Nice details you have called out and added. I have one more of these in the stash, so it's good to have the compilation of details.
Hi all,
All of the parts have now been painted.
I've replaced the Parabellum machine gun with a 'GasPatch' Parabellum LMG14, which only meant a slight modification to the lit supplied mounting.
Now onto applying the decals and then weathering, before construction of the model,
Mike
21 hours ago, John1 said:
You are doing some truly impressive work here.   What are you using for paint?
Hi John,
Fuselage is 'Tamiya' acrylics - Dark Green 2 (RAF) - XF81 and Light Blue XF23,
Applied over an 'Alclad' Duraluminium (ALC102) base coat.
I was intending to chip the top coats but the lacquer Duraluminium coat caused the chipping solutions to 'bead up' instead of covering.
So instead I'll weather the metal painted surface by dry brushing,
Mike
Hi all,
A few updates.
The 'Aviattic' 5 colour faded lozenge decal applied.
Also the kit supplied decals.
I had to print the serial number for this particular aircraft.
I've fitted the tail plane, fin and rudder.
Also the two flare racks, engine Tachometer and pilots mirror.
Now it's weathering before assembly,
Mike
