dmthamade Posted July 8, 2017 Share Posted July 8, 2017 Still with PB so i don't know how much longer this will work, will go with one of the other options soon. This is the Czech Models kit of the F-80, looks like the T-33 by the same manufacturer. Haven't tried any dry fitting yet, reading reviews and builds, i'm sure i'll have my work cut out for me. I have done the T-33 in canadian markings, it was the worst fitting kit i had done in a long time, a battle to get everything sorted out but in the end well worth the effort. I guess it's a typical short run kit. Decal options are very colorful, there is not much out there aftermarket wise. Don't know if i'll add much to the pit, not much to see in the small opening. Standard pic of the kit. Pic of the T-33 i did. Don BradG, MikeMaben, red baron and 11 others 14 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 8, 2017 Share Posted July 8, 2017 Don Will be following with great interest .. just a gem of a kit. Your T-33 is awesome - beautifully done Peter Link to comment Share on other sites More sharing options...
themongoose Posted July 11, 2017 Share Posted July 11, 2017 I love the T-33! A real teaser for your czech model. dmthamade 1 Link to comment Share on other sites More sharing options...
dmthamade Posted July 12, 2017 Author Share Posted July 12, 2017 (edited) Test for Image shack. Edited July 12, 2017 by dmthamade blackbetty and ClumsyDude 2 Link to comment Share on other sites More sharing options...
ClumsyDude Posted July 16, 2017 Share Posted July 16, 2017 Imageshack is looking good, so off you go! I was a huge fan of your T-33 so looking forward to this one too. Jim dmthamade 1 Link to comment Share on other sites More sharing options...
dmthamade Posted July 22, 2017 Author Share Posted July 22, 2017 (edited) Image shack seems to be a big improvement over PB, pictures appear as i took them, not darker or with less detail. I've been away from the bench for the most part, enjoying summer and been off on vacation for the last week. Not much done, but did a manage a bit yesterday. The fit on this kit is better than the T-33 was, intakes were much easier to fit, and the wing bottom to fuselage joint is also much better. Not to say it's Tamiya quality but nothing insurmountable. It says "Limited Run" on the box, i get that and am OK with it. Not crazy about the decal selection in the lit or aftermarket, have to figure out what i'll do about that. Don Edited July 22, 2017 by dmthamade Alain Gadbois, BradG, Harold and 2 others 5 Link to comment Share on other sites More sharing options...
dmthamade Posted July 29, 2017 Author Share Posted July 29, 2017 (edited) So, last night had some time at the bench and accomplished a lot. Cleaned up the wing seams and glued onto fuselage. This AM i checked out the work, looked good, some seams to be filled but nothing major. One small problem....i forgot to finish and install a "small" detail. You can see it there... Don Edited July 29, 2017 by dmthamade sandokan and R Palimaka 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 29, 2017 Share Posted July 29, 2017 Don Yikes. I posted my idea it the other thread for you. I'm sure a few of the suggestions will work Peter Link to comment Share on other sites More sharing options...
dmthamade Posted July 30, 2017 Author Share Posted July 30, 2017 Don Yikes. I posted my idea it the other thread for you. I'm sure a few of the suggestions will work Peter There are a lot of suggestions given, going to take a bit of a break to figure this out. Really hate the idea of cracking this one open... Don It was going together so much easier than the T-33..... LSP_Kevin 1 Link to comment Share on other sites More sharing options...
dmthamade Posted July 30, 2017 Author Share Posted July 30, 2017 After some thought and suggestions on how to fix, i managed to fit the pit in with no cutting of the fuselage. First i cut the tub up a little bit. By cutting off the rear bulkhead and cutting out the small kickout, i can squeeze the pit together and it falls into place in thru the hole!!! I went ahead and glued it in, then reattached the rear bulkhead. The big hole will be covered by the seat Big sigh of relief!! I'll paint it in place, not too worried about the consoles as realistically very little can be seen. The instrument panel i will use the PE parts. Back on track, now Thanks to all who offered suggestions!! Don Shaka HI, Hardcore, BradG and 11 others 14 Link to comment Share on other sites More sharing options...
Joel_W Posted July 30, 2017 Share Posted July 30, 2017 Don, Nicely done. Joel dmthamade 1 Link to comment Share on other sites More sharing options...
Gazzas Posted July 30, 2017 Share Posted July 30, 2017 Great save! dmthamade 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted July 30, 2017 Share Posted July 30, 2017 Great recovery Don! I wouldn't have thought of squeezing the two side consoles together like that. Carl dmthamade 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 30, 2017 Share Posted July 30, 2017 Great save! Yes indeed! Kev logan181 and dmthamade 2 Link to comment Share on other sites More sharing options...
ClumsyDude Posted July 30, 2017 Share Posted July 30, 2017 All RIGHT Don, great job - brilliant save. Jim logan181 1 Link to comment Share on other sites More sharing options...
