferred, cut out and taped / shaped to the tip starting from the top seam first... ..this one was rivitted on the top seam to start with, and you can see it keeps its shape quite well.. ..moving on to the nav light area - on TZ138 this is plated over so that made it easier - here a sheet has been tapped into shape and the borders run around with a cocktail stick to define them.. ..this is then cut & shaped to fit, but even then the bottom seam still needed trimming to match the panel line.. ..both wingtips are now complete - the wrapping is back on the airframe so just the tips are showing... ..moving on to the canopy.. ok they are highback dimensions, but screen too both armoured and X1X curved, so do not know if they help, 9 drawings uploadedhttps://flic.kr/s/aHskXGLjeG thanks Tony - very useful, I did start to make use of the XIV drawings in the monforton book, and used the drawings to construct a three dimensional template.. ..this is then loosely filled with P38 filler.. ..refined down to the template outline.. ..and ultimately the complete mould - I need to add to it so it moulds properly and will likely cast it in resin as I have had trouble in the past with primer coming off due to the heat etc.. ..need to do the windscreen next as there is a curved bit at the top,, TTFN Peter Jeff, Shawn M, Shaka HI and 13 others 16 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 30, 2017 Share Posted May 30, 2017 Unreal as USUAL Peter! Carry on! airscale, Shaka HI and Jeff 3 Link to comment Share on other sites More sharing options...
TorbenD Posted May 30, 2017 Share Posted May 30, 2017 Beautifully inspiring as ever Peter. Are you planning to simply crash mould the canopy or use male (or female) vac-forming? Torben Out2gtcha and airscale 2 Link to comment Share on other sites More sharing options...
Squizzy 78 Posted May 31, 2017 Share Posted May 31, 2017 Mind blowing !!! One day I'd like to try skinning a model in aluminium, but I know I can't do it like this, that's a gift, amazing job Peter. Shaka HI and airscale 2 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted May 31, 2017 Share Posted May 31, 2017 No words... Cheers Rainer airscale 1 Link to comment Share on other sites More sharing options...
ungoliat Posted May 31, 2017 Share Posted May 31, 2017 Peter, When I grow up I want to be like you... airscale 1 Link to comment Share on other sites More sharing options...
