monthebiff Posted March 9, 2023 Posted March 9, 2023 1 hour ago, mozart said: But I don’t know if he’s still in business Dennis. I can’t find a way of ordering on his website which is why I sent him an email this morning. Fingers crossed! Hopefully he is still in business as I needed another correction set and Watts propellor for my rag wing build. Regards. Andy mozart 1
LSP_Kevin Posted March 9, 2023 Posted March 9, 2023 Excellent progress, Max! Brian's a member here, but I don't think he's been active for quite some time. I hope his is still in business, as I'm thinking I'll need his parts for my own build of this kit! If you get a response, please let us know. Kev mozart 1
mozart Posted March 9, 2023 Author Posted March 9, 2023 (edited) Will do Kev. If Brian wasn’t still in business I don’t see the benefit of his website still being there, but on the other hand I couldn’t see a way of ordering, and the site looks a bit “neglected”! Half of me is optimistic, but t’other half……? PS. More work on the Moth tomorrow! Edited March 9, 2023 by mozart LSP_Kevin 1
thierry laurent Posted March 9, 2023 Posted March 9, 2023 Excellent work!!! By the way, to me, there is a reason explaining the fact some Black dog figures have quite soft faces and hands: they look like perfect copies of Airfix plastic 1/32 multipose figures parts... This explains that! Typically this is why I'm often avoiding figures for which the master has been made by Radek Tomanec... Caveat Emptor. mozart 1
MikeMaben Posted March 10, 2023 Posted March 10, 2023 Looking good Max. I made my own doghouse extension (long before Brian offered his). I didn't bother with the nose coversion as the difference is barely noticeable (to me). Don't forget the hole in the port side. I have no idea what it's for but it's on all Hurricanes. I highly recommend the AIMS Rotol spinner and blades. Also Barracuda's wheels. Have fun. Landrotten Highlander, Troy Molitor, Alain Gadbois and 3 others 5 1
mozart Posted March 10, 2023 Author Posted March 10, 2023 (edited) Thanks Mike, I emailed John last night about his Rotol prop but no reply yet, and I’ve had no reply from Brian either which is ominous though he could be away. That ‘hole’, isn’t it a hand-hold with a spring mounted cover? Now you see it: Now you don’t: Edited March 10, 2023 by mozart MikeC, dennismcc and R Palimaka 3
mozart Posted March 10, 2023 Author Posted March 10, 2023 I’ve had a reply from Brian Fawcett, he closed his business due to “problems caused by Brexit” (what sn inspired event that was!) but is able to supply items as a personal sale so I’m ordering both the Watts and Rotol props, £4.50 and £5.50 respectively. Kev, I’ve asked him about availability etc of the dog kennel set, will let you know. R Palimaka, dennismcc and LSP_Kevin 3
mozart Posted March 10, 2023 Author Posted March 10, 2023 17 hours ago, monthebiff said: Hopefully he is still in business as I needed another correction set and Watts propellor for my rag wing build. Regards. Andy See above Andy! monthebiff 1
monthebiff Posted March 10, 2023 Posted March 10, 2023 1 hour ago, mozart said: See above Andy! Thank you Max, sounds promising Regards. Andy
mozart Posted March 10, 2023 Author Posted March 10, 2023 (edited) I’ve been trying to do a test fit for the dog kennel linked with the cockpit assembly and armour plating, quite tricky with the way the kit is constructed. I envisage some heavyweight clamping happening: Obviously there are refinements in many places to achieve a better fit, the first thing I’ve done is to thin the plastic behind the dog kennel so that it’s a little more flexible: And the cockpit assembly as it stands at the moment: The seat belts are HGW ones left over from a Mosquito kit, I don’t think I’ve put them together correctly and there’s another set of straps to come, but it’s good enough! Edited November 26, 2023 by mozart dutik, Landrotten Highlander, LSP_Kevin and 4 others 7
MikeMaben Posted March 11, 2023 Posted March 11, 2023 20 hours ago, mozart said: That ‘hole’, isn’t it a hand-hold with a spring mounted cover? This hole , I think it's a vent as it's positioned at the cutout opening where there is a vacuum / draw. ...not a big deal, but it is usually visible. Thot you might like to know about it. R Palimaka 1
mozart Posted March 11, 2023 Author Posted March 11, 2023 Ah, wrong hole! Ahem. monthebiff and Shoggz 2
monthebiff Posted March 11, 2023 Posted March 11, 2023 1 hour ago, mozart said: Ah, wrong hole! Ahem. Said the Nun to the Vicar Regards. Andy mozart 1
mozart Posted December 1, 2023 Author Posted December 1, 2023 (edited) This build of mine, started last year, has been moved here since it qualifies on all counts: less than 25% completed and F/O Brooker was certainly an “ace”. I spent an hour yesterday looking over the work so far done and planning the next steps, the first of which will be detailing this area: because those two prominent pipes are not very well formed on the Fawcett resin nose. Probably going to use nickel silver pipes if the size is about right……but very happy to be part of this GB chaps! (Albeit a bit late!) Edited December 1, 2023 by mozart Fanes, Shoggz, BradG and 5 others 8
