Neo Posted December 27, 2017 Share Posted December 27, 2017 Hi Guys Couple weeks ago i started this project that came with a really cool back story At last years LSP X-Mas raffle (2016) i won some very cool books , looking back on the thread i notice that maru seamed to relly like them, so i decided to donate them to him no strings attached. To my very big surprise Maru insisted in sending me his raffle win, a 1/32 Special hobby P-39D complete with a Big Ed set, as amazing as this was he also added a squadron walk around and a sort reference on WWII british camo!! its been almost a year and as im writing this im still speacheless! Ive been wanting to get to this one and i promiessed myselft to get it going before years end, now ive only manage to build one kit this year , a USCG HH-65. This year has been a wild ride, ive changed job twice, for the better btoh time, but that brouth lots of late night and homework catching up with the projects , teams, technology stack and on top of that i did a kitchen facelift to my house on a tiny buget of 2500CAD$(buget was a persola challenge of proving that you dont need to spend 15000$ to have a nice kitchen) but im blabering! Back on topic So for this build i really wanted to build a RAF gray and green scheme so got the Maketar Mask, and got my first set of brass barrels(profimodeler) Here is my current progress Cockit is almost done and ive been cleaning up flight surfaces. I installed the PE in the wheels wells. Ive spent some time building the PE flaps set but i realized i had to chop parts of the wings to fit them in and im not sure if im up for that challenge yet!. I do have one question at the moment, What color are the intakes on these birds(on the leading edge of the wings) ? im leaning on painting them white but im not sure, the only good pics i have and B&W or OD green planes More to come in 2018! THANK YOU MARU Cheers Neo Whitey, sandokan, CANicoll and 5 others 8 Link to comment Share on other sites More sharing options...
Dandiego Posted December 27, 2017 Share Posted December 27, 2017 Looks like a good start. Always wanted to build one of these. Well maybe someday. Dan Link to comment Share on other sites More sharing options...
Gerhard Posted December 27, 2017 Share Posted December 27, 2017 That's Maru for you. CANicoll and Shawn M 2 Link to comment Share on other sites More sharing options...
Neo Posted January 22, 2018 Author Share Posted January 22, 2018 HI Guys ive been working on this one a little these days but mostly late night witch is making the carpet monster really happy, and progress slow !! here is the progress ive managed so far i built up the wings, and while there was a gap in front of the vents i really applied myself to fix it. now today while dryfitting the cockpit, i desided to dry fit the wings on.. but i just realized that those vents are reversed... oups. so i broke out the Tamiya Extra Thin applied it around the joint and managed to pry them out and reinstall then the correct way! Ive also installe the front vents and puttied it in nicely, there was some gaps but im satisfied with the result now i have closed the wings and finalyzed that fit on the vent Ive made some good progress on the cockpit ,and today ive managed to glue the cockpit in, ive lost many many small p.e handles on this one but him still very happy with the results here are the doors Ive also been experimenting with the barrels, my father in law gave me some left over Perma blue paste used for guns, ive gave these guys 2 coats, but im sceptical if it will work More progress soon i hope ! thank for following dennismcc, LSP_Kevin, Whitey and 2 others 5 Link to comment Share on other sites More sharing options...
Neo Posted June 26, 2018 Author Share Posted June 26, 2018 Hi guys it's been a while since I've updated this thread, I must say my modeling time has not been abundant these days. The project is coming along well and I'm really enjoying it. I've ran couple more passes with the gun blue on the brass barrels and the finish is pretty good I've spent many hours installing all the pe and the detail in the cockpit. I'm really happy with the results, although those throttle levers fell off so many times! had to tweak the seam line. I used Tamiya surface primer with a bush then sanded it down I added the Eduard pe to the wheels, you can see the difference I installed the canopy, and re worked the seams, I then primed the entire plane with Tamiya White surface primer(airbrushed) Not in pictures but I've painted the wings leading edges yellow and the RAF duck green band on the rear fuselage. As for painting I did not have any RAF colors, so I went out to get some, but unfortunately my close paint sources no longer carry humbrol or Model master witch I normally use so I ended up buying some Tamiya paint. this will be a first for me I'll let you know how that goes. Today I realized that I forgot I'm using paint mask ... so I searched for the RAF roundel colors and this is what I've found on the subject Dull BlueInsigniaFS:35044 Dull RedInsigniaFS:30109 Identification WhiteInsigniaFS:37875 Next step is to match these in MM or Humbrol. I believe I should lay down the white now then mask, paint the camo, then paint the rest of the insignias? I've never done this before but I'm sure I'll figure it out. NukerDan, Bruce_Crosby, TorbenD and 7 others 10 Link to comment Share on other sites More sharing options...
MikeMaben Posted June 26, 2018 Share Posted June 26, 2018 Looking good Neo Link to comment Share on other sites More sharing options...
Neo Posted June 26, 2018 Author Share Posted June 26, 2018 Looking good Neo Thank you. MikeMaben 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 26, 2018 Share Posted June 26, 2018 Looks good! I like the interior a lot Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted June 27, 2018 Share Posted June 27, 2018 This and the P-63 are my two favorite fighters of all time, and I love this. You're doing this one proud! Bloody gorgeous. Link to comment Share on other sites More sharing options...
Neo Posted June 28, 2018 Author Share Posted June 28, 2018 Looks good! I like the interior a lot Thank you. It was allot of work but its worth it. Plus since the doors will be left open and the glass is big i have a feeling it will be visible once completed Out2gtcha 1 Link to comment Share on other sites More sharing options...
Neo Posted June 28, 2018 Author Share Posted June 28, 2018 (edited) This and the P-63 are my two favorite fighters of all time, and I love this. You're doing this one proud! Bloody gorgeous. Thank you. I really like these odd planes. This an the p-38 are some of my fav too. Do you guys have any advice for paint mask? The reference im using is this tutorial for montex mask http://www.montex-mask.com/en/tutorial-jak-malowac Edited June 28, 2018 by Neo Link to comment Share on other sites More sharing options...
pacificmustang Posted June 29, 2018 Share Posted June 29, 2018 Day Neo I did a similar build last year using the Kittyhawk kit Here is my Flickr album detailing the build, showing some pics of me using the Maketar masks. https://www.flickr.com/photos/131700029@N03/albums/72157679018142276 Beware that Maketar does not provide handed fin flashes on his set so you have to make make yourself for one side of the fin. This is easily achieved using tamiya tape or similar I use tamiya paints, so used Royal Blue plus black for the roundel blue Red plus a touch of Hull Red for the red Yellow plus a touch of red for the yellow Hope this helps you. Im liking the work you have done so far Cheers Bruce MikeMaben and CANicoll 2 Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted June 30, 2018 Share Posted June 30, 2018 Neo, I wish I could help, but every single P-39 and P-63 I have ever or will ever build has Red Stars on it's fuselage and wings. I've just gotten on some crazy VVS kick when it comes to these things. Keep up the awesome work though, Sir, it's gonna be incredibly awesome when complete. Ernie Link to comment Share on other sites More sharing options...
tomprobert Posted June 30, 2018 Share Posted June 30, 2018 I've just recently added this kit to the stash. From your smooth progress, it appears to go together well. You're tempting me..! Tom Link to comment Share on other sites More sharing options...
TorbenD Posted June 30, 2018 Share Posted June 30, 2018 Oooh how did I miss this first time? Looking great so far Neo - those intakes in particular take a lot of fettling in don't they. I'm looking forward to seeing how you get on with the top coat - with a strong note to self to dust off mine which is currently resting mid-build but will be in a similar scheme. Torben Link to comment Share on other sites More sharing options...
