Azgaron Posted April 4 Share Posted April 4 I guess I'm not the first one to build this kit! Starting with the cockpit as usual. Some interior grey green. Then a little aluminium. And a bit of black here and there and alu on the other side of some parts. Something with the pics on my site ain't working, so I can't show more pics at the moment. Have to sort that. Håkan MikeMaben, dennismcc, Fanes and 15 others 18 Link to comment Share on other sites More sharing options...
Biggles87 Posted April 5 Share Posted April 5 Always ready for another Spitfire build, so I’m in. Looks like you’ve made a good start. John Azgaron and geedubelyer 2 Link to comment Share on other sites More sharing options...
Archimedes Posted April 6 Share Posted April 6 Great start Håkan Looking forward to seeing how this one develops! kind regards, Paul Azgaron 1 Link to comment Share on other sites More sharing options...
Phil88 Posted April 6 Share Posted April 6 Nice work Azgaron 1 Link to comment Share on other sites More sharing options...
Azgaron Posted April 14 Author Share Posted April 14 Thank you John, Paul and Phil! More painting done on the interior and wings. Adding decals to the IP was a bit of a pain in the butt. I lost a few of the small ones. Then the side panels also got their decals. The instruments got a bit of kristal klear, but i barely shows. Then I started assemble the cockpit. I tried my hands at rigging the cockpit with wire. That kind of wire perhaps wasn't the best thing to use, but I didn't have anything else. While that was drying, I glued the wing parts. And the radiators. Back to the interior which got a bit of black wash. Next will be some cockpit assembly. Håkan chaos07, denders, chrish and 13 others 16 Link to comment Share on other sites More sharing options...
dennismcc Posted April 15 Share Posted April 15 Nice work, looking forward to more. Cheers Dennis Azgaron 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted April 16 Share Posted April 16 Link to comment Share on other sites More sharing options...
Azgaron Posted April 16 Author Share Posted April 16 Thank you Dennis and Mike! The cockpit side panels was glued in place. As with everything else on this kit, it's a very tight fit. The wing roots was glued in place. The cockpit was glued to the fuselage and then the fuselage halves were glued together. The stabilizer was glued in place. The sight was assembled and painted. Then the front cover with the sight was glued in place as well as the engine covers on both sides. The wings was glued in place. The fit was very nice. I also assembled the propeller and spinner. Update coming soon! Håkan MikeMaben, Biggles87, Shoggz and 11 others 14 Link to comment Share on other sites More sharing options...
Archimedes Posted April 17 Share Posted April 17 Nice work Håkan! Wow you are quick! Kind regards, Paul Azgaron 1 Link to comment Share on other sites More sharing options...
Azgaron Posted April 17 Author Share Posted April 17 Thank you Paul! Not, really. It's an ongoing build that I've been very slow to post about! The exhausts was assembled and then drilled out a bit. Landing gear parts and propeller was painted. I used the closed canopy as cover when painting. Exhaust pipes, tail gear and the door was painted. The tires was painted with a mix of black and tire black. The exhaust pipes was dry brushed and given a hint of rust. And the mirror and closing handle for the canopy was sorted. Then the plane got some primer. Next up, some paint. Håkan Biggles87, LSP_Kevin, Landrotten Highlander and 5 others 8 Link to comment Share on other sites More sharing options...
geedubelyer Posted April 17 Share Posted April 17 This one is moving right along @Azgaron. Lovely stuff so far Azgaron 1 Link to comment Share on other sites More sharing options...
Azgaron Posted April 17 Author Share Posted April 17 Thank you @geedubelyer! Håkan geedubelyer 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted April 17 Share Posted April 17 Nice work, Håkan! Kev Azgaron 1 Link to comment Share on other sites More sharing options...
monthebiff Posted April 17 Share Posted April 17 Looking good, the wing assembly to fuselage was such a tight fit on my first build and then on my second build glued the wing fillers to the fuselage first and the whole fit was much better. Looking forward to more progress. Regards. Andy Azgaron 1 Link to comment Share on other sites More sharing options...
Azgaron Posted April 18 Author Share Posted April 18 Thank you Kev and Andy! The fit sure was tight. If I ever build one more, I'll try glueing the fillets first. I did a pre-shade with brown and then painted the underside with sky type s. Then I masked the underside and gave the topside a black pre-shade. Then on with some dark earth. Some black goo was applied to mask the camo. Dark green was painted and then the goo was removed. I wasn't happy with how some of the camo turned out, so I applied goo again. Don't leave it on too long though! After a few paint sessions it looked like this. I accidently got some overspray on the underside. Easily sorted! I've clear coted the plane and have started with the decals, but no pics yet, so this is where I'm at right now. Håkan LSP_Kevin, MikeMaben, patricksparks and 8 others 11 Link to comment Share on other sites More sharing options...
